ESP32 - On Time: adding more timer causes permanently reboots after download
I try to buil an project for my fish tank there in need some timers.
I want to connect:
4 Pumps over Relais for dosing pumps
8 sockets over relais for different things
8 Buttons for switching
2 Temperature Sensor (DS18b20)
I’ve got my functions to work for the dosing and now i wanted to start with the time scedule.
After adding the fourth time the ESP starts resetting and i am not able to do OTA anymore because it is fast rebooting
Device: ESP32 Dev Kit C V4
Code:
## Variablen
substitutions:
  ## Plug Name also for Variable
  dev_name: 129_og_aq
  dev_host: 129-og-aq
  dev_ip: 192.168.179.129
  #log_level: info
  #log_level: debug
  log_level: verbose
  log_rate: "115200"
  ## HW Substittuion
  # Dallas
  gpio_dallas_pin: GPIO04 #TX war 4 oder 1
  temp1_offset: "0"
  temp2_offset: "0"
# Basis Packages
packages:
  devi: !include base/b0_device_nodemcu_esp32_azv4.yaml
  hoas: !include base/b1_homeassistant.yaml
  logs: !include base/b2_log.yaml
  wifi: !include base/b3_wifi.yaml
  webs: !include base/b4_webserver.yaml
  #mqtt: !include base/b5_mqtt.yaml
  sens: !include base/b6_sensor.yaml
  swit: !include base/b7_switch.yaml
  #time: !include base/b8_time_ha.yaml
## HW Anschlüsse
# One Wire Sensoren
dallas:
  - pin: ${gpio_dallas_pin}
globals:
 # Pumpe 1
  - id: p1_faktor
    type: float
    restore_value: yes
    initial_value: '0'
  - id: p1_soll
    type: float
    restore_value: yes
    initial_value: '0'
 # Pumpe 2
  - id: p2_faktor
    type: float
    restore_value: yes
    initial_value: '0'
  - id: p2_soll
    type: float
    restore_value: yes
    initial_value: '0'
  # Pumpe 3
  - id: p3_faktor
    type: float
    restore_value: yes
    initial_value: '0'
  - id: p3_soll
    type: float
    restore_value: yes
    initial_value: '0'
 # Pumpe 4
  - id: p4_faktor
    type: float
    restore_value: yes
    initial_value: '0'
  - id: p4_soll
    type: float
    restore_value: yes
    initial_value: '0'
 # Dosiersollzeit
  - id: p_sollzeit
    type: float
    restore_value: no
    initial_value: '0'
 # Dosiermenge
  - id: p_menge
    type: float
    restore_value: no
    initial_value: '0'
 # Dosierzeit
  - id: p_laufzeit
    type: float
    restore_value: no
    initial_value: '0'
 # Dosierfaktor
  - id: p_faktor
    type: float
    restore_value: no
    initial_value: '0'
 # Temperatur Innen (Temp 1)
  - platform: dallas
    # address: 0x950000076A885828
    address: 0x6E3C01D0750B1628 # temp
    accuracy_decimals: 2
    filters:
      - median:
          window_size: 10
          send_every: 5
          send_first_at: 1
      - offset: ${temp1_offset}
 # Temperatur Becken (Temp 2)
  - platform: dallas
    # address: 0x03041750296CFF28
    address: 0xD03C01D075F44528 # temp
    filters:
      - median:
          window_size: 10
          send_every: 5
          send_first_at: 1
      - offset: ${temp2_offset}
 # Sollwert Pumpe 1
  - platform: homeassistant
    entity_id: input_number.og_ku_aq_p1_soll
    on_value:
      - globals.set:
          value: !lambda 'return id(soll_p1_ha).state;'
      - component.update: soll_p1
    icon: mdi:water-check
    unit_of_measurement: ml
    state_class: "measurement"
    accuracy_decimals: 1
    update_interval: 300s
    lambda: return id(p1_soll);
 # Sollwert Pumpe 2
    entity_id: input_number.og_ku_aq_p2_soll
    on_value:
      - globals.set:
          value: !lambda 'return id(soll_p2_ha).state;'
      - component.update: soll_p2
    lambda: return id(p2_soll);
 # Sollwert Pumpe 3
    entity_id: input_number.og_ku_aq_p3_soll
    on_value:
      - globals.set:
          value: !lambda 'return id(soll_p3_ha).state;'
      - component.update: soll_p3
    lambda: return id(p3_soll);
 # Sollwert Pumpe 4
    entity_id: input_number.og_ku_aq_p4_soll
