ESP32-S3 touch sensor?
I’ve used touch pins on esp32 to change a lamp into a touch-controlled lamp. I’m now trying to use the M5StampS3, which uses the esp32-S3. The ESPHOME document indicates touch works differently on this chip. When I configure a touch pin I get a very high value out, but it doesn’t change at all when I touch the medal the pin is connected. Any idea on configuration to make this works. This is the configuration I’m trying to make work with a touch sensor.
 esphome:
  friendly_name: m5 esp32 s3 orange 1 relay
esp32:
  board: esp32-s3-devkitc-1
  framework:
    #type: arduino
    type: ESP-IDF
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_key
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "FR-Lamp-Touch"
# Enable Web server.
web_server:
  port: 80
captive_portal:
  # hack so the touch sensor doesn't kick off at power on
  - platform: uptime
    update_interval: 30s
esp32_touch:
  setup_mode: true
binary_sensor:
  - platform: esp32_touch
    name: "ESP32 Touch Pad GPIO5"
    pin: GPIO5
    threshold: 290
    filters:
      # Small filter, to debounce the spurious events.
      - delayed_on: 10ms
      - delayed_off: 10ms
    #on_press:
    on_click:
    - min_length: 10ms
      max_length: 500ms
      # Short touch to turn light on and off
      then:
        if:
          # test to ignore random event on boot
          condition:
            - lambda: 'return  id(time_since_boot).raw_state > 10;'
          then:
            - button.press: pwr_btn
# restart-button
button:
  - platform: restart
    on_press:
      then:
        if:
          condition:
            and:
              # if light is off
              - switch.is_off: light_state
          then:
            # then we turn it on
            - switch.turn_on: light_state
          else:
            # else it's on so we turn it off
            - switch.turn_off: light_state
switch:
  - platform: gpio
    pin: GPIO7
Hi Brian!
I just upgraded a previsiously-installed traditional ESP32 to an ESP32-S3-16/8.
In my case, the values initially were huge (significantly larger than before) and didn’t appear to change at all. The trick that worked for me was to adjust the measurement_duration value down from the default 4ms to 0.25ms. Once I did that, the values were still pretty large numbers, but changed quite reliably.
esp32_touch:
  setup_mode: false
  measurement_duration: 0.25ms
binary_sensor:
    pin: 4
    threshold: 1100000
    pin: 5
    threshold: 1300000
I’ve got ~1m lead wires running to from the ESP32-S3 to the touchpads. For me, TouchPad1 sits idle at ~ 573,000 and goes up to ~1675000 when touched. TouchPad2 sits idle at ~677000 and goes up to ~1530000 when touched.
Great. I’ll give it a try.
That worked great. Thanks much.
