For some reason my ESP-board keeps failing connecting to the WiFi and it keeps getting problems with the OTA.
And when its finaly is connected, i can ping the ESP32, it respons. but going to the IP does notting.
Code:
esphome:
platform: ESP32
board: nodemcu-32s
libraries:
- EEPROM
- SPI
- [email protected]
- [email protected]
includes:
- somfy_secrets.h
- somfy_cover.h
wifi:
ssid: !secret wifi_ssid
power_save_mode: none
ap:
ssid: !secret fallback_ssid
password: !secret fallback_password
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: !secret ota_password
web_server:
port: 80
- platform: uptime
- platform: wifi_signal
name: "WiFi Signal Sensor"
cover:
- platform: custom
lambda: |-
auto somfy_remote = new SomfyESPRemote();
somfy_remote->add_cover("somfyTine", "badezimmer", SOMFY_REMOTE_BADEZIMMER);
somfy_remote->add_cover("somfyJohn", "kinderzimmer", SOMFY_REMOTE_KINDERZIMMER);
App.register_component(somfy_remote);
return somfy_remote->covers;
covers:
- id: "somfyTine"
name: "Somfy Cover Tine"
- id: "somfyJohn"
name: "Somfy Cover John"
- id: "somfySamen"
name: "Somfy Cover Samen"
switch:
turn_on_action:
- lambda: |-
((SomfyESPCover*)id(somfyTine))->program();
turn_on_action:
- lambda: |-
((SomfyESPCover*)id(somfyTine))->make_call().set_command_stop();
turn_on_action:
- lambda: |-
((SomfyESPCover*)id(somfyJohn))->program();
turn_on_action:
- lambda: |-
((SomfyESPCover*)id(somfyJohn))->make_call().set_command_stop();
turn_on_action:
- lambda: |-
((SomfyESPCover*)id(somfySamen))->program();
turn_on_action:
- lambda: |-
((SomfyESPCover*)id(somfySamen))->make_call().set_command_stop();
And log:
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
[I][logger:258]: Log initialized
[C][ota:469]: There have been 0 suspected unsuccessful boot attempts.
[D][esp32.preferences:113]: Saving 1 preferences to flash...
[D][esp32.preferences:142]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x401566e2 PS : 0x00060830 A0 : 0x800e1ddb A1 : 0x3ffb26d0
A2 : 0xbaad567c A3 : 0x3ffb27a4 A4 : 0x3f40363a A5 : 0x0000ff00
A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x801566d7 A9 : 0x3ffb26b0
A10 : 0x3ffb2fd0 A11 : 0x3f403629 A12 : 0x00000011 A13 : 0x00000001
A14 : 0x00000003 A15 : 0x00060023 SAR : 0x00000008 EXCCAUSE: 0x0000001c
EXCVADDR: 0xbaad567c LBEG : 0x40089285 LEND : 0x400892a7 LCOUNT : 0x00000000
Backtrace:0x401566df:0x3ffb26d00x400e1dd8:0x3ffb2700 0x400e37a1:0x3ffb2720 0x400ee592:0x3ffb2820
ELF file SHA256: 0000000000000000
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805e4
[C][ota:469]: There have been 1 suspected unsuccessful boot attempts.
A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x00000008 EXCCAUSE: 0x0000001c
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 2 suspected unsuccessful boot attempts.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 3 suspected unsuccessful boot attempts.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 4 suspected unsuccessful boot attempts.
A10 : 0x3ffb3060 A11 : 0x3f403629 A12 : 0x00000011 A13 : 0x00000001
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 5 suspected unsuccessful boot attempts.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 6 suspected unsuccessful boot attempts.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 7 suspected unsuccessful boot attempts.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 8 suspected unsuccessful boot attempts.
A14 : 0x00000001 A15 : 0x3ffb08c0 SAR : 0x00000008 EXCCAUSE: 0x0000001c
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 9 suspected unsuccessful boot attempts.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 10 suspected unsuccessful boot attempts.
