I am trying to update the firmware on my mailbox sensor via OTA. It will not work when powered through the 3.3v pin or VIN pin, but does work when powered via USB power (not attached to a PC).
The error is “ERROR Error receiving acknowledge version: timed out” and is highlighted below along with my code.
I’ve tried the capacitor trick going from the EN pin to GND with all sorts of values and that doesn’t work, so I am at a loss. Any help would be greatly appreciated, thanks.
========================= [SUCCESS] Took 4.00 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.x.xxx
INFO Uploading /data/maibox_sensor/.pioenvs/maibox_sensor/firmware.bin (890992 bytes)
esphome:
platform: ESP32
board: esp32doit-devkit-v1
wifi:
ssid: !secret ssid
fast_connect: true
ap:
ssid: "Maibox Sensor Fallback Hotspot"
password: !secret mailbox_ap_password
# Optional manual IP
manual_ip:
static_ip: 192.168.x.xxx
gateway: 192.168.x.x
subnet: 255.255.255.x
dns1: 192.168.x.x
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret ota_password
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO32
mode: INPUT_PULLDOWN
device_class: opening
- platform: adc
pin: GPIO35
attenuation: 11db
filters:
- offset: -0.19
name: "Mailbox Battery Level"
update_interval: 5s