    on_value:
      - globals.set:
          value: !lambda 'return id(soll_p4_ha).state;'
      - component.update: soll_p4
    lambda: return id(p4_soll);
 # Pumpe 1 Faktor
    unit_of_measurement: s/ml
    lambda: return id(p1_faktor);
 # Pumpe 2 Faktor
    lambda: return id(p2_faktor);
 # Pumpe 3 Faktor
    lambda: return id(p3_faktor);
 # Pumpe 4 Faktor
    lambda: return id(p4_faktor);
 # Kalibrierfaktor Handeingabe
    entity_id: input_number.og_ku_aq_p_calfaktor
    on_value:
      then:
        - sensor.template.publish:
            state: !lambda 'return (id(calfaktor_p_ha).state);'
 # Kalibriermenge
    entity_id: input_number.og_ku_aq_p_calmenge
    on_value:
      then:
            state: !lambda 'return (id(doszeit_p).state / id(calmenge_p_ha).state);'
 # Dosierzeit
 # Dosiermenge
 # Dosierfaktor
    accuracy_decimals: 3
binary_sensor:
 # Hand/Auto Schalter
  - platform: gpio
    icon: "mdi:run"
    pin:
      number: GPIO36
      mode: INPUT
      inverted: false
    on_multi_click:
    - timing:
          - ON for at least 10ms
      then:
        - text_sensor.template.publish:
            state: "Auto"
 # Sonos Taster
  - platform: gpio
    internal: "true"
    pin:
      number: GPIO39
      mode: INPUT
      inverted: false
    on_multi_click:
    - timing:
        - ON for at least 100ms
      then:
        - switch.toggle: sw_sonos
 # Filter Taster
  - platform: gpio
    internal: "true"
    pin:
      number: GPIO34
      mode: INPUT
      inverted: false
    on_multi_click:
    - timing:
      then:
        - switch.toggle: sw_filter
 # Heizer Taster
  - platform: gpio
    internal: "true"
    pin:
      number: GPIO35
      mode: INPUT
      inverted: false
    on_multi_click:
    - timing:
      then:
        - switch.toggle: sw_heizer
 # CO2 Taster
  - platform: gpio
    internal: "true"
    pin:
      number: GPIO32
      mode: INPUT
      inverted: false
    on_multi_click:
    - timing:
      then:
        - switch.toggle: sw_co2
 # Skimmer Taster
  - platform: gpio
    internal: "true"
    pin:
      number: GPIO33
      mode: INPUT
      inverted: false
    on_multi_click:
    - timing:
      then:
        - switch.toggle: sw_skimmer
 # Licht Taster
  - platform: gpio
    internal: "true"
    pin:
      number: GPIO25
      mode: INPUT
      inverted: false
    on_multi_click:
    - timing:
      then:
        - switch.toggle: sw_licht
 # Pumpen Taster
  - platform: gpio
    icon: "mdi:run"
    pin:
      number: GPIO26
      mode: INPUT
      inverted: false
    on_multi_click:
    - timing:
      then:
   ## Pumpe 1
        - if:
            condition:
              and:
                - text_sensor.state:
                    state: 'P1'
                    state: 'Kalibrieren'
            then:
              - switch.toggle: sw_p1
   ## Pumpe 2
        - if:
            condition:
              and:
                    state: 'P2'
            then:
              - switch.toggle: sw_p2
   ## Pumpe 3
        - if:
            condition:
              and:
                    state: 'P3'
            then:
              - switch.toggle: sw_p3
   ## Pumpe 4
        - if:
            condition:
              and:
                    state: 'P4'
            then:
              - switch.toggle: sw_p4
#     on_release:
#       then:
#         - switch.turn_off: sw_p1
#         - switch.turn_off: sw_p2
#         - switch.turn_off: sw_p3
#         - switch.turn_off: sw_p4
switch:
 # Pumpe 1
  - platform: gpio
    icon: "mdi:pump"
    pin:
      number: GPIO27
      inverted: true
    restore_mode: ALWAYS_OFF
    interlock: &intl_sw_p [sw_p1, sw_p2, sw_p3, sw_p4]
    on_turn_on:
      then:
        - globals.set:
            value: !lambda 'return id(p1_faktor);'
        - globals.set:
            value: '0.0'
        - globals.set:
            value: '0.0'
        - script.execute: pumpen_laufzeit
    on_turn_off:
      then:
        - globals.set:
            value: !lambda 'return (id(p_laufzeit) / id(p_faktor));'
            state: !lambda 'return id(p_menge);'
            state: !lambda 'return id(p_laufzeit);'
 # Pumpe 2
  - platform: gpio
    icon: "mdi:pump"
    pin:
      number: GPIO14
      inverted: true
    interlock: *intl_sw_p
    on_turn_on:
      then:
        - globals.set:
            value: !lambda 'return id(p2_faktor);'
        - globals.set:
            value: '0.0'
        - globals.set:
            value: '0.0'
    on_turn_off:
      then:
        - globals.set:
 # Pumpe 3
  - platform: gpio
    icon: "mdi:pump"
    pin:
      number: GPIO12
      inverted: true
    on_turn_on:
      then:
        - globals.set:
            value: !lambda 'return id(p3_faktor);'
        - globals.set:
            value: '0.0'
        - globals.set:
            value: '0.0'
    on_turn_off:
      then:
        - globals.set:
 # Pumpe 4
  - platform: gpio
    icon: "mdi:pump"
    pin:
      number: GPIO13
      inverted: true
    on_turn_on:
      then:
        - globals.set:
            value: !lambda 'return id(p4_faktor);'
        - globals.set:
            value: '0.0'
        - globals.set:
            value: '0.0'
    on_turn_off:
      then:
        - globals.set:
 # Sonos
  - platform: gpio
    icon: "mdi:speaker"
    pin:
      number: GPIO23
      inverted: true
    restore_mode: RESTORE_DEFAULT_OFF
 # Filter
  - platform: gpio
    icon: "mdi:air-filter"
    pin:
      number: GPIO22
      inverted: true
    restore_mode: RESTORE_DEFAULT_ON
 # Heizer
  - platform: gpio
    icon: "mdi:radiator"
    pin:
      number: GPIO21
      inverted: true
 # CO2
  - platform: gpio
    icon: "mdi:molecule-co2"
    pin:
      number: GPIO19
      inverted: true
 # Skimmer
  - platform: gpio
    icon: "mdi:vacuum-outline"
    pin:
      number: GPIO18
      inverted: true
 # Licht
  - platform: gpio
    icon: "mdi:led-strip"
    pin:
      number: GPIO05
      inverted: true
 # Klemme 4
  - platform: gpio
    icon: "mdi:power-socket-de"
    pin:
      number: GPIO17
      inverted: true
 # Steckdose 2
  - platform: gpio
    icon: "mdi:power-socket-eu"
    pin:
      number: GPIO16
      inverted: true
button:
 # Kalibrieren speichern
    on_press:
      then:
  ## Pumpe 1
        - if:
            condition:
                  state: 'P1'
            then:
              - globals.set:
                  value: !lambda 'return id(dosfaktor_p).state;'
              - component.update: faktor_p1
    ## Pumpe 2
        - if:
            condition:
                  state: 'P2'
            then:
              - globals.set:
              - component.update: faktor_p2
    ## Pumpe 3
        - if:
            condition:
                  state: 'P3'
            then:
              - globals.set:
              - component.update: faktor_p3
    ## Pumpe 4
        - if:
            condition:
                  state: 'P4'
            then:
              - globals.set:
              - component.update: faktor_p4
 # Pumpe P1 Dosieren
    on_press:
      then:
        - globals.set:
            value: !lambda 'return id(soll_p1).state * id(p1_faktor);'
            state: "P1"
        - switch.turn_on: sw_p1
        - wait_until:
            lambda: return id(p_sollzeit) < id(p_laufzeit);
 # Pumpe P2 Dosieren
    on_press:
      then:
        - globals.set:
            value: !lambda 'return id(soll_p2).state * id(p2_faktor);'
            state: "P2"
        - switch.turn_on: sw_p2
        - wait_until:
 # Pumpe P3 Dosieren
    on_press:
      then:
        - globals.set:
            value: !lambda 'return id(soll_p3).state * id(p3_faktor);'
            state: "P3"