[E][ota:476]: Boot loop detected. Proceeding to safe mode.
[I][app:029]: Running through setup()...
[C][wifi:037]: Setting up WiFi...
[C][wifi:038]: Local MAC: C8:F0:9E:74:24:64
[D][wifi:386]: Starting scan...
[D][wifi:401]: Found networks:
[I][wifi:445]: - 'WiFi' (B4:B0:24:DE:3C:CC) [redacted]▂▄▆█
[D][wifi:446]: Channel: 11
[D][wifi:447]: RSSI: -73 dB
[I][wifi:445]: - 'WiFi' (D8:0D:17:E5:E1:E0) [redacted]▂▄▆█
[D][wifi:447]: RSSI: -75 dB
[D][wifi:450]: - ''[redacted] (BA:B0:24:DE:3C:CC) [redacted]▂▄▆█
[D][wifi:450]: - ''[redacted] (DE:0D:17:E5:E1:E0) [redacted]▂▄▆█
[D][wifi:450]: - '~ Home ~'[redacted] (DC:53:7C:83:90:76) [redacted]▂▄▆█
[D][wifi:450]: - 'TelenetWiFree'[redacted] (06:53:7C:83:90:79) [redacted]▂▄▆█
[D][wifi:450]: - '~ Home ~'[redacted] (1C:64:99:B0:02:2C) [redacted]▂▄▆█
[D][wifi:450]: - 'Proximus-Home-5F70'[redacted] (20:9A:7D:92:5F:76) [redacted]▂▄▆█
[D][wifi:450]: - 'telenet-86D4747'[redacted] (DC:53:7C:AF:38:C1) [redacted]▂▄▆█
[D][wifi:450]: - 'SUN2000-HV2263408472'[redacted] (98:3F:60:D8:BD:C8) [redacted]▂▄▆█
[D][wifi:450]: - 'TelenetWiFree'[redacted] (DE:53:3C:AF:38:C1) [redacted]▂▄▆█
[D][wifi:450]: - '~ Home ~'[redacted] (C8:D1:2A:05:8C:D8) [redacted]▂▄▆█
[D][wifi:450]: - 'SUN2000-HV2250274671'[redacted] (14:AB:02:26:3C:2D) [redacted]▂▄▆█
[D][wifi:450]: - 'WiFi-2.4-2763'[redacted] (F8:1A:67:A9:0D:78) [redacted]▂▄▆█
[D][wifi:450]: - 'DIRECT-oQC43x Series'[redacted] (86:25:19:0E:69:76) [redacted]▂▄▆█
[I][wifi:257]: WiFi Connecting to 'WiFi'...
[W][wifi_esp32:494]: Event: Disconnected ssid='WiFi' bssid=B4:B0:24:DE:3C:CC[redacted] reason='Authentication Failed'
[W][wifi:570]: WiFi Unknown connection status 0
[W][wifi_esp32:494]: Event: Disconnected ssid='WiFi' bssid=B4:B0:24:DE:3C:CC[redacted] reason='Association Leave'
[D][wifi:447]: RSSI: -78 dB
[W][wifi:513]: Incomplete connection.
[W][wifi_esp32:494]: Event: Disconnected ssid='WiFi' bssid=D8:0D:17:E5:E1:E0[redacted] reason='Authentication Failed'
[W][wifi:565]: Connecting to WiFi network failed. Are the credentials wrong?
[D][wifi:447]: RSSI: -74 dB
[D][wifi:447]: RSSI: -80 dB
[W][wifi:585]: Restarting WiFi adapter...
[D][wifi:447]: RSSI: -72 dB
[I][wifi:141]: Starting fallback AP!
[C][wifi:210]: Setting up AP...
[C][wifi:212]: AP SSID: 'Wifi Fallback Hotspot'
[C][wifi:213]: AP Password: 'StH4vi7456Sb'
[C][wifi:222]: IP Address: 192.168.4.1
[D][wifi:447]: RSSI: -79 dB
[D][wifi:447]: RSSI: -76 dB
