I have upgraded the ESPhome add-on earlier this week to version 2023.3.0 .
Since that moment one of my ESP8266’s, configured as a DSMR interface is generating the following error:
[20:11:08][W][api.connection:085]: 192.168.178.68: Reading failed: BAD_INDICATOR errno=11
[20:11:20][D][api:102]: Accepted 192.168.178.68
[20:11:20][W][api.connection:085]: 192.168.178.68: Reading failed: BAD_INDICATOR errno=11
[20:11:38][D][DmsrCustom:179]: request new message from P1 port
[20:11:38][D][DmsrCustom:084]: Header found
[20:11:38][D][DmsrCustom:092]: Footer found
[20:11:38][D][DmsrCustom:099]: Trying to parse
[20:12:08][D][api:102]: Accepted 192.168.178.68
[20:12:08][W][api.connection:085]: 192.168.178.68: Reading failed: BAD_INDICATOR errno=11
And, more important, all device entities are unavailable
What can be the case here?
Thank you for your help, Yann
I’m not sure if I get it; you’ve removed your device from the HA integration, then did something to the encryption key and then added the device again?
A lot of my sonoff devices fell out of the HA configuration and require re-integration with an encryption key, which I don’t have. All my yaml configuration files have kindly disappeared so I decided to start again. The sonoff controls a radiator valve and I added a AM2302 climate sensor to the unit, so it works as a stand alone temperature controller.
So after reprogramming a sonoff basic, and adding it to ESPHome page in my HA, I get the same error message.
[17:25:39][D][dht:048]: Got Temperature=22.7°C Humidity=38.5%
[17:25:39][D][sensor:093]: 'Music Room Temperature': Sending state 22.70000 °C with 1 decimals of accuracy
[17:25:39][D][sensor:093]: 'Music Room Humidity': Sending state 38.50000 % with 0 decimals of accuracy
[17:25:53][D][api:102]: Accepted 192.168.0.103
[17:25:53][W][api.connection:091]: : Socket operation failed: BAD_INDICATOR errno=11
[17:26:39][D][dht:048]: Got Temperature=22.8°C Humidity=38.6%
The log file shows the sensor is read. I don’t understand the error, nor do I understand the consequences.
Consequences I think are less security if you dont have an encryption key setup. They added this in 2023.12.2 I believe, and heres more info on how to update older devices that helped me out some
I just experienced this issue with my Apollo AIR-1 device after a power outage. The device was still running and accessible over its local network name. But it was not able to report back to Home Assistant.
I was able to recover by doing only the following:
