ESP32-S3-BOX not waking
Hello all, I recently found out about the esphome-supported voice assistant firmware for the ESP32-S3-BOX unit (which I bought last year and used a bit with willow). Since yesterday I have been trying to get it to work, without success. I’m running HA 2024.5.2, and I used Ready-Made Projects — ESPHome to load the firmware onto the unit. Right now the screen shows a smiling gray house, so I believe that means that it’s connected to my HA instance (yay!). However, when I speak the wake word absolutely nothing happens. I can watch the logs and confirm that no activity takes place.
I have seen a few posts from others describing a similar problem, but most of them either reloaded and cured the problem, or the thread went dead. I have reinstalled the firmware 4 or 5 times now, so I don’t think the 7th time is going to be “the one” or anything.
Has anyone else encountered this problem? I have a BOX3 on the way, so hopefully that one will work, but I’d like to have this one working as well since I already have it.
HA>>settings>>voice assistant
Did you setup and configure a voice assistant?
I can’t speak for James but i’m having a similar issue with my device.
Maybe once or twice after the device reboots it will wake with ‘okay nabu’ but after that it seems totally deaf to me. It’s acting like one of my kids when they were young :slight_smile:
Additionally, it might also be randomly waking based on some sound inperceptible to the human ear. Several times during the night i’ll hear it wake up & spout some sentence that i can’t make out since I & anyone else are in another room. Weird stuff.
I have paused my esp voice assistant experimentation for the time being until i can afford to spend more time invesetigating.
Just sayin’.
Yes, I had an assistant configured from my previous work with willow. Below the assistant, the page says 46 entities exposed 1 assist device which implies that HA knows about the existence of the S3 Box.
That smiling house is mocking me! :rofl:
I received my ESP32-S3-BOX3 in the mail yesterday, so today I tried to follow the same procedure for setting it up. After adopting it into my HA install, I’m stuck in exactly the same spot. It boots up and displays the gray smiley face, but it does not respond to any wake word. :frowning:
I wondered if I might be mispronouncing the wake word, so I changed the configuration on the S3-Box to use a different wakeword model (hey_jarvis). That did not alter the behavior of the box, it is still completely unresponsive to either wake word.
I just recently added an ESP32-S3-BOX-3 to my Home Assistant server and have experienced the same behavior others describe: it connects to my server, but it only occasionally responds to the wake word.
By occasionally, it’s about 1 in 20 attempts. When it does respond, it executes the command successfully. I’ve tried both “Alexa” and “ok Nabu” for the wake words, same behavior.
I just received my ESP32-S3-BOX-3. Same behaviour. I can set it up via the web page and it also is recognized in HA. But the Home Assistant Logo is greyed out on the device and for me no voice command is recognized.
Hi all.
I got two Box3’s today, and have the same issue.
My DIY esp32 on a breadboard with i2s mic works better than this.
No matter what I try, wake word on device or in HA, multiple pipelines (which work on a plain esp32), do not work here.
This is quite frustrating, as I was hoping for a good out-of-box experience.
Found some recent info here:
https://www.reddit.com/r/homeassistant/comments/1baoa29/comment/lajgxtx/
synthmike wrote: “We’ve switched the audio over to using the same connection that ESPHome maintains to HA, so no more UDP issues :)”
What I noticed, is my breadboard esp32 (when connected) starts wake word runs that I can see in the Debug Assistant.
The Box3 does not (when selecting Home Assistant as the wake word engine location).
The Debug Assistant just stays empty. On any pipeline I try.
Not sure if it’s the same for other people, but for me wake word detection doesn’t work after rebooting the ESP32 until I switch “Wake word engine location” to “In home assistant” and then back to “on device”.
Might be some strange feedback, but hey. It’s progress.
Looking at the logs. I can see the last line is Waiting for VAD, or WakeWord. Depending on the Engine Location I set.
So… many frustrations later of this thing never detecting me, I spoke to it loudly at point blank close range… and it worked.
It has extremely poor pickup. Anything further than 10cm and it is unresponsive.
I don’t have a soft voice either.
So now the next goal would be increasing sensitivity.
Do I have two faulty units, or has anyone else struggled with the same issue?
Im also experiencing issues with not detecting my wake words…
Any updates on this? Recently my ESPbox stopped responding to the wake word. After looking in the ESPhome settings I discovered that the wake word location selector is greyed out:
So I decided to re-flash it using the code from the ESPhome Projects github page and it is still the same…
When I look at the device logs there is no entry that points to a cause for this. (no errors at all)
Secondly, I have no idea why there are two firmware entities…
Bumping this. I had similar problems, finally after a complete wipe and redo it started working…kind of. My issue is no matter what I do i.e. redo the yaml or change the options in HA wake word will not change It will only use ok nabu. Every time I try to redo the YAML, save it then try to install it they ESP home it locks up or just straight fails.
From what i understand - if you change the wake word - which I have done. The firmware must be recompiled. Which takes extra resource from the system that you requesting this from, in my case a RPI 4. I had to stop multiple add-ons etc to provide enough free RAM in the system to enable it to happen. Took me about 5 attempts to get it to work. But I have a working ‘Hey Jarvis’ S3 system now.
@dharvey24 I am running a Yellow and it should have enough resources I would think but will not work for me after days of attempting. I always see the option to download it and compile, I think it says, any clue how that option works or a place with a “very dumbed down…like very” explanation of the steps? Not sure if this is due to hardware or ESP home but there are so many complaints about this whole process.
[quote=“Marcavich, post:12, topic:732297”]
I had also no success with “hey jarvis” & “okay nabu”. Then I tried “hey mycroft” : works perfectly. I think it is my accent.
I ended up re-flashing mine serially and it’s working well again.
