Esp32 s2 dht22 wrong readings, works after reset
have som issue whit esp32 s2, and dht22
on cold start i do get wrong readings
typical a few degrees c och low rf
efter reset och uppdate it gives the right readings
standard
  • platform: dht
    pin: GPIO1
    temperature:
    humidity:
    update_interval: 10s
have tryed it on several esp32, and diffrent batches om dht22
any help of what this be?
Gpio1 is not “normal” pin, it’s uart TX pin, debug output at boot. Try with Gpio4 for example.
Also try adding the model to the config. Sometimes auto detection is a bit flaky.
  model: DHT22 # or DHT22_TYPE2
thanks, autodetect was the problem, model it all ok
did change pin to, but it wasent that, but i should not be using that anyway
