ESP32, OLED Display and Deep Sleep
Good afternoon!
I breaded to make a battery-powered watch with an OLED SSD1306 screen on an ESP 32 that goes into deep sleep. I managed to send the board to sleep, but at the moment when the board falls asleep the screen continues to light. Tell me how you can turn off the screen when the board falls asleep
You could use a mosfet to be sure the display can’t draw any more power
shved86
Alexander
1m
yes, I thought about it, the question is, after esp wakes up the display needs to be initialized? If I remove the power from the display while the board is on and then return it back, it will not work
These commands should help:
display.ssd1306_command(SSD1306_DISPLAYOFF);
display.ssd1306_command(SSD1306_DISPLAYON);
With a little more research I think you will find your objective.
These don’t seem to be valid anymore. For anyone looking into the correct commands to turn off an OLED display use the display_on and display_off methods:
display:
  - platform: ssd1306_i2c
switch:
    turn_on_action:
      then:
        - lambda: |-
            id(oled_display).turn_on();
    turn_off_action:
      then:
        - lambda: |-
            id(oled_display).turn_off();
