I’ve got an ESP32-S3-BOX-3. It’s working, but…
After 2 days it doesn’t respond anymore on the wake word ‘OK NABU’.
The only solution is then to reinstall the box in HA.
Drives my crazy. More people with this problem? Any ideas?
LOG:
INFO ESPHome 2024.6.4
INFO Reading configuration /config/esphome/esphome-web-05a480.yaml…
INFO Updating https://github.com/esphome/firmware.git@main
INFO Updating https://github.com/esphome/esphome.git@pull/5230/head
INFO Updating https://github.com/jesserockz/esphome-components.git@None
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See Frequently Asked Questions — ESPHome
WARNING Found and merged multiple configurations for ota platform esphome port(s) [3232]
INFO Starting log output from 192.168.178.45 using esphome API
INFO Successfully connected to esp32-s3-box-3-05a480 @ xxx.xxx.xxx.xxx in 0.058s
INFO Successful handshake with esp32-s3-box-3-05a480 @ xxx.xxx.xxx.xxx in 0.266s
[10:41:09][I][app:100]: ESPHome version 2024.6.4 compiled on Jun 28 2024, 13:45:37
[10:41:09][I][app:102]: Project esphome.voice-assistant version 2.0
[10:41:09][C][wifi:599]: WiFi:
[10:41:09][C][wifi:427]: Local MAC: xx:xx:xx:xx:xx:xx
[10:41:09][C][wifi:432]: SSID: ‘xxxxxxxxx’[redacted]
[10:41:09][C][wifi:435]: IP Address: xxx.xxx.xxx.xxx
[10:41:09][C][wifi:439]: BSSID: xx:xx:xx:xx:xx:xx[redacted]
[10:41:09][C][wifi:440]: Hostname: ‘esp32-s3-box-3-05a480’
[10:41:09][C][wifi:442]: Signal strength: -62 dB ▂▄▆█
[10:41:09][C][wifi:446]: Channel: 9
[10:41:09][C][wifi:447]: Subnet: 255.255.255.0
[10:41:09][C][wifi:448]: Gateway: xxx.xxx.xxx.xxx
[10:41:09][C][wifi:449]: DNS1: xxx.xxx.xxx.xxx
[10:41:09][C][wifi:450]: DNS2: 0.0.0.0
[10:41:09][C][logger:185]: Logger:
[10:41:09][C][logger:186]: Level: DEBUG
[10:41:09][C][logger:188]: Log Baud Rate: 115200
[10:41:09][C][logger:189]: Hardware UART: USB_SERIAL_JTAG
[10:41:09][C][spi:068]: SPI bus:
[10:41:09][C][spi:069]: CLK Pin: GPIO7
[10:41:09][C][spi:070]: SDI Pin:
[10:41:09][C][spi:071]: SDO Pin: GPIO6
[10:41:09][C][spi:076]: Using HW SPI: SPI2_HOST
[10:41:09][C][i2c.idf:075]: I2C Bus:
[10:41:09][C][i2c.idf:076]: SDA Pin: GPIO8
[10:41:09][C][i2c.idf:077]: SCL Pin: GPIO18
[10:41:09][C][i2c.idf:078]: Frequency: 50000 Hz
[10:41:09][C][i2c.idf:084]: Recovery: bus successfully recovered
[10:41:09][I][i2c.idf:094]: Results from i2c bus scan:
[10:41:09][I][i2c.idf:100]: Found i2c device at address 0x18
[10:41:09][I][i2c.idf:100]: Found i2c device at address 0x40
[10:41:09][I][i2c.idf:100]: Found i2c device at address 0x5D
[10:41:09][I][i2c.idf:100]: Found i2c device at address 0x68
[10:41:09][C][i2c.idf:076]: SDA Pin: GPIO41
[10:41:09][C][i2c.idf:077]: SCL Pin: GPIO40
[10:41:09][I][i2c.idf:100]: Found i2c device at address 0x28
[10:41:09][I][i2c.idf:100]: Found i2c device at address 0x38
[10:41:09][C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘Mute’
[10:41:09][C][gpio.binary_sensor:016]: Pin: GPIO1
[10:41:09][C][ledc.output:176]: LEDC Output:
[10:41:09][C][ledc.output:177]: Pin GPIO47
[10:41:09][C][ledc.output:178]: LEDC Channel: 0
[10:41:09][C][ledc.output:179]: PWM Frequency: 1000.0 Hz
[10:41:09][C][ledc.output:180]: Phase angle: 0.0°
[10:41:09][C][ledc.output:181]: Bit depth: 14
[10:41:09][C][template.select:065]: Template Select ‘Wake word engine location’
[10:41:09][C][template.select:066]: Update Interval: 60.0s
[10:41:09][C][template.select:069]: Optimistic: YES
[10:41:09][C][template.select:070]: Initial Option: On device
[10:41:09][C][template.select:071]: Restore Value: YES
[10:41:09][C][template.text_sensor:020]: Template Sensor ‘text_request’
[10:41:09][C][template.text_sensor:020]: Template Sensor ‘text_response’
[10:41:09][C][ili9xxx:094]: ili9xxx
[10:41:09][C][ili9xxx:094]: Rotations: 0 °
[10:41:09][C][ili9xxx:094]: Dimensions: 320px x 240px
[10:41:09][C][ili9xxx:095]: Width Offset: 0
[10:41:09][C][ili9xxx:096]: Height Offset: 0
[10:41:09][C][ili9xxx:102]: Color mode: 16bit
[10:41:09][C][ili9xxx:111]: Data rate: 40MHz
