in this page has a sample:
image:
- file: https://esphome.io/_images/logo.png
resize: 200x162
Compiling in Synology Nas/ova VM/Home Assistant 2024.7.3 + ESPHome 2024.7.1
image:
Don’t attach screenshots (especially truncated ones!), copy and paste the text. What you added there is no help, since it doesn’t show where you’re trying to use the image.
I think the screenshot says more. I don’t want to share the whole yaml, it’s still under development, it might confuse others. Here, too, the image component is clearly visible, which is inserted according to the rules.
I’m going step by step. do you mean that the error could also be because the image is just inserted, but not used anywhere?
Your picture of the compile error discussion looks almost exactly like the picture that was shown in the posting that I linked to above. So, just to verify, did you follow that link and did you “Clean Build Files”?
Also, in order for Clyde to help you (its amazing that he is doing all of this work on the code and taking time to help us as well!), he needs code that shows your issue but has all of the extra stuff that no one wants to see (esp_modus, abb_ev, etc) removed so that it only focuses on the problem. For example, below is working code that will compile and shows a picture of a cat (assuming the picture is in you esphome folder) but nothing else (as for why the cat is drawn in black and white on the display… heck if I know).
esphome:
friendly_name: Largedisplay
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
board_build.arduino.memory_type: qio_opi
board_build.flash_mode: dio
board_upload.maximum_ram_size: 524288
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
CONFIG_ESP32S3_DATA_CACHE_64KB: y
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
external_components:
- source: github://pr#6363
refresh: 0min
components: [lvgl]
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
level: DEBUG
i2c:
sda: GPIO08
scl: GPIO09
scan: True
display:
- platform: rpi_dpi_rgb
auto_clear_enabled: false
update_interval: never
color_order: RGB
pclk_frequency: 14MHz
dimensions:
width: 800
height: 480
de_pin:
number: 5
hsync_pin:
number: 46
ignore_strapping_warning: true
vsync_pin:
number: 3
pclk_pin: 7
pclk_inverted: false
hsync_back_porch: 10 #30
hsync_front_porch: 20 #210
hsync_pulse_width: 10 #30
vsync_back_porch: 10 #4
vsync_front_porch: 10 #4
vsync_pulse_width: 10 #4
data_pins:
red:
- 1 #r3
- 2 #r4
- 42 #r5
- 41 #r6
- 40 #r7
blue:
- 14 #b3
- 38 #b4
- 18 #b5
- 17 #b6
- 10 #b7
green:
- 39 #g2
- 0 #g3
- 45 #g4
- 48 #g5
- 47 #g6
- 21 #g7
font:
- file: "gfonts://Roboto"
image:
- file: "test.jpg"
resize: 480x480
- file: "cat.png"
resize: 69x86
resize: 200x162
touchscreen:
platform: gt911
interrupt_pin: GPIO4
on_touch:
- lambda: |-
ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
lvgl:
displays:
- display_id: my_display
buffer_size: 25%
touchscreens:
- touchscreen_id: my_touchscreen
pages:
- id: image_page
widgets:
- img:
align: CENTER
src: my_cat_image
radius: 11
clip_corner: true
# Enable Home Assistant API
api:
encryption:
key: "<redacted>"
ota:
- platform: esphome
password: "<redacted>"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "<redacted>"
captive_portal:
The default image type is binary, I.e. monochrome. type: RGB565
will get you colours.
Now the code compoled. But the image not visible. The midea4.png is next to e.yaml in esphome folder
substitutions:
lightbulb: "\U000F0335"
ceiling_light: "\U000F0769"
floor_lamp: "\U000F08DD"
string_lights: "\U000F12BA"
esphome:
friendly_name: Home Display
platformio_options:
esp32:
variant: esp32s3
framework:
type: esp-idf
sdkconfig_options:
api:
ota:
- platform: esphome
wifi:
networks:
- ssid: !secret wifi_ssid
web_server:
port: 80
- source:
type: git
url: https://github.com/clydebarrow/esphome
ref: 82264dc2440981873b8400d613e0cc32d229daa3 #previous commit - wont be needed in the future
components: [lvgl]
psram:
mode: octal
speed: 80MHz
logger:
level: DEBUG
i2c:
sda: GPIO08
scl: GPIO09
scan: True
uart:
- id: mod_bus
tx_pin: GPIO16
rx_pin: GPIO15
baud_rate: 9600
parity: EVEN
stop_bits: 1
data_bits: 8
modbus:
uart_id: mod_bus
modbus_controller:
- id: "esp_modbus"
address: 0x1
modbus_id: heatpump_modbus
setup_priority: -10
update_interval: 10s
- id: "abb_ev"
address: 0x1
setup_priority: -10
image:
- file: "midea4.png"
resize: 400x600
display:
color_order: RGB
dimensions:
width: 800
height: 480
de_pin:
number: 5
hsync_pin:
number: 46
vsync_pin:
number: 3
pclk_pin: 7
data_pins:
red:
- 1
- 2
- 42
- 41
- 40
blue:
- 14
- 38
- 18
- 17
- 10
green:
- 39
- 0
- 45
- 48
- 47
- 21
font:
bpp: 4
extras:
- file: 'fonts/materialdesignicons-webfont.ttf' # http://materialdesignicons.com/cdn/7.4.47/
glyphs: [
"\U000F004B",
"\U0000f0ed",
"\U000F006E",
"\U000F012C",
"\U000F179B",
"\U000F0748",
"\U000F1A1B",
"\U000F02DC",
"\U000F0A02",
"\U000F035F",
"\U000F0156",
"\U000F0C5F",
"\U000f0084",
"\U000f0091",
"\U000F0335",
bpp: 4
glyphs: &mdi-weather-glyphs
- "\U000F0590" # mdi-weather-cloudy
- "\U000F0F2F" # mdi-weather-cloudy-alert
- "\U000F0E6E" # mdi-weather-cloudy-arrow-right
- "\U000F0591" # mdi-weather-fog
- "\U000F0592" # mdi-weather-hail
- "\U000F0F30" # mdi-weather-hazy
- "\U000F0898" # mdi-weather-hurricane
- "\U000F0593" # mdi-weather-lightning
- "\U000F067E" # mdi-weather-lightning-rainy
- "\U000F0594" # mdi-weather-clear-night
- "\U000F0F31" # mdi-weather-night-partly-cloudy
- "\U000F0595" # mdi-weather-partly-cloudy
- "\U000F0F32" # mdi-weather-partly-lightning
- "\U000F0F33" # mdi-weather-partly-rainy
- "\U000F0F34" # mdi-weather-partly-snowy
- "\U000F0F35" # mdi-weather-partly-snowy-rainy
- "\U000F0596" # mdi-weather-pouring
- "\U000F0597" # mdi-weather-rainy
- "\U000F0598" # mdi-weather-snowy
- "\U000F0F36" # mdi-weather-snowy-heavy
- "\U000F067F" # mdi-weather-snowy-rainy
- "\U000F0599" # mdi-weather-sunny
- "\U000F0F37" # mdi-weather-sunny-alert
- "\U000F14E4" # mdi-weather-sunny-off
- "\U000F059A" # mdi-weather-sunset
- "\U000F059B" # mdi-weather-sunset-down
- "\U000F059C" # mdi-weather-sunset-up
- "\U000F0F38" # mdi-weather-tornado
- "\U000F059D" # mdi-weather-windy
- "\U000F059E" # mdi-weather-windy-variant
bpp: 4
glyphs: [
"\U000F0335", # mdi-lightbulb
"\U000F0769", # mdi-ceiling-light
"\U000F08DD", # mdi-floor-lamp
"\U000F12BA", # mdi-string-lights
bpp: 4
touchscreen:
platform: gt911
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
- platform: wifi_signal
update_interval: 60s
entity_category: diagnostic
internal: true
- platform: copy
source_id: wifi_signal_db
name: "WiFi Strength"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
- platform: modbus_controller
modbus_controller_id: "abb_ev"
name: "ABB Import energy total"
address: 0x5000
register_type: holding
value_type: U_QWORD
device_class: "energy"
unit_of_measurement: "kWh"
accuracy_decimals: 4
state_class: "total_increasing"
filters:
- multiply: 0.0001
modbus_controller_id: abb_ev
name: "ABB Voltage L1-N"
address: 0x5B00
value_type: U_DWORD
accuracy_decimals: 1
device_class: voltage
unit_of_measurement: "V"
filters:
- multiply: 0.1
name: "ABB Power total"
address: 0x5B14
value_type: S_DWORD
accuracy_decimals: 2
device_class: power
unit_of_measurement: "W"
filters:
- multiply: 0.01
text_sensor:
- platform: wifi_info
ip_address:
ssid:
mac_address:
# LVGL Buttons
lvgl:
displays:
touchscreens:
on_idle:
- timeout: 10s
then:
- logger.log: idle timeout
- if:
condition:
lvgl.is_idle:
timeout: 5s
then:
- logger.log: LVGL is idle
- timeout: 15s
then:
- logger.log: idle 15s timeout
style_definitions:
- id: style_line
line_color: 0x0000FF
line_width: 8
line_rounded: true
- id: date_style
text_font: roboto24
align: center
text_color: 0x333333
bg_opa: cover
radius: 4
pad_all: 2
theme:
btn:
text_font: roboto24
scroll_on_focus: true
group: general
radius: 25
width: 150
height: 109
pad_left: 10px
pad_top: 10px
pad_bottom: 10px
pad_right: 10px
shadow_width: 0
bg_color: 0x313131
text_color: 0xB6B6B6
checked:
bg_color: 0xCC5E14
page_wrap: true
pages:
- id: main_page
skip: true
layout:
type: flex
flex_flow: column_wrap
width: 100%
bg_color: 0x000000
bg_opa: cover
pad_all: 5
widgets:
- btn:
height: 223
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Kitchen"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Outdoor"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $floor_lamp
- label:
align: bottom_left
text: "Living Room"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Accent"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Bed Room"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "00:00am"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Fan"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Timer"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Lamp"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Wall Spot"
