hm⌠to be honest, I donât really understand the âauto discoveryâ mechanismâŚ
When I delete my configuration, ESPHome will auto-detect the device - but the installation usually fails, because itâs waiting for a password - which is not given.
If I cancel the auto-detect, I do have only the following config:
Now the reponse stream is much better in terms of cut off. I believe this is due to changes in ESPHome which is now version 2023.11.6. Only sometimes there is a little bit missing at the beginning. Unfortunately the volume is still very low and increasing the âvolume_multiplierâ did not change anything for me. Everything else works fine for me.
UPDATE: Starting with HA 2024.5 and ESPHome 2024.4.0, UDP is no longer used for the sending and receiving audio. The ESPHome-to-HA native API, using TCP, is used instead. This means special UDP VLAN firewall rules are no longer needed for voice assistant.
This is a post for people who want to run their Box 3 on a VLAN. I originally tried to run the Box 3 on my IoT VLAN without success. When I moved the Box 3 to my regular VLAN where home assistant runs, it worked fine. By using Wireshark, I determined that the Box 3 sent the audio streams to HA on randomly assigned UDP ports. Each audio stream was sent on a different UDP port. By adding firewall rules to allow the audio streams, I was able to get the Box 3 to work on the IoT VLAN. The firewall rule was to allow any UDP traffic from any Box 3 to the HA server.
Just installed the code on my BOX-3 using your recommendations - I added my WiFi settings and removed âname_add_mac_suffix: trueâ because I didnât want to use this setting - but the display shows a sad smiley.
So, almost there⌠is there a way to troubleshoot this? What do I have to look for in the logfiles?
[17:47:05][W][api.connection:107]: : Reading failed: BAD_INDICATOR errno=11
[17:47:06][W][component:214]: Component api took a long time for an operation (0.17 s).
[17:47:06][W][component:215]: Components should block for at most 20-30ms.
Edit: using regular VLAN where Home Assistant also resides.
# Your `my_device` envryption key
esphome_encryption_key: "my_key"
Added the esphome_encryption_key to the my_device.yaml
# Enable Home Assistant API
api:
encryption:
key: !secret esphome_encryption_key
on_client_connected:
- script.execute: reset_display
on_client_disconnected:
Added my WiFi credentials to my_device.yaml from within my_sectrets.yaml
wifi:
ssid: !secret wifi_ssid
# Static IP
manual_ip:
# Set this to the IP of the ESP
static_ip: my_ip
# Set this to the IP address of the router. Often ends with .1
gateway: my_gw
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
dns1: my_gw
dns2: 0.0.0.0
# wifi:
# ap:
# on_connect:
# - delay: 5s # Gives time for improv results to be transmitted
# - ble.disable:
# - script.execute: reset_display
# on_disconnect:
# - ble.enable:
Do you have additional voice satellites? If yes, turn them off.
In any case turn the box off. Restart HA and then turn the box back on.
This did the trick for me when my wakeword was not recognized.
And verify you have a âdefaultâ voice assistant defined in HA.
Logger: aioesphomeapi.connection
Source: runner.py:188
First occurred: 10:07:30 (6 occurrences)
Last logged: 12:53:02
esp32-s3-box-3 @ IP-address: Connection error occurred: [Errno 104] Connection reset by peer
Settings > System >> Logs > ESPHome:
2023-12-02 12:49:41,059 INFO 304 GET /devices (0.0.0.0) 1.03ms
2023-12-02 12:49:45,318 INFO 200 GET /static/js/esphome/c.L2HzI1eb.js (0.0.0.0) 7.29ms
2023-12-02 12:49:45,321 INFO 200 GET /edit?configuration=esp32-s3-box-3.yaml (0.0.0.0) 1.19ms
2023-12-02 12:49:45,403 INFO 200 GET /static/js/esphome/monaco-editor/esm/vs/editor/editor.worker.js (0.0.0.0) 3.64ms
2023-12-02 12:49:45,438 INFO 101 GET /ace (0.0.0.0) 0.78ms
2023-12-02 12:49:45,452 INFO Running command 'esphome --dashboard -q vscode --ace /config/esphome'
2023-12-02 12:49:46,093 INFO 200 GET /static/fonts/codicon.ttf (0.0.0.0) 7.39ms
2023-12-02 12:49:49,363 INFO 200 GET /devices (0.0.0.0) 0.98ms
2023-12-02 12:50:38,782 INFO 304 GET /devices (0.0.0.0) 1.10ms
2023-12-02 12:54:49,363 INFO 200 GET /devices (0.0.0.0) 1.34ms
2023-12-02 12:59:49,363 INFO 200 GET /devices (0.0.0.0) 1.12ms
2023-12-02 13:04:49,364 INFO 200 GET /devices (0.0.0.0) 1.19ms
Seems I have a wireless network issue atm. The log hangs after 255.255.255.0 and box-3 sad face reappears. Will report back asap. Thanks for the help so far.
really indicates an issue with your network connection.
Not sure, why the connection was reset, but it seems, that your box was the device which reset the connection.
You could probably do a test and use your âdefaultâ Wifi rather than configure a manual IP to see, if this would work.
I havenât used Vlan and manual IP configuration on these devices yet - so I canât say for sure, if these are working as expected atm.
Thank you both for helping me out. The log from the box-3 starts with a warning:
INFO ESPHome 2023.11.6
INFO Reading configuration /config/esphome/esp32-s3-box-3.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/5230/head
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
Have read the linked page, but donât know the meaning of it yet, I just donât comprehend the correlation for now.
Box-3 now makes a connection - restored fixed IP - with Home Assistant. I disconnected the Atom Echoâs, but still no interaction from within the box-3.
[17:26:25][D][api:102]: Accepted IP-address_HA
[17:26:25][D][api.connection:1089]: Home Assistant 2023.11.3 (IP-address_HA): Connected successfully
[17:26:25][W][component:214]: Component api took a long time for an operation (0.18 s).
[17:26:25][W][component:215]: Components should block for at most 20-30ms.