[10:41:09][C][ili9xxx:113]: Reset Pin: GPIO48
[10:41:09][C][ili9xxx:114]: CS Pin: GPIO5
[10:41:09][C][ili9xxx:115]: DC Pin: GPIO4
[10:41:09][C][ili9xxx:117]: Color order: BGR
[10:41:09][C][ili9xxx:118]: Swap_xy: NO
[10:41:09][C][ili9xxx:119]: Mirror_x: YES
[10:41:09][C][ili9xxx:120]: Mirror_y: YES
[10:41:09][C][ili9xxx:125]: Update Interval: never
[10:41:09][C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘Top Left Button’
[10:41:09][C][gpio.binary_sensor:016]: Pin: GPIO0
[10:41:09][C][light:103]: Light ‘LCD Backlight’
[10:41:09][C][light:105]: Default Transition Length: 0.2s
[10:41:09][C][light:106]: Gamma Correct: 2.80
[10:41:09][C][template.switch:068]: Template Switch ‘Display conversation’
[10:41:09][C][template.switch:091]: Restore Mode: restore defaults to ON
[10:41:09][C][template.switch:057]: Optimistic: YES
[10:41:09][C][template.switch:068]: Template Switch ‘timer_ringing’
[10:41:09][C][template.switch:091]: Restore Mode: always OFF
[10:41:09][C][template.switch:068]: Template Switch ‘Mute’
[10:41:09][C][template.switch:091]: Restore Mode: restore defaults to OFF
[10:41:09][C][psram:020]: PSRAM:
[10:41:09][C][psram:021]: Available: YES
[10:41:09][C][psram:024]: Size: 16383 KB
[10:41:09][C][factory_reset.button:011]: Factory Reset Button ‘Factory reset’
[10:41:09][C][factory_reset.button:011]: Icon: ‘mdi:restart-alert’
[10:41:09][C][aht10:160]: AHT10:
[10:41:09][C][aht10:161]: Address: 0x38
[10:41:09][C][aht10:165]: Temperature ‘Temperature’
[10:41:09][C][aht10:165]: Device Class: ‘temperature’
[10:41:09][C][aht10:165]: State Class: ‘measurement’
[10:41:09][C][aht10:165]: Unit of Measurement: ‘°C’
[10:41:09][C][aht10:165]: Accuracy Decimals: 2
[10:41:09][C][aht10:166]: Humidity ‘Humidity’
[10:41:09][C][aht10:166]: Device Class: ‘humidity’
[10:41:09][C][aht10:166]: State Class: ‘measurement’
[10:41:09][C][aht10:166]: Unit of Measurement: ‘%’
[10:41:09][C][aht10:166]: Accuracy Decimals: 2
[10:41:09][C][adc:097]: ADC Sensor ‘Battery voltage’
[10:41:09][C][adc:097]: Device Class: ‘voltage’
[10:41:09][C][adc:097]: State Class: ‘measurement’
[10:41:09][C][adc:097]: Unit of Measurement: ‘V’
[10:41:09][C][adc:097]: Accuracy Decimals: 3
[10:41:09][C][adc:107]: Pin: GPIO10
[10:41:09][C][adc:116]: Attenuation: 2.5db
[10:41:09][C][adc:141]: Samples: 1
[10:41:09][C][adc:142]: Update Interval: 30.0s
[10:41:09][C][copy.sensor:015]: Copy Sensor ‘Battery level’
[10:41:09][C][copy.sensor:015]: Device Class: ‘battery’
[10:41:09][C][copy.sensor:015]: State Class: ‘measurement’
[10:41:09][C][copy.sensor:015]: Unit of Measurement: ‘%’
[10:41:09][C][copy.sensor:015]: Accuracy Decimals: 1
[10:41:09][C][esp32_ble:388]: ESP32 BLE: bluetooth stack is not enabled
[10:41:09][C][esp32_ble_server:200]: ESP32 BLE Server:
[10:41:09][C][esp32_improv.component:261]: ESP32 Improv:
[10:41:09][C][esp32_improv.component:266]: Status Indicator: ‘NO’
[10:41:09][C][mdns:115]: mDNS:
[10:41:09][C][mdns:116]: Hostname: esp32-s3-box-3-05a480
[10:41:09][C][esphome.ota:073]: Over-The-Air updates:
[10:41:09][C][esphome.ota:074]: Address: esp32-s3-box-3-05a480.local:3232
[10:41:09][C][esphome.ota:075]: Version: 2
[10:41:09][C][safe_mode:018]: Safe Mode:
[10:41:09][C][safe_mode:020]: Boot considered successful after 60 seconds
[10:41:09][C][safe_mode:021]: Invoke after 10 boot attempts
[10:41:09][C][safe_mode:023]: Remain in safe mode for 300 seconds
[10:41:09][C][api:139]: API Server:
[10:41:09][C][api:140]: Address: esp32-s3-box-3-05a480.local:6053
[10:41:09][C][api:142]: Using noise encryption: YES
[10:41:09][C][improv_serial:032]: Improv Serial:
[10:41:09][C][micro_wake_word:058]: microWakeWord:
[10:41:09][C][micro_wake_word:059]: Wake Word: okay nabu
[10:41:09][C][micro_wake_word:060]: Probability cutoff: 0.500
[10:41:09][C][micro_wake_word:061]: Sliding window size: 10
[10:41:10][D][sensor:094]: ‘Temperature’: Sending state 27.05898 °C with 2 decimals of accuracy
[10:41:10][D][sensor:094]: ‘Humidity’: Sending state 46.05141 % with 2 decimals of accuracy
