vladx
(L>)
February 2, 2024, 2:31pm
224
Yes, temp, voice and presence all working
vladx
(L>)
February 2, 2024, 2:32pm
225
Maybe try cleaning build files. It helped me several times
Kev1
(Kevin Burr)
February 2, 2024, 3:22pm
226
Tried that and various other things I can think of, also including deleting Esphome Addon.
If there another way of Installing with going through the link?
bobzer
(Bobzer)
February 2, 2024, 4:37pm
227
would you mind to share your whole yaml please ?
also did you change settings on the mic or speaker ?
I feel mine donāt hear a lot and the speaker is very very low
vladx
(L>)
February 2, 2024, 5:05pm
228
Sure.
Home Assistant Voice Assistant + Presence + Temp Sensor - Pastebin.com
The tempeature sensor seems a bit optimistic measuring 25-26 celsius while it is only 22, so noone should rely on it
ballakers
(Ballakers)
February 2, 2024, 7:57pm
229
Thanks for uploading your code - And what youāre describing is the extra little RGB LED they included - it goes with the GPIO dock unfortunately - wish we could plug it into the Radar dock but i guess enough GPIOs are used with that dock.
HJM
(John Munro)
February 2, 2024, 10:05pm
230
@vladx , can you try pulling the power on your box3 and then powering it up again to see if both temp and voice still work? Both temp and voice on mine worked until the cold boot too.
Apparently the issue is a driver handle conflict between ADF and ESPHome controlling the I2C bus and this is not seen until a full reboot.
opened 11:19AM - 26 Dec 23 UTC
### The problem
Voice Assistant is installed on the ESP32-S3-BOX-3.
Afā¦ ter activating i2c. The Voice Assistant pipeline no longer activates after a few hours. A factory reset does not help. Only deactivating the i2c components and reflashing helps.
The Red Button under the Display does not work either.
Best regards,
M.
### Which version of ESPHome has the issue?
2023.12.3
### What type of installation are you using?
Home Assistant Add-on
### Which version of Home Assistant has the issue?
2023.12.3
### What platform are you using?
ESP32-IDF
### Board
ESP32-S3-BOX-3
### Component causing the issue
Voice assistant
### Example YAML snippet
```yaml
substitutions:
friendly_name: ESP32 S3 Box 3
loading_illustration_file: https://github.com/esphome/firmware/raw/main/voice-assistant/casita/loading_320_240.png
idle_illustration_file: https://github.com/esphome/firmware/raw/main/voice-assistant/casita/idle_320_240.png
listening_illustration_file: https://github.com/esphome/firmware/raw/main/voice-assistant/casita/listening_320_240.png
thinking_illustration_file: https://github.com/esphome/firmware/raw/main/voice-assistant/casita/thinking_320_240.png
replying_illustration_file: https://github.com/esphome/firmware/raw/main/voice-assistant/casita/replying_320_240.png
error_illustration_file: https://github.com/esphome/firmware/raw/main/voice-assistant/casita/error_320_240.png
loading_illustration_background_color: '000000'
idle_illustration_background_color: '000000'
listening_illustration_background_color: 'FFFFFF'
thinking_illustration_background_color: 'FFFFFF'
replying_illustration_background_color: 'FFFFFF'
error_illustration_background_color: '000000'
voice_assist_idle_phase_id: '1'
voice_assist_listening_phase_id: '2'
