Hi guys,
Since the past year, I have been using Home Assistant to automate my lights and fan. I have installed several esp32 along with relay boards to bring the lights online. Recently, the area I reside in has started facing power failures (the power comes back within 30 mins or so). It is alright when this happens during daytime, but during night, I want my fan to kick in (restore its previous state before power failure) immediately upon power restore.
A sample YAML of esp32 being used is posted below:
esphome:
esp32:
board: nodemcu-32s
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "7adEoY6NdYLVUxSraGTgDS16+xvk="
ota:
password: "fcxe751a096886"
wifi:
networks:
- ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.221
gateway: 192.168.1.1
subnet: 255.255.255.0
- ssid: !secret wifi_ssid1
password: !secret wifi_password1
manual_ip:
- ssid: !secret wifi_ssid2
password: !secret wifi_password2
ap:
ssid: "Behind-Wardrobe Fallback Hotspot"
password: "dpWxxTC6o"
captive_portal:
esp32_touch:
setup_mode: false
output:
- platform: gpio
pin: 18
inverted: true
- platform: gpio
pin: 19
inverted: true
- platform: gpio
pin: 25
inverted: true
- platform: gpio
pin: 26
inverted: true
- platform: gpio
pin: 17
inverted: true
- platform: gpio
pin: 16
inverted: true
- platform: gpio
pin: 23
inverted: true
- platform: gpio
pin: 22
inverted: true
light:
- platform: binary
output: "Switch_1"
- platform: binary
output: "Switch_2"
name: "Behind wall Plug"
restore_mode: restore_default_on
internal: True
- platform: binary
output: "Switch_3"
- platform: binary
output: "Switch_4"
- platform: binary
output: "Switch_5"
disabled_by_default: true
- platform: binary
output: "Switch_6"
name: "Four Spotlights"
- platform: binary
output: "Switch_7"
internal: false
- platform: binary
output: "Switch_8"
name: "Side Mirror LED"
internal: True
binary_sensor:
- platform: esp32_touch
name: "ESP32 Touch Pad PIN 13"
pin: 13
internal: true
threshold: 500
on_press:
then:
- light.turn_on:
on_release:
then:
- delay: 1000ms
- light.turn_off:
name: "ESP32 Touch Pad PIN 14"
pin: 14
internal: true
threshold: 500
on_press:
then:
- light.turn_on:
on_release:
then:
- delay: 1000ms
- light.turn_off:
name: "ESP32 Touch Pad PIN 27"
pin: 27
internal: true
threshold: 500
on_press:
then:
- light.turn_on:
on_release:
then:
- delay: 1000ms
- light.turn_off:
name: "ESP32 Touch Pad PIN 33"
pin: 33
internal: true
threshold: 500
on_press:
then:
- light.turn_on:
on_release:
then:
- delay: 1000ms
- light.turn_off:
Could someone kindly guide me through this. Thanks in advance
