ESP32 S3 BOX lite buttons
I’m trying to crack my esp32 s3 box lite buttons: https://fr.aliexpress.com/item/1005004441701974.html . The device has 3 buttons connected to ADC pin 1 so I can read them using this config:
  - platform: adc
    pin: 1
    update_interval: .2s
    attenuation: auto
button 1 when pressed reads 2.4360V
button 2 when pressed reads between 2.006 and 1.990V
button 3 when pressed reads 0.8262V
when released the reading is 3.1554V
Is there a way to use that info and make working buttons?
I have cracked it - that code seems to do the trick:
  - platform: adc
    pin: 1
    update_interval: 200ms
    attenuation: auto
binary_sensor:
    lambda: |-
      if (id(button_adc).state > 2.2 && id(button_adc).state < 3.005){
        return true;
      } else {
        return false;
    lambda: |-
      if (id(button_adc).state > 1.8 && id(button_adc).state < 2.1) {
        return true;
      } else {
        return false;
    lambda: |-
      if (id(button_adc).state > 0.8 && id(button_adc).state < 1.8){
        return true;
      } else {
        return false;
Thanks for this!
I made the version below to handle simultaneous button presses. The voltage ranges are a bit narrow, so hopefully the values don’t vary between devices or power supplies.
  - platform: adc
    pin: 1
    attenuation: auto
binary_sensor:
    lambda: |-
      if ( (id(button_adc).state > 2.2 && id(button_adc).state < 2.76) ||
      (id(button_adc).state > 1.22 && id(button_adc).state < 1.81) ||
      (id(button_adc).state > 0.73 && id(button_adc).state < 0.79) ||
      id(button_adc).state < 0.68 ) {
        return true;
      } else {
        return false;
    lambda: |-
      if ( (id(button_adc).state > 1.22 && id(button_adc).state < 2.20) ||
      id(button_adc).state < 0.73 ) {
        return true;
      } else {
        return false;
    lambda: |-
      if ( id(button_adc).state < 1.22) {
        return true;
      } else {
        return false;
How did you disable the reset function of the button on the lower left?
I don’t think you can - that’s hardwired to the reset button on the board
did you manage to get the microphone working on your esp32 s3 box lite?