        - switch.turn_on: sw_p3
        - wait_until:
 # Pumpe P4 Dosieren
    on_press:
      then:
        - globals.set:
            value: !lambda 'return id(soll_p4).state * id(p4_faktor);'
            state: "P4"
        - switch.turn_on: sw_p4
        - wait_until:
 # Pumpe Dosieren
    on_press:
      then:
        - button.press: bu_p1_dos
        - delay: 10ms
        - wait_until:
            switch.is_off: sw_p1
        - delay: 10s
        - button.press: bu_p2_dos
        - delay: 10ms
        - wait_until:
            switch.is_off: sw_p2
        - delay: 10s
        - button.press: bu_p3_dos
        - delay: 10ms
        - wait_until:
            switch.is_off: sw_p3
        - delay: 10s
        - button.press: bu_p4_dos
        - delay: 10ms
        - wait_until:
            switch.is_off: sw_p4
            state: "Keine"
text_sensor:
 # Auswahl Pumpen
    entity_id: input_select.og_ku_aq_sel_pumpe
    on_value:
          state: !lambda 'return id(sel_pumpe_ha).state;'
 # Auswahl Modus
    entity_id: input_select.og_ku_aq_sel_modus
    on_value:
          state: !lambda 'return id(sel_modus_ha).state;'
      - if:
          condition:
            - binary_sensor.is_on: bu_auto
          then:
                state: "Auto"
script:
 # Pumpen Laufzeit
  mode: single
  then:
    - while:
        condition:
          or:
            - switch.is_on: sw_p1
            - switch.is_on: sw_p2
            - switch.is_on: sw_p3
            - switch.is_on: sw_p4
        then:
          - delay: 100ms
          - globals.set:
              value: !lambda 'return (id(p_laufzeit) + 0.1);'
time:
 ## Automatisch Dosieren und Sonstiges
    # id: sntp_time
    # servers: fritz.box, 0.pool.ntp.org, 1.pool.ntp.org
    timezone: Europe/Berlin
    on_time_sync:
      then:
        - logger.log:
            format: "Synchronized SNTP system clock"
            level: "INFO"
            tag: "INFO SVBE"
    on_time:
   ## Every Day Dosieren
      - seconds: 0
        minutes: /3
        then:
          - logger.log:
              format: "Würde gerne dosieren"
              level: "INFO"
              tag: "INFO SVBE"
          - if:
              condition:
                    state: 'Auto'
              then:
                - button.press: bu_dosieren
      - seconds: 0
        minutes: 0
        hours: 6
        days_of_week: MON-SUN
        then:
          - logger.log:
              level: "INFO"
              tag: "INFO SVBE"
          - if:
              condition:
                    state: 'Auto'
              then:
   ## Every Day CO2
      - seconds: 0
        minutes: 30
        hours: 5
        then:
          - switch.turn_on: sw_co2
      - seconds: 0
        minutes: 30
        hours: 10
        then:
          - switch.turn_off: sw_co2
  #     - seconds: 0
  #       minutes: 30
  #       hours: 13
  #       days_of_week: MON-SUN
  #       then:
  #         - switch.turn_on: sw_co2
  #     - seconds: 0
  #       minutes: 0
  #       hours: 19
  #       then:
  #         - switch.turn_off: sw_co2
  #  ## Every Day Zusatzlicht
  #     - seconds: 0
  #       minutes: 0
  #       hours: 8
  #       then:
  #         - switch.turn_on: sw_licht
  #     - seconds: 0
  #       minutes: 0
  #       hours: 11
  #       then:
  #         - switch.turn_off: sw_licht
  #     - seconds: 0
  #       minutes: 0
  #       hours: 16
  #       then:
  #     - seconds: 0
  #       minutes: 0
  #       hours: 19
  #       then:
  #  ## Every Day Skimmer
  #     - seconds: 0
  #       minutes: 0
  #       hours: 4
  #       then:
  #         - switch.turn_on: sw_skimmer
  #     - seconds: 0
  #       minutes: 29
  #       hours: 5
  #       then:
  #         - switch.turn_off: sw_skimmer
Validation and Installing works flawlessly but the the ESP doesn’t boot successfully anymore.
