I have a defective ESP32 -S2-Saola-1 Devkit and now need a replacement.
In Germany I can currently only find the ESP32 Wroom version.
Are the pin-outs and the design the same?
I have the ESP32-S2 Saola on a circuit board and would like to be able to continue using the old wiring and my ESPhome code.
The old ESP32-S2 Saola works somehow, but I don’t get a signal. If I connect it to the USB port directly on my PC, it can’t be found either.
Thanks ,
I know this documentation. I’m just trying to find the right one because the ESP-S2-saola-1 is probably no longer being produced.
So there must be some kind of suitable replacement.
I’ve currently come across the ESP32-S2-mini-1 or the ESP32-S2-DevKit-N4R2. I think both of them should fit… I’m not interested in flash or RAM memory, just the same pin-outs, at least those that I can use as GPIOs. I have it plugged into a circuit board. If that doesn’t fit, I’ll have to throw away the whole circuit board
great,
I found it thanks to your links, but I wasn’t entirely sure. Since I couldn’t find enough information like a data sheet from my dealer here in Germany… to be on the safe side, I ordered the
ESP32-S2-DEVKITM-1-N4R2
and the
ESP32-S2-DEVKITM-1
I think the only difference between them is the RAM and flash memory size
That sucks! You might find some headers with 2.54mm offset.
The component you pointed is 3.3V voltage regulator. If that is the only damaged component you can still power Esp directly from 3.3V pin with external 3.3V source.
But it also means you probably have something wrong on your circuit board. Either drawing too much current or power supply problem. Those voltage regulators are quite robust if not abused.