voice_assist_thinking_phase_id: '3'
voice_assist_replying_phase_id: '4'
voice_assist_not_ready_phase_id: '10'
voice_assist_error_phase_id: '11'
voice_assist_muted_phase_id: '12'
#wifi_update_interval: 3s
#packages:
# esphome.voice-assistant: github://esphome/firmware/voice-assistant/esp32-s3-box-3.yaml@main
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
platformio_options:
board_build.flash_mode: dio
project:
version: "1.0"
min_version: 2023.11.5
on_boot:
priority: 600
then:
- script.execute: draw_display
- delay: 30s
- if:
condition:
lambda: return id(init_in_progress);
then:
- lambda: id(init_in_progress) = false;
api:
encryption:
key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
on_client_connected:
on_client_disconnected:
wifi:
ssid: !secret wifi_ssid
ap:
on_connect:
- delay: 5s # Gives time for improv results to be transmitted
- ble.disable:
on_disconnect:
- ble.enable:
esp32:
board: esp32s3box
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_AUDIO_BOARD_CUSTOM: "y"
CONFIG_ESP32_S3_BOX_3_BOARD: "y"
components:
- name: esp32_s3_box_3_board
source: github://jesserockz/esp32-s3-box-3-board@main
refresh: 0s
psram:
mode: octal
speed: 80MHz
external_components:
- source: github://pr#5230
components: esp_adf
refresh: 0s
ota:
logger:
hardware_uart: USB_SERIAL_JTAG
# level: VERBOSE
dashboard_import:
package_import_url: github://esphome/firmware/voice-assistant/esp32-s3-box-3.yaml@main
improv_serial:
esp32_improv:
authorizer: none
button:
- platform: factory_reset
binary_sensor:
- platform: gt911
index: 1
gt911_id: gt911_touchscreen
on_press:
then:
- light.toggle: led
- platform: gpio
pin:
number: GPIO1
inverted: true
disabled_by_default: true
entity_category: diagnostic
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: true
name: Top Left Button
on_multi_click:
- timing:
- ON for at least 10s
then:
- button.press: factory_reset_btn
output:
- platform: ledc
pin: GPIO47
light:
- platform: monochromatic
name: LCD Backlight
entity_category: config
output: backlight_output
restore_mode: RESTORE_DEFAULT_ON
default_transition_length: 250ms
esp_adf:
board: esp32s3box3
microphone:
- platform: esp_adf
speaker:
- platform: esp_adf
voice_assistant:
microphone: box_mic
speaker: box_speaker
use_wake_word: true
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 2.0 #2.0
vad_threshold: 3
on_listening:
- lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
- light.turn_on: led
on_stt_vad_end:
- lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
on_tts_stream_start:
- lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
on_tts_stream_end:
- lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
- light.turn_off: led
on_error:
- if:
condition:
lambda: return !id(init_in_progress);
then:
- lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
- delay: 1s
- if:
condition:
switch.is_off: mute
then:
else:
- lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
- if:
condition:
switch.is_off: mute
then:
- wait_until:
not: ble.enabled
- voice_assistant.start_continuous:
else:
- lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
script:
- id: draw_display
then:
- if:
condition:
then:
- if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- lambda: |
switch(id(voice_assistant_phase)) {
case ${voice_assist_listening_phase_id}:
id(s3_box_lcd).show_page(listening_page);
id(s3_box_lcd).update();
break;
case ${voice_assist_thinking_phase_id}:
id(s3_box_lcd).show_page(thinking_page);
break;
case ${voice_assist_replying_phase_id}:
id(s3_box_lcd).show_page(replying_page);
break;
case ${voice_assist_error_phase_id}:
id(s3_box_lcd).show_page(error_page);
break;
case ${voice_assist_muted_phase_id}:
id(s3_box_lcd).show_page(muted_page);
break;
case ${voice_assist_not_ready_phase_id}:
id(s3_box_lcd).show_page(no_ha_page);
break;
default:
id(s3_box_lcd).show_page(idle_page);
else:
- display.page.show: no_ha_page
- component.update: s3_box_lcd
else:
- display.page.show: no_wifi_page
else:
- display.page.show: initializing_page
switch:
optimistic: true
restore_mode: RESTORE_DEFAULT_OFF
on_turn_off:
- if:
condition:
then:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_on:
- if:
condition:
then:
- voice_assistant.stop
- lambda: id(va).set_use_wake_word(false);
globals:
- id: init_in_progress
type: bool
restore_value: no
initial_value: 'true'
- id: voice_assistant_phase
type: int
restore_value: no
initial_value: ${voice_assist_not_ready_phase_id}
image:
- file: ${error_illustration_file}
resize: 320x240
type: RGB24
use_transparency: true
- file: ${idle_illustration_file}
resize: 320x240
type: RGB24
- file: ${listening_illustration_file}
resize: 320x240
type: RGB24
- file: ${thinking_illustration_file}
resize: 320x240
type: RGB24
- file: ${replying_illustration_file}
resize: 320x240
type: RGB24
- file: ${loading_illustration_file}
resize: 320x240
type: RGB24
- file: https://github.com/esphome/firmware/raw/main/voice-assistant/error_box_illustrations/error-no-wifi.png
resize: 320x240
type: RGB24
- file: https://github.com/esphome/firmware/raw/main/voice-assistant/error_box_illustrations/error-no-ha.png
resize: 320x240
type: RGB24
color:
- id: idle_color
hex: ${idle_illustration_background_color}
- id: listening_color
hex: ${listening_illustration_background_color}
- id: thinking_color
hex: ${thinking_illustration_background_color}
- id: replying_color
hex: ${replying_illustration_background_color}
- id: loading_color
hex: ${loading_illustration_background_color}
- id: error_color
hex: ${error_illustration_background_color}
spi:
clk_pin: 7
mosi_pin: 6
display:
- platform: ili9xxx
model: S3BOX
data_rate: 40MHz
cs_pin: 5
dc_pin: 4
reset_pin:
number: 48
inverted: true
update_interval: never
pages:
- id: idle_page
lambda: |-
it.fill(id(idle_color));
it.image((it.get_width() / 2), (it.get_height() / 2), id(casita_idle), ImageAlign::CENTER);
- id: listening_page
lambda: |-
it.fill(id(listening_color));
it.image((it.get_width() / 2), (it.get_height() / 2), id(casita_listening), ImageAlign::CENTER);
- id: thinking_page
lambda: |-
it.fill(id(thinking_color));
it.image((it.get_width() / 2), (it.get_height() / 2), id(casita_thinking), ImageAlign::CENTER);
- id: replying_page
lambda: |-
it.fill(id(replying_color));
it.image((it.get_width() / 2), (it.get_height() / 2), id(casita_replying), ImageAlign::CENTER);
- id: error_page
lambda: |-
it.fill(id(error_color));
it.image((it.get_width() / 2), (it.get_height() / 2), id(casita_error), ImageAlign::CENTER);
- id: no_ha_page
lambda: |-
it.image((it.get_width() / 2), (it.get_height() / 2), id(error_no_ha), ImageAlign::CENTER);