long_mode: dot
- btn:
checkable: true
widgets:
- label:
text_font: roboto24
align: top_left
text: $lightbulb
- label:
align: bottom_left
text: "Driveway"
long_mode: dot
- btn:
widgets:
- label:
align: center
text: "Go to Page 2"
on_click:
then:
- lvgl.page.show: page2
- btn:
widgets:
- label:
align: center
text: "Go to Page 3"
on_click:
then:
- lvgl.page.show: page3
- id: page2
skip: true
layout:
type: flex
width: 100%
bg_color: 0x000000
bg_opa: cover
pad_all: 5
widgets:
- btn:
widgets:
- label:
align: center
text: "Go to Main Page"
text_font: roboto10
on_click:
then:
- lvgl.page.show: main_page
- label:
text: "ABB Import Energy: 0 kWh"
text_font: roboto24
text_color: 0xFFFFFF
align: top_right
- label:
text: "ABB Voltage L1-N"
text_font: roboto24
align: top_right
- meter:
align: center
scales:
- range_from: 0
range_to: 10000
angle_range: 240
rotation: 150
ticks:
count: 11
length: 10
major:
stride: 1000
length: 13
label_gap: 13
indicators:
- line:
width: 2
color: 0xFF0000
r_mod: -4
- tick_style:
start_value: 0
end_value: 5000
color_start: 0x0000bd
color_end: 0xbd0000
- id: page3
skip: true
layout:
type: flex
width: 100%
bg_color: 0x000000
bg_opa: cover
pad_all: 5
widgets:
- img:
align: CENTER
src: midea_logo
radius: 11
clip_corner: true
- btn:
widgets:
- label:
align: center
text_font: roboto10
on_click:
then:
# - label:
# id: abb_import_energy_label2
# text: "ABB Import Energy: 0 kWh"
# text_font: roboto24
# text_color: 0xFFFFFF
# align: top_right
# - label:
# id: abb_voltage_l1_n_label2
# text: "ABB Voltage L1-N"
# align: top_right
# - meter:
# id: abb_power_meter2
# align: center
# scales:
# - range_from: 0
# range_to: 10000
# angle_range: 240
# rotation: 150
# ticks:
# count: 11
# length: 10
# major:
# stride: 1000
# length: 13
# label_gap: 13
# indicators:
# - line:
# id: abb_power_needle2
# width: 2
# color: 0xFF0000
# r_mod: -4
# - tick_style:
# start_value: 0
# end_value: 5000
# color_start: 0x0000bd
# color_end: 0xbd0000
interval:
- interval: 20s
then:
- lambda: |-
char buffer_energy[64];
snprintf(buffer_energy, sizeof(buffer_energy), "ABB Import Energy: %.4f kWh", id(abb_import_energy_total).state);
lv_label_set_text(id(abb_import_energy_label), buffer_energy);
char buffer_voltage[64];
snprintf(buffer_voltage, sizeof(buffer_voltage), "ABB Voltage L1-N: %.1f V", id(abb_voltage_l1_n).state);
lv_label_set_text(id(abb_voltage_l1_n_label), buffer_voltage);
You Cleaned the build files, didn’t you
Clyde answered that one already (Thank you BTW!).
I had the same issue as you with the logo image below not being visible until I followed Clyde’s comment above and included type: RGB565
resize: 200x162
Now, for your specific issue, change
image:
resize: 400x600
to the following and it should work.
image:
resize: 400x600
type: RGB565
From the display component page:
type (Optional): Specifies how to encode image internally. Defaults to BINARY for local images and TRANSPARENT_BINARY for MDIs.
BINARY: Two colors, suitable for 1 color displays or 2 color image in color displays. Uses 1 bit per pixel, 8 pixels per byte.
TRANSPARENT_BINARY: One color, any pixel that is fully transparent will not be drawn, and any other pixel will be the on color. Uses 1 bit per pixel, 8 pixels per byte.
GRAYSCALE: Full scale grey. Uses 8 bits per pixel, 1 pixel per byte.
RGB565: Lossy RGB color stored. Uses 2 bytes per pixel.
RGB24: Full RGB color stored. Uses 3 bytes per pixel.
RGBA: Full RGB color stored. Uses 4 bytes per pixel. Any pixel with an alpha value < 127 will not be drawn.
Oh, I get it!
Thank you! You can see that I struggle a lot with the language barrier, but I managed.
the disp_bg_image: is use the ismage all pages?
If i need background only one page, it is possible?
Yes you can set that on a per page basis.
can you show me a sample for this? I have not been successful so far.
Is there any way to show percent battery left? I can’t find any information about a GPIO being dedicated to the battery input.
Anyone have any luck getting deepsleep to work with touch screen wake?
I too would like to know this.
clydebarrow!
Please help me, the individual background question!
Just add the image to the page as the first object.
is there any way to control the LEDs on ESP32? (or any GPIO)