Is there sth wrong in the code?
There is also a different in the Flash memory detected by esphomeflasher and given by the manufactorer 16MB vs 4MB from flasher.
Please help
Log über Esphomeflasher:
[12:06:50][I][ota:338]: OTA update finished!
[12:06:51][I][app:133]: Rebooting safely...
[12:06:51][D][esp32.preferences:114]: Saving preferences to flash...
[12:06:51][V][esp-idf:000]: I (112158) wifi:
[12:06:51][V][esp-idf:000]: state: run -> init (0)
[12:06:51]
[12:06:51][V][esp-idf:000]: I (112161) wifi:
[12:06:51][V][esp-idf:000]: pm stop, total sleep time: 65099811 us / 107566939 us
[12:06:51]
[12:06:51]
[12:06:51][V][esp-idf:000]: I (112174) wifi:
[12:06:51][V][esp-idf:000]: new:<11,0>, old:<11,0>, ap:<255,255>, sta:<11,0>, prof:1
[12:06:51]
[12:06:51][D][WiFiGeneric.cpp:374] _eventCallback(): Event: 3 - STA_STOP
[12:06:51][V][wifi_esp32:465]: Event: WiFi STA stop
[12:06:51][V][esp-idf:000]: I (112219) wifi:
[12:06:51][V][esp-idf:000]: flush txq
[12:06:51]
[12:06:51][V][esp-idf:000]: I (112220) wifi:
[12:06:51][V][esp-idf:000]: stop sw txq
[12:06:51]
[12:06:51][V][esp-idf:000]: I (112231) wifi:
[12:06:51][V][esp-idf:000]: lmac stop hw txq
[12:06:51]
[12:06:51]ets Jun  8 2016 00:22:57
[12:06:51]
[12:06:51]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[12:06:51]configsip: 0, SPIWP:0xee
[12:06:51]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[12:06:51]mode:DIO, clock div:2
[12:06:51]load:0x3fff0018,len:4
[12:06:51]load:0x3fff001c,len:1044
[12:06:51]load:0x40078000,len:8896
[12:06:51]load:0x40080400,len:5828
[12:06:51]entry 0x400806ac
[12:06:51][I][logger:214]: Log initialized
[12:06:51][C][ota:458]: There have been 0 suspected unsuccessful boot attempts.
[12:06:51][I][app:029]: Running through setup()...
[12:06:51][V][app:030]: Sorting components by setup priority...
[12:06:51][C][switch.gpio:011]: Setting up GPIO Switch '129_og_aq_pumpe_1'...
--- gekürzt wg. post Länge ---
[12:06:52][D][binary_sensor:034]: '129_og_aq_status': Sending initial state OFF
[12:06:52][V][text_sensor:016]: '129_og_aq_version': Received new state 2021.12.3 Jan  9 2022, 12:06:17
[12:06:52][D][text_sensor:067]: '129_og_aq_version': Sending state '2021.12.3 Jan  9 2022, 12:06:17'
[12:06:52][C][dallas.sensor:032]: Setting up DallasComponent...
[12:06:52][C][wifi:037]: Setting up WiFi...
[12:06:52][V][esp32.preferences:057]: nvs_get_blob('-430349532'): ESP_ERR_NVS_NOT_FOUND - the key might not be set yet
[12:06:52][V][wifi_esp32:039]: Enabling STA.