- id: no_wifi_page
lambda: |-
it.image((it.get_width() / 2), (it.get_height() / 2), id(error_no_wifi), ImageAlign::CENTER);
- id: initializing_page
lambda: |-
it.fill(id(loading_color));
it.image((it.get_width() / 2), (it.get_height() / 2), id(casita_initializing), ImageAlign::CENTER);
- id: muted_page
lambda: |-
it.fill(Color::BLACK);
i2c:
- id: bus_a
sda: GPIO08
scl: GPIO18
- id: bus_b
sda: GPIO41
scl: GPIO40
- platform: aht10
i2c_id: bus_b
variant: AHT20
temperature:
humidity:
update_interval: 60s
- platform: adc
pin: GPIO10
unit_of_measurement: "V"
accuracy_decimals: 3
device_class: "voltage"
entity_category: "diagnostic"
update_interval: 30s
attenuation: auto
filters:
- multiply: 4.01
- platform: copy
source_id: battery_voltage
unit_of_measurement: "%"
accuracy_decimals: 1
device_class: "battery"
filters:
- lambda: return (x - 2.5) / (4.2 - 2.5) * 100;
- clamp:
min_value: 0
max_value: 100
ignore_out_of_range: true
# - platform: uptime
# name: Uptime
# id: uptime_sensor
# entity_category: "diagnostic"
# update_interval: $wifi_update_interval
# on_raw_value:
# then:
# - text_sensor.template.publish:
# id: uptime_human
# state: !lambda |-
# int seconds = round(id(uptime_sensor).raw_state);
# int days = seconds / (24 * 3600);
# seconds = seconds % (24 * 3600);
# int hours = seconds / 3600;
# seconds = seconds % 3600;
# int minutes = seconds / 60;
# seconds = seconds % 60;
# return (
# (days ? to_string(days) + "d " : "") +
# (hours ? to_string(hours) + "h " : "") +
# (minutes ? to_string(minutes) + "m " : "") +
# (to_string(seconds) + "s")
# ).c_str();
# - platform: wifi_signal
# name: "WiFi Signal dB"
# id: wifi_signal_db
# update_interval: 60s
- platform: internal_temperature
name: "Internal Temperature"
touchscreen:
platform: gt911
i2c_id: bus_a
interrupt_pin: GPIO3
on_touch:
# - logger.log:
# format: Touch at (%d, %d)
# args: [touch.x, touch.y]
then:
- light.toggle: led
#text_sensor:
# - platform: wifi_info
# ip_address:
# name: IP Address
# ssid:
# name: Connected SSID
# bssid:
# name: Connected BSSID
# mac_address:
# name: Mac Wifi Address
# scan_results:
# name: Latest Scan Results
# Device Uptime Information
# - platform: template
# name: Uptime Human Readable
# id: uptime_human
# icon: mdi:clock-start
### Anything in the logs that might be useful for us?
```txt
Log after a factory reset:
[12:14:40][I][app:102]: ESPHome version 2023.12.3 compiled on Dec 26 2023, 11:38:44
[12:14:40][I][app:104]: Project esphome.voice-assistant version 1.0
[12:14:40][C][wifi:573]: WiFi:
[12:14:40][C][wifi:405]: Local MAC: xxxxxxxxxxxxxxx
[12:14:40][C][wifi:410]: SSID: [redacted]
[12:14:40][C][wifi:411]: IP Address: xxxxxxxxxxxxxxx
[12:14:40][C][wifi:413]: BSSID: [redacted]
[12:14:40][C][wifi:414]: Hostname: 'esp32-s3-box-3-5ace4c'
[12:14:40][C][wifi:416]: Signal strength: -47 dB āāāā
[12:14:40][C][wifi:420]: Channel: 1
[12:14:40][C][wifi:421]: Subnet: 255.255.255.0
[12:14:40][C][wifi:422]: Gateway: xxxxxxxxxx
[12:14:40][C][wifi:423]: DNS1: xxxxxxxxxx
[12:14:40][C][wifi:424]: DNS2: xxxxxxxxxxx
[12:14:40][C][logger:443]: Logger:
[12:14:40][C][logger:444]: Level: DEBUG
[12:14:40][C][logger:445]: Log Baud Rate: 115200
[12:14:40][C][logger:447]: Hardware UART: USB_SERIAL_JTAG
[12:14:40][C][spi:067]: SPI bus:
