ESP32-S2 Feather w/ MBE280 doesn't work beyond 2024.8.1
I am using the Adafruit ESP32-S2 Feather with integrated MBE280 sensor to measure pressure and temperature.
Everything works fine with ESPHome 2024.8.1.
But when I tried to update to 2024.10.? I would get no data back. The device is still on-line and I can control the on board GPIO LED, but there is apparently no I2C data.
I restored the 2024.8.1 and tried again with 2024.11.3. The same problem, no sensor data.
Any suggestions?
Here is my configuration:
esphome:
  friendly_name: Feather_BME280
  platformio_options:
    board_build.variant: um_feathers2
esp32:
  board: featheresp32-s2
  variant: esp32s2
  framework:
    type: esp-idf
    version: recommended
# Enable logging
# Enable Home Assistant API
ota:
wifi:
captive_portal:
switch:
  - platform: gpio
    restore_mode: ALWAYS_ON
    pin: 7
    setup_priority: 801
  - platform: gpio
    pin: 13
i2c:
  sda: GPIO3
  scl: GPIO4
  # scan: true
  frequency: 200kHz
  setup_priority: 700
  - platform: uptime
    update_interval: 10s
  - platform: bme280_i2c
    i2c_id: stemma
    temperature:
      name: "BME280 Temperature"
      oversampling: 16x
      filters:
        - offset: -6.2
        - sliding_window_moving_average:
            window_size: 12
            send_every: 6
    pressure:
      name: "BME280 Pressure"
      oversampling: 16x
      unit_of_measurement: "hPa"
      accuracy_decimals: 1
      filters:
        - offset: 26.7
            window_size: 6
            send_every: 6
    humidity:
      name: "BME280 Humidity"
      oversampling: 16x
      filters:
        - multiply: 1.19
        - offset: 6.0
            window_size: 6
            send_every: 6
    address: 0x77
    update_interval: 60s
Log?
Are you asking for a log of programming or log of operation?
I just tried with 12.2. Still no luck. The log seems too big to post, so here is the end:
RAM:   [=         ]   9.6% (used 31396 bytes from 327680 bytes)
Flash: [=====     ]  50.6% (used 929182 bytes from 1835008 bytes)
Building .pioenvs/feather-bme280/firmware.bin
Creating esp32s2 image...
Successfully created esp32s2 image.
esp32_create_combined_bin([".pioenvs/feather-bme280/firmware.bin"], [".pioenvs/feather-bme280/firmware.elf"])
Wrote 0xf2f10 bytes to file /data/build/feather-bme280/.pioenvs/feather-bme280/firmware.factory.bin, ready to flash to offset 0x0
esp32_copy_ota_bin([".pioenvs/feather-bme280/firmware.bin"], [".pioenvs/feather-bme280/firmware.elf"])
======================== [SUCCESS] Took 393.97 seconds ========================
INFO Successfully compiled program.
INFO Connecting to 192.168.128.99 port 3232...
INFO Connected to 192.168.x.x
INFO Uploading /data/build/feather-bme280/.pioenvs/feather-bme280/firmware.bin (929552 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 4.69 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.128.99 using esphome API
INFO Successfully connected to feather-bme280 @ 192.168.128.99 in 5.162s
INFO Successful handshake with feather-bme280 @ 192.168.128.99 in 0.079s
[14:05:11][I][app:100]: ESPHome version 2024.12.2 compiled on Dec 21 2024, 14:02:37
[14:05:11][C][wifi:600]: WiFi:
[14:05:11][C][wifi:428]:   Local MAC:
[14:05:11][C][wifi:433]:   SSID: [redacted]
[14:05:11][C][wifi:436]:   IP Address: 192.168.x.x
[14:05:11][C][wifi:439]:   BSSID: [redacted]
[14:05:11][C][wifi:441]:   Hostname: 'feather-bme280'
[14:05:11][C][wifi:443]:   Signal strength: -46 dB ▂▄▆█
[14:05:11][C][wifi:447]:   Channel: 10
[14:05:11][C][wifi:448]:   Subnet: 255.255.255.0
[14:05:11][C][wifi:449]:   Gateway: 192.168.x.1
[14:05:11][C][wifi:450]:   DNS1: 192.168.x.1
[14:05:11][C][wifi:451]:   DNS2: 0.0.0.0
[14:05:11][C][logger:185]: Logger:
[14:05:11][C][logger:186]:   Level: DEBUG
[14:05:11][C][logger:188]:   Log Baud Rate: 115200
