ESP32-S3-BOX-3: Any YAML examples, how to migrate to using "assist_satellite"
I have been using the configuration, and instructions on this page: https://www.home-assistant.io/voice_control/s3_box_voice_assistant/
And since updating to Home Assistant 2024.10, I am receiving the following repair issue:
The ESPHome in progress binary sensor binary_sensor.esp32_s3_box_00000_assist_in_progress is deprecated.
Migrate your configuration to use the corresponding assist_satellite entity and then click SUBMIT to disable the in progress binary sensor and fix this issue.
I assume this is a new entity that needs to be added in ESPHome, but I can’t see any examples of it?
Thanks!
I solved this by just accepting this repair message and the enties will be replaced with the new assist entity.
o man, I am totally similar to yours, I am stuck in here too, have u solved that?
@AshaiRey’s solution is the way to go.
I think the wording suggests otherwise, but you should be able to just hit SUBMIT.