[12:14:40][C][spi:068]: CLK Pin: GPIO7
[12:14:40][C][spi:069]: SDI Pin:
[12:14:40][C][spi:070]: SDO Pin: GPIO6
[12:14:40][C][spi:072]: Using HW SPI: SPI2_HOST
[12:14:40][C][i2c.idf:061]: I2C Bus:
[12:14:40][C][i2c.idf:062]: SDA Pin: GPIO8
[12:14:40][C][i2c.idf:063]: SCL Pin: GPIO18
[12:14:40][C][i2c.idf:064]: Frequency: 50000 Hz
[12:14:40][C][i2c.idf:067]: Recovery: bus successfully recovered
[12:14:40][I][i2c.idf:077]: Results from i2c bus scan:
[12:14:40][I][i2c.idf:083]: Found i2c device at address 0x18
[12:14:40][I][i2c.idf:083]: Found i2c device at address 0x40
[12:14:40][I][i2c.idf:083]: Found i2c device at address 0x5D
[12:14:40][I][i2c.idf:083]: Found i2c device at address 0x68
[12:14:40][C][i2c.idf:062]: SDA Pin: GPIO41
[12:14:40][C][i2c.idf:063]: SCL Pin: GPIO40
[12:14:40][I][i2c.idf:083]: Found i2c device at address 0x28
[12:14:40][I][i2c.idf:083]: Found i2c device at address 0x38
[12:14:40][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Mute'
[12:14:40][C][gpio.binary_sensor:016]: Pin: GPIO1
[12:14:40][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Top Left Button'
[12:14:40][C][gpio.binary_sensor:016]: Pin: GPIO0
[12:14:40][C][ledc.output:164]: LEDC Output:
[12:14:40][C][ledc.output:165]: Pin GPIO47
[12:14:40][C][ledc.output:166]: LEDC Channel: 0
[12:14:40][C][ledc.output:167]: PWM Frequency: 1000.0 Hz
[12:14:40][C][ledc.output:168]: Bit depth: 14
[12:14:40][C][ili9xxx:069]: ili9xxx
[12:14:40][C][ili9xxx:069]: Rotations: 0 Ā°
[12:14:40][C][ili9xxx:069]: Dimensions: 320px x 240px
[12:14:40][C][ili9xxx:070]: Width Offset: 0
[12:14:40][C][ili9xxx:071]: Height Offset: 0
[12:14:40][C][ili9xxx:077]: Color mode: 16bit
[12:14:40][C][ili9xxx:086]: Data rate: 40MHz
[12:14:40][C][ili9xxx:088]: Reset Pin: GPIO48
[12:14:40][C][ili9xxx:089]: CS Pin: GPIO5
[12:14:40][C][ili9xxx:090]: DC Pin: GPIO4
[12:14:40][C][ili9xxx:092]: Swap_xy: NO
[12:14:40][C][ili9xxx:093]: Mirror_x: YES
[12:14:40][C][ili9xxx:094]: Mirror_y: YES
[12:14:40][C][ili9xxx:099]: Update Interval: never
[12:14:40][C][light:103]: Light 'LCD Backlight'
[12:14:40][C][light:105]: Default Transition Length: 0.2s
[12:14:40][C][light:106]: Gamma Correct: 2.80
[12:14:40][C][template.switch:068]: Template Switch 'Mute'
[12:14:40][C][template.switch:091]: Restore Mode: restore defaults to OFF
[12:14:40][C][template.switch:057]: Optimistic: YES
[12:14:40][C][psram:020]: PSRAM:
[12:14:40][C][psram:021]: Available: YES
[12:14:40][C][psram:024]: Size: 16383 KB
[12:14:40][C][factory_reset.button:011]: Factory Reset Button 'Factory reset'
[12:14:40][C][factory_reset.button:011]: Icon: 'mdi:restart-alert'
[12:14:40][C][aht10:150]: AHT10:
[12:14:40][C][aht10:151]: Address: 0x38
[12:14:40][C][aht10:155]: Temperature 'Temperature'
[12:14:40][C][aht10:155]: Device Class: 'temperature'
[12:14:40][C][aht10:155]: State Class: 'measurement'
[12:14:40][C][aht10:155]: Unit of Measurement: 'Ā°C'
[12:14:40][C][aht10:155]: Accuracy Decimals: 2
[12:14:40][C][aht10:156]: Humidity 'Humidity'
[12:14:40][C][aht10:156]: Device Class: 'humidity'
[12:14:40][C][aht10:156]: State Class: 'measurement'
[12:14:40][C][aht10:156]: Unit of Measurement: '%'
[12:14:40][C][aht10:156]: Accuracy Decimals: 2
[12:14:40][C][adc:097]: ADC Sensor 'Battery voltage'
