The problem
I am trying to connect more than one addressable RGB strip to my ESP32 controller running ESPHome.
When I have one neopixelbus light instance (LED1) it runs well. When I try to add a second (LED2) the ESP32 does not boot properly.
The pins should not be the issue. I tried a number of different ones. Always the same behavior no matter which pin I use for the neopixelbus.
substitutions:
# -> LED Output Definitions
LED1_pin: GPIO17
LED1_num_leds: "5"
LED1_type: "GRB"
LED1_variant: "WS2812"
# CRASHES WHEN I ADD THIS:
LED2_pin: GPIO18
LED2_num_leds: "5"
LED2_type: "GRB"
LED2_variant: "WS2812"
light:
- platform: neopixelbus
type: $LED1_type
variant: $LED1_variant
pin: $LED1_pin
num_leds: $LED1_num_leds
name: "LED OUT 1"
type: $LED2_type
variant: $LED2_variant
pin: $LED2_pin
num_leds: $LED2_num_leds
name: "LED OUT 2"
Which version of ESPHome has the issue?
2024.9.2
What type of installation are you using?
Docker
Which version of Home Assistant has the issue?
No response
What platform are you using?
ESP32
Board
Lilygo T-ETH ELite
Component causing the issue
neopixelbus
Example YAML snippet
# PC Desk Controller
substitutions:
# System Definitions
comment: "Modular ESP32 Controller (LED, Switches & More)"
device_name: base-desk-controller
friendly_name: (BASE) Desk Controller
# Controller Variables
LED1_pin: GPIO17
LED1_num_leds: "5"
LED1_type: "GRB"
LED2_pin: GPIO18
LED2_num_leds: "5"
LED2_type: "GRB"
# -> Desk Switch (UP/DOWN)
SW_UP_pin: GPIO08
SW_DOWN_pin: GPIO16
esphome:
friendly_name: ${friendly_name}
comment: ${comment}
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
# Enable logging
logger:
# T-ETH-ELite
ethernet:
type: W5500
clk_pin: GPIO48
mosi_pin: GPIO21
miso_pin: GPIO47
cs_pin: GPIO45
interrupt_pin: GPIO14
#reset_pin: GPIOXX
light:
type: $LED1_type
pin: $LED1_pin
name: "LED OUT 1"
type: $LED2_type
pin: $LED2_pin
name: "LED OUT 2"
switch:
# Desk Switches (UP/DOWN)
- platform: gpio
pin:
number: $SW_DOWN_pin
name: "Desk - DOWN"
icon: "mdi:arrow-expand-down"
- platform: gpio
pin:
number: $SW_UP_pin
name: "Desk - UP"
icon: "mdi:arrow-expand-up"
Anything in the logs that might be useful for us?
INFO ESPHome 2024.9.2
INFO Reading configuration /config/base-desk-controller.yaml...
WARNING GPIO45 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing base-desk-controller (board: esp32-s3-devkitc-1; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Update @ 2.0.0
|-- noise-c @ 0.1.6
|-- NeoPixelBus @ 2.7.3
Compiling .pioenvs/base-desk-controller/src/main.cpp.o
Linking .pioenvs/base-desk-controller/firmware.elf
RAM: [= ] 9.2% (used 30064 bytes from 327680 bytes)
Flash: [==== ] 35.3% (used 647297 bytes from 1835008 bytes)
Building .pioenvs/base-desk-controller/firmware.bin
Creating esp32s3 image...
Successfully created esp32s3 image.
esp32_create_combined_bin([".pioenvs/base-desk-controller/firmware.bin"], [".pioenvs/base-desk-controller/firmware.elf"])
Wrote 0xae200 bytes to file /config/.esphome/build/base-desk-controller/.pioenvs/base-desk-controller/firmware.factory.bin, ready to flash to offset 0x0
esp32_copy_ota_bin([".pioenvs/base-desk-controller/firmware.bin"], [".pioenvs/base-desk-controller/firmware.elf"])
========================= [SUCCESS] Took 5.10 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.178.126
INFO Uploading /config/.esphome/build/base-desk-controller/.pioenvs/base-desk-controller/firmware.bin (647680 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 4.03 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.178.126 using esphome API
WARNING Can't connect to ESPHome API for base-desk-controller @ 192.168.178.126: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.178.126', port=6053))]: [Errno 111] Connect call failed ('192.168.178.126', 6053) (SocketAPIError)
INFO Trying to connect to base-desk-controller @ 192.168.178.126 in the background
Additional information
No response