[12:06:52][V][esp-idf:000]: I (703) wifi:
[12:06:52][V][esp-idf:000]: wifi driver task: 3ffcd9ec, prio:23, stack:3584, core=0
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1661) wifi:
[12:06:52][V][esp-idf:000]: wifi firmware version: dc30037
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1662) wifi:
[12:06:52][V][esp-idf:000]: config NVS flash: enabled
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1674) wifi:
[12:06:52][V][esp-idf:000]: config nano formating: disabled
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1686) wifi:
[12:06:52][V][esp-idf:000]: Init data frame dynamic rx buffer num: 32
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1699) wifi:
[12:06:52][V][esp-idf:000]: Init management frame dynamic rx buffer num: 32
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1712) wifi:
[12:06:52][V][esp-idf:000]: Init management short buffer num: 32
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1725) wifi:
[12:06:52][V][esp-idf:000]: Init dynamic tx buffer num: 32
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1737) wifi:
[12:06:52][V][esp-idf:000]: Init static rx buffer size: 1600
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1749) wifi:
[12:06:52][V][esp-idf:000]: Init static rx buffer num: 16
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1761) wifi:
[12:06:52][V][esp-idf:000]: Init dynamic rx buffer num: 32
[12:06:52]
[12:06:52][V][esp-idf:000]: I (1867) wifi:
[12:06:52][V][esp-idf:000]: mode : sta (58:bf:25:9d:a8:24)
[12:06:52]
[12:06:52][D][WiFiGeneric.cpp:374] _eventCallback(): Event: 0 - WIFI_READY
[12:06:52][D][WiFiGeneric.cpp:374] _eventCallback(): Event: 2 - STA_START
[12:06:52][V][wifi_esp32:460]: Event: WiFi STA start
[12:06:52]Guru Meditation Error: Core  1 panic'ed (Unhandled debug exception)
[12:06:52]Debug exception reason: Stack canary watchpoint triggered (loopTask)
[12:06:52]Core 1 register dump:
[12:06:52]PC      : 0x401215b3  PS      : 0x00060036  A0      : 0x8011cbed  A1      : 0x3ffb0070
[12:06:52]A2      : 0x3ffb8100  A3      : 0x3ffb03b0  A4      : 0x3ffb0294  A5      : 0x00000010
[12:06:52]A6      : 0x00000007  A7      : 0x3ffb02d4  A8      : 0x1b006d37  A9      : 0x3ffb0520
[12:06:52]A10     : 0x3ffb8258  A11     : 0x00000006  A12     : 0x3f403fbe  A13     : 0x000001bd
[12:06:52]A14     : 0x3f4041e9  A15     : 0x00000000  SAR     : 0x00000004  EXCCAUSE: 0x00000001
[12:06:52]EXCVADDR: 0x00000000  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xfffffffe
[12:06:52]
[12:06:52]ELF file SHA256: 0000000000000000
[12:06:52]
[12:06:52]Backtrace: 0x401215b3:0x3ffb0070 0x4011cbea:0x3ffb00a0 0x4011f3ba:0x3ffb03b0 0x4011f3f6:0x3ffb0440 0x400daf91:0x3ffb0480 0x400dafc5:0x3ffb04b0 0x400daff9:0x3ffb0500 0x400db1c1:0x3ffb0520 0x400e7365:0x3ffb0540 0x400e7392:0x3ffb0570 0x400e547d:0x3ffb05d0 0x400e420a:0x3ffb0680 0x400f31f5:0x3ffb06d0 0x400f34c3:0x3ffb07f0 0x400e4329:0x3ffb0900 0x400e4388:0x3ffb0930 0x400e333e:0x3ffb0960 0x401785c9:0x3ffb0a70 0x40178695:0x3ffb0a90 0x400e6701:0x3ffb0ab0 0x400f1787:0x3ffb0b00 0x400fcc3e:0x3ffb1fb0 0x4008a066:0x3ffb1fd0
[12:06:52]
[12:06:52]Rebooting...