[12:14:40][C][adc:097]: Device Class: 'voltage'
[12:14:40][C][adc:097]: State Class: 'measurement'
[12:14:40][C][adc:097]: Unit of Measurement: 'V'
[12:14:40][C][adc:097]: Accuracy Decimals: 3
[12:14:40][C][adc:107]: Pin: GPIO10
[12:14:40][C][adc:109]: Attenuation: auto
[12:14:40][C][adc:142]: Update Interval: 30.0s
[12:14:40][C][copy.sensor:015]: Copy Sensor 'Battery level'
[12:14:40][C][copy.sensor:015]: Device Class: 'battery'
[12:14:40][C][copy.sensor:015]: State Class: 'measurement'
[12:14:40][C][copy.sensor:015]: Unit of Measurement: '%'
[12:14:40][C][copy.sensor:015]: Accuracy Decimals: 1
[12:14:40][C][internal_temperature:059]: Internal Temperature Sensor 'Internal Temperature'
[12:14:40][C][internal_temperature:059]: Device Class: 'temperature'
[12:14:40][C][internal_temperature:059]: State Class: 'measurement'
[12:14:40][C][internal_temperature:059]: Unit of Measurement: 'Ā°C'
[12:14:40][C][internal_temperature:059]: Accuracy Decimals: 1
[12:14:41][C][gt911.touchscreen:105]: GT911 Touchscreen:
[12:14:41][C][gt911.touchscreen:106]: Address: 0x5D
[12:14:41][C][gt911.touchscreen:107]: Interrupt Pin: GPIO3
[12:14:41][C][GT911.binary_sensor:015]: GT911 Button 'Home Button'
[12:14:41][C][GT911.binary_sensor:016]: Index: 1
[12:14:41][C][esp32_ble:379]: ESP32 BLE: bluetooth stack is not enabled
[12:14:41][C][esp32_ble_server:200]: ESP32 BLE Server:
[12:14:41][C][esp32_improv.component:257]: ESP32 Improv:
[12:14:41][C][esp32_improv.component:262]: Status Indicator: 'NO'
[12:14:41][C][mdns:115]: mDNS:
[12:14:41][C][mdns:116]: Hostname: esp32-s3-box-3-5ace4c
[12:14:41][C][ota:097]: Over-The-Air Updates:
[12:14:41][C][ota:098]: Address: esp32-s3-box-3-5ace4c.local:3232
[12:14:41][C][api:139]: API Server:
[12:14:41][C][api:140]: Address: esp32-s3-box-3-5ace4c.local:6053
[12:14:41][C][api:142]: Using noise encryption: YES
[12:14:41][C][improv_serial:032]: Improv Serial:
[12:14:42][D][aht10:097]: AHT10 is busy, waiting...
[12:14:42][D][sensor:094]: 'Temperature': Sending state 38.71040 Ā°C with 2 decimals of accuracy
[12:14:42][D][sensor:094]: 'Humidity': Sending state 22.04561 % with 2 decimals of accuracy
[12:14:42][W][component:214]: Component aht10.sensor took a long time for an operation (0.08 s).
[12:14:42][W][component:215]: Components should block for at most 20-30ms.
[12:14:43][D][button:010]: 'Factory reset' Pressed.
[12:14:43][I][factory_reset.button:013]: Resetting to factory defaults...
[12:14:43][D][esp32.preferences:176]: Cleaning up preferences in flash...
[12:14:43][I][app:134]: Rebooting safely...
INFO Processing expected disconnect from ESPHome API for esp32-s3-box-3-5ace4c @ 192.168.0.167
WARNING Disconnected from API
INFO Successfully connected to esp32-s3-box-3-5ace4c @ 192.168.0.167 in 7.141s
INFO Successful handshake with esp32-s3-box-3-5ace4c @ 192.168.0.167 in 0.320s
[12:14:57][D][voice_assistant:422]: State changed from IDLE to START_MICROPHONE
[12:14:57][D][voice_assistant:428]: Desired state set to WAIT_FOR_VAD
[12:14:57][D][light:036]: 'LCD Backlight' Setting:
[12:14:57][D][light:047]: State: OFF
[12:14:57][D][light:085]: Transition length: 0.2s
[12:14:57][E][spi-esp-idf:081]: Transmit failed - err 101
[12:14:57][W][component:214]: Component voice_assistant took a long time for an operation (0.19 s).
[12:14:57][W][component:215]: Components should block for at most 20-30ms.
[12:14:57][D][esp32_ble:255]: Disabling BLE...
[12:14:57][D][esp-idf:000]: W (14577) BT_APPL: bta_dm_disable BTA_DISABLE_DELAY set to 200 ms
[12:14:58][W][component:214]: Component esp32_ble took a long time for an operation (0.21 s).
[12:14:58][W][component:215]: Components should block for at most 20-30ms.
[12:14:58][D][voice_assistant:159]: Starting Microphone
[12:14:58][D][voice_assistant:422]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[12:14:58][D][esp-idf:000]: I (14818) I2S: DMA Malloc info, datalen=blocksize=512, dma_buf_count=8
[12:14:58][D][esp-idf:000]: I (14825) I2S: I2S0, MCLK output by GPIO2
[12:14:58][D][esp-idf:000]: I (14831) AUDIO_PIPELINE: link el->rb, el:0x3d036c2c, tag:i2s, rb:0x3d037040
[12:14:58][D][esp-idf:000]: I (14834) AUDIO_PIPELINE: link el->rb, el:0x3d036da0, tag:filter, rb:0x3d039080
[12:14:58][D][esp-idf:000]: I (14841) AUDIO_ELEMENT: [i2s-0x3d036c2c] Element task created
[12:14:58][D][esp-idf:000]: I (14848) AUDIO_THREAD: The filter task allocate stack on external memory
[12:14:58][D][esp-idf:000]: I (14851) AUDIO_ELEMENT: [filter-0x3d036da0] Element task created
[12:14:58][D][esp-idf:000]: I (14856) AUDIO_ELEMENT: [raw-0x3d036ed0] Element task created
[12:14:58][D][esp-idf:000]: I (14861) AUDIO_PIPELINE: Func:audio_pipeline_run, Line:359, MEM Total:16583563 Bytes, Inter:48188 Bytes, Dram:48188 Bytes
[12:14:58][D][esp-idf:000]: I (14868) AUDIO_ELEMENT: [i2s] AEL_MSG_CMD_RESUME,state:1
[12:14:58][D][esp-idf:000]: I (14872) AUDIO_ELEMENT: [filter] AEL_MSG_CMD_RESUME,state:1
[12:14:58][D][esp-idf:000]: I (14876) RSP_FILTER: sample rate of source data : 16000, channel of source data : 2, sample rate of destination data : 16000, channel of destination data : 1
[12:14:58][D][esp-idf:000]: I (14879) AUDIO_PIPELINE: Pipeline started
[12:14:58][D][esp_adf.microphone:294]: Microphone started
[12:14:58][D][voice_assistant:422]: State changed from STARTING_MICROPHONE to WAIT_FOR_VAD
[12:14:58][D][voice_assistant:176]: Waiting for speech...
[12:14:58][D][voice_assistant:422]: State changed from WAIT_FOR_VAD to WAITING_FOR_VAD
[12:15:05][D][sensor:094]: 'Battery voltage': Sending state 3.56853 V with 3 decimals of accuracy
[12:15:05][D][sensor:094]: 'Battery level': Sending state 62.85499 % with 1 decimals of accuracy
[12:15:27][D][aht10:097]: AHT10 is busy, waiting...
[12:15:27][D][sensor:094]: 'Temperature': Sending state 38.69686 Ā°C with 2 decimals of accuracy
[12:15:27][D][sensor:094]: 'Humidity': Sending state 22.14909 % with 2 decimals of accuracy
[12:15:27][W][component:214]: Component aht10.sensor took a long time for an operation (0.07 s).