[14:05:11][C][logger:189]:   Hardware UART: USB_CDC
[14:05:11][C][switch.gpio:068]: GPIO Switch 'power_on'
[14:05:11][C][switch.gpio:090]:   Restore Mode: always ON
[14:05:11][C][switch.gpio:031]:   Pin: GPIO7
[14:05:11][C][switch.gpio:068]: GPIO Switch 'LED'
[14:05:11][C][switch.gpio:090]:   Restore Mode: always OFF
[14:05:11][C][switch.gpio:031]:   Pin: GPIO13
[14:05:11][C][uptime.sensor:033]: Uptime Sensor 'up'
[14:05:11][C][uptime.sensor:033]:   Device Class: 'duration'
[14:05:11][C][uptime.sensor:033]:   State Class: 'total_increasing'
[14:05:11][C][uptime.sensor:033]:   Unit of Measurement: 's'
[14:05:11][C][uptime.sensor:033]:   Accuracy Decimals: 0
[14:05:11][C][uptime.sensor:033]:   Icon: 'mdi:timer-outline'
[14:05:11][C][uptime.sensor:034]:   Type: Seconds
[14:05:11][C][i2c.idf:075]: I2C Bus:
[14:05:11][C][i2c.idf:076]:   SDA Pin: GPIO3
[14:05:11][C][i2c.idf:077]:   SCL Pin: GPIO4
[14:05:11][C][i2c.idf:078]:   Frequency: 200000 Hz
[14:05:11][C][i2c.idf:084]:   Recovery: bus successfully recovered
[14:05:11][I][i2c.idf:094]: Results from i2c bus scan:
[14:05:11][I][i2c.idf:100]: Found i2c device at address 0x36
[14:05:11][I][i2c.idf:100]: Found i2c device at address 0x77
[14:05:11][C][bme280_i2c.sensor:025]:   Address: 0x77
[14:05:11][C][bme280.sensor:182]: BME280:
[14:05:11][C][bme280.sensor:194]:   IIR Filter: OFF
[14:05:11][C][bme280.sensor:195]:   Update Interval: 60.0s
[14:05:11][C][bme280.sensor:197]:   Temperature 'BME280 Temperature'
[14:05:11][C][bme280.sensor:197]:     Device Class: 'temperature'
[14:05:11][C][bme280.sensor:197]:     State Class: 'measurement'
[14:05:11][C][bme280.sensor:197]:     Unit of Measurement: '°C'
[14:05:11][C][bme280.sensor:197]:     Accuracy Decimals: 1
[14:05:11][C][bme280.sensor:198]:     Oversampling: 16x
[14:05:11][C][bme280.sensor:199]:   Pressure 'BME280 Pressure'
[14:05:11][C][bme280.sensor:199]:     Device Class: 'pressure'
[14:05:11][C][bme280.sensor:199]:     State Class: 'measurement'
[14:05:11][C][bme280.sensor:199]:     Unit of Measurement: 'hPa'
[14:05:11][C][bme280.sensor:199]:     Accuracy Decimals: 1
[14:05:11][C][bme280.sensor:200]:     Oversampling: 16x
[14:05:11][C][bme280.sensor:201]:   Humidity 'BME280 Humidity'
[14:05:11][C][bme280.sensor:201]:     Device Class: 'humidity'
[14:05:11][C][bme280.sensor:201]:     State Class: 'measurement'
[14:05:11][C][bme280.sensor:201]:     Unit of Measurement: '%'
[14:05:11][C][bme280.sensor:201]:     Accuracy Decimals: 1
[14:05:11][C][bme280.sensor:202]:     Oversampling: 16x
[14:05:11][C][captive_portal:089]: Captive Portal:
[14:05:11][D][sensor:093]: 'up': Sending state 7.24300 s with 0 decimals of accuracy
[14:05:11][C][mdns:116]: mDNS:
[14:05:11][C][mdns:117]:   Hostname: feather-bme280
[14:05:11][C][esphome.ota:073]: Over-The-Air updates:
[14:05:11][C][esphome.ota:074]:   Address: feather-bme280.local:3232
[14:05:11][C][esphome.ota:075]:   Version: 2
[14:05:11][C][esphome.ota:078]:   Password configured
[14:05:11][C][safe_mode:018]: Safe Mode:
[14:05:11][C][safe_mode:019]:   Boot considered successful after 60 seconds
[14:05:11][C][safe_mode:021]:   Invoke after 10 boot attempts
[14:05:11][C][safe_mode:022]:   Remain in safe mode for 300 seconds
[14:05:11][C][api:140]: API Server:
[14:05:11][C][api:141]:   Address: feather-bme280.local:6053
[14:05:11][C][api:143]:   Using noise encryption: YES
[14:05:11][D][api:103]: Accepted 192.168.128.81
[14:05:11][D][api.connection:1446]: Home Assistant 2024.12.5 (192.168.128.81): Connected successfully
[14:05:21][D][sensor:093]: 'up': Sending state 17.24400 s with 0 decimals of accuracy
[14:05:31][D][sensor:093]: 'up': Sending state 27.24600 s with 0 decimals of accuracy
[14:05:41][D][sensor:093]: 'up': Sending state 37.24600 s with 0 decimals of accuracy
