ESP32-S3 Adafruit PDM MEMS Microphone Breakout
Hi there,
I’m playing around with the Adafruit PDM MEMS Microphone Breakout and ESP32-S3, but can’t get it working. As far as I was able to find out, The i2s can be assignet to every avaible GPIO on the S3. But I can’t see anything in logs. Here is my yaml:
substitutions:
  board: esp32-s3-devkitc-1
  friendly_name: ESP32 S3 Mic
  sclk_pin: GPIO41 # MP34DT01 SEL
  bclk_pin: GPIO40 # MP34DT01 CLK
  din_pin: GPIO39  # MP34DT01 DAT
esphome:
  friendly_name: ${friendly_name}
esp32:
  board: ${board}
  framework:
    type: arduino
#    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "ycJWxK4CJUtf722n4d0kunETziWAZp6rpObngZlx+XU="
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "${friendly_name} Fallback Hotspot"
captive_portal:
i2s_audio:
  i2s_lrclk_pin: ${sclk_pin} # MP34DT01  SEL
  i2s_bclk_pin: ${bclk_pin}  # MP34DT01  CLK
microphone:
  - platform: i2s_audio
    i2s_din_pin: ${din_pin} # MP34DT01  DAT
    adc_type: external
    pdm: true
voice_assistant:
  microphone: mic_i2s
#  media_player: media_player_speaker
  noise_suppression_level: 2
  use_wake_word: false
  auto_gain: 31dBFS
  volume_multiplier: 4.0
  on_listening:
    - light.turn_on:
        effect: "Scan"
        red: 0%
        green: 50%
        blue: 93%
  on_stt_vad_end:
    - light.turn_on:
        effect: "Rainbow"
  on_wake_word_detected:
    - light.turn_on:
  on_stt_end:
    - light.turn_on:
        effect: "Rainbow"
  on_end:
    - delay: 100ms
    - light.turn_off:
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: "Fast Pulse"
    - if:
        condition:
          switch.is_on: use_wake_word
        then:
          - switch.turn_off: use_wake_word
          - delay: 1sec
          - switch.turn_on: use_wake_word
  on_client_connected:
    - if:
        condition:
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
binary_sensor:
  - platform: status
    name: API Connection
    filters:
      - delayed_on: 1s
    on_press:
      - if:
          condition:
          then:
    on_release:
      - if:
          condition:
          then:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
      - script.execute: reset_led
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
    name: Use Listen Light
    optimistic: true
    on_turn_on:
    on_turn_off:
light:
  - platform: neopixelbus
    type: grb
    pin: GPIO14      # DIN pin of the LED Strip
    num_leds: 8      # change the Number of LEDS according to your LED Strip.
    variant: ws2812x
    default_transition_length: 0.5s
    effects:
      - addressable_scan:
          move_interval: 50ms
          scan_width: 2
      - addressable_rainbow:
          speed: 10
          width: 50
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
          max_brightness: 100%
script:
  - id: reset_led
    then:
      - if:
          condition:
            - switch.is_on: use_wake_word
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                red: 100%
                green: 89%
                blue: 71%
                brightness: 60%
                effect: none
          else:
            - light.turn_off: led_light
Also The LED Ring doesn’t light up. Same code, on esp32-wroom works with diffrent Pin mapping:
substitutions:
  board: esp32dev
  friendly_name: esp32-mic-speaker
  sclk_pin: GPIO23 # MSM261S4030H0 WS
  bclk_pin: GPIO22 # MSM261S4030H0 CLK
  din_pin: GPIO21  # MSM261S4030H0 DAT
Where is my misstake and what’s the right mapping for S3 with MP34DT01?
Thank you for your help!