[12:15:27][W][component:215]: Components should block for at most 20-30ms.
[12:15:31][D][esp32.preferences:114]: Saving 1 preferences to flash...
[12:15:31][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[12:15:35][D][sensor:094]: 'Battery voltage': Sending state 3.57047 V with 3 decimals of accuracy
[12:15:35][D][sensor:094]: 'Battery level': Sending state 62.96910 % with 1 decimals of accuracy
[12:15:37][D][esp-idf:000]: I (54079) tsens: Config temperature range [-10Ā°C ~ 80Ā°C], error < 1Ā°C
[12:15:37][D][sensor:094]: 'Internal Temperature': Sending state 40.05940 Ā°C with 1 decimals of accuracy
### Additional information
_No response_
vladx
(L>)
February 3, 2024, 11:17am
231
Yes, it seems after reboot voice is not workingā¦I removed the temp sensor, and voice still not working. Iāve experienced this multiple times, the voice was ok for a while, then stopped responding to wake wordā¦ so it seems a bit alpha
L:
HJM
(John Munro)
February 3, 2024, 8:36pm
232
If you didnāt figure it out yet, you need to reboot to remove the code the temp sensor adds. Be sure youāve removed all the I2C code before rebooting.
nisse1
(nisse)
February 4, 2024, 9:46am
233
Its a 1W speaker guysā¦ you should not expect much.
and if you dont like it, do what i did and send the response to a multiroom media player.
Voice , AHT , presence and Touch are all working for me. The only thing I havenāt got at the moment is the red touch button and IR , but not really looked into those too much.
HJM
(John Munro)
February 9, 2024, 8:12am
235
what am I looking at John everything is working for me after changing i2c config as per ESP32-S3-BOX-3 Voice assistant stability issue when i2c is activated Ā· Issue #5296 Ā· esphome/issues Ā· GitHub
**edit
ok Iām with you now, I always have a battery in , so hadnāt encountered the cold boot issue. and yes , voice stops working from a cold boot. oh well I guess iāll just leave the battery in for now. I thought it was working too well lol
sparkydave
(š¦šŗ Dave)
February 13, 2024, 1:21am
237
Just replying to myself here to explain that this situation is about to change.
On-board wake word coming to ESP chips!
nisse1
(nisse)
February 13, 2024, 9:56am
238
Mine gets āstuckā after calling services like media_player.play_media
Is there anyway I can reboot the device from within HA? that way i can put it at the end of the intent_script, or something like that
psinide
(Raj Palvankar)
February 17, 2024, 4:08am
239
I just received my s3 box3. Can you share your config to get the sensors running? I also plan to have a battery along with the power to avoid the issues from cold boot
HJM
(John Munro)
February 17, 2024, 4:19am
240
Hi Raj,
Can you do us a favour and scroll up for the config?
Thanks.
you can add the following to your device config in ESPHome , to give you a restart button, which will have an entity you can call
button:
- platform: restart
there is a new model for āhey jarvisā if you are using the beta, and for me it works 100% better
model: 'github://kahrendt/microwakeword/models/hey_jarvis.json'
HJM
(John Munro)
February 20, 2024, 4:50am
243
Hi Rob(?),
Do you have micro wake word running? If so, what changes to your yaml did you make?
Using the example code in the beta (2024.2.0b2), I keep getting compile errors.
Compiling .pioenvs/esp32-s3-box-3-5ad0fc/components/esp-tflite-micro/tensorflow/lite/micro/micro_allocation_info.o
xtensa-esp32s3-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/esp32-s3-box-3-5ad0fc/components/esp-tflite-micro/tensorflow/lite/micro/fake_micro_context.o] Error 1
========================= [FAILED] Took 640.22 seconds =========================
I forked the repo and changed yaml:
packages:
esphome.voice-assistant: github://jaymunro/esphome_firmware/voice-assistant/esp32-s3-box-3.yaml@micro_wake_word
