ESP32-S3 Wifi sometimes working sometimes not / esp32-S3-DevkitC wifi problem [Solved]
Hello Hello !!
I am a beginner on Home Assitant and ESPHome, trying to make my first device to control a relay based on humidity measurement. I am facing a major issue trying to make the first step:
Connect my ESP32-S3 to wifi. I have went through everything I have found about that on internet for days now but still not able to make it. I will try to explain as precisely as I can the problem I encounter:
When I create a new device, I connect to my ESP32-S3 using USB cable using ESPHome Web (Web - ESPHome).
I click on ā€œPrepare for first useā€, proceed to install successfully, I then configure wi-fi.
And it works, I can even visit the device locally on 192.168.1.20)
I can see my esp32 being connected to my 2.4GHz wifi on my route; The IP has been automatically attributed via the DHCP:
Sans titre5
So it looks the ESP32 is well able to connect to my wifi using dynamic IP.
Now let’s install my yaml file (I continue to use ESPHome Web, so manually download the .bin file):
esphome:
  friendly_name: "vmc-controller"
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
api:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "ESP32-VMC-CONTROLLER-HOTSPOT"
    password: "password"
captive_portal:
logger:
  level: ERROR
ota:
  platform: esphome
improv_serial:
Again, the configuration is successfully installed:
So I have verified before installing my yaml configuration that the ESP32 is able to connect to the wifi, so it should be able to connect to my wifi now right ?
Well this is not what is happening, impossible to connect to ESP32.
I cannot connect anymore to my ESP32…
So I went through a lot of forum, it often recommends to provide a manual IP (it should not be needed as earlier I could connect using DHCP but well, let’s try). Let’s update the yaml file:
esphome:
esp32:
  framework:
    type: arduino
api:
wifi:
  manual_ip:
    static_ip: 192.168.1.201
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
captive_portal:
logger:
  level: ERROR
ota:
  platform: esphome
improv_serial:
I install again successfully using ESPHome Web interface but it still doesn’t work.
I’m having this problem for days now without being able to understand what I’m doing wrong, I therefore come here with the hope of getting some support ! :grinning:
Please, tell me what I’m doing wrong !
Note I have verified many many many times the SSID and the password of the Secrets are correct.
Please format your code correctly. No one can help you if there’s an indentation error with the code as it’s currently displayed.
Also, double check your IPs. You first mention connecting successfully on 1.20, then when you say you can’t connect your manual IP code shows 1.201
Hello ! Sorry for the formating, it’s corrected now :slight_smile:
About the IP address, I’m not that good (let’s say, not at all) with that kind of things but my understanding is that the manual IP (so 192.168.1.201) has to be out of the range of the DHCP server defined in my router (from 192.168.1.10 to 192.168.1.200)/
This is the reason why I have used 192.168.1.201.
firmware updates use the devices hostname. More than likely your network does not resolve the devices hostname to a correct IP.
add a use_address
domain (Optional, string): Set the domain of the node hostname used for uploading. For example, if it’s set to .local, all uploads will be sent to <HOSTNAME>.local. Defaults to .local.
Using DHCP on esphome devices just calls for problems. Change that to static IP first. And always use only static IP’s in all HA related devices, if you can’t set static IP to a certain device then reserve it’s IP in router.
Hello ! Thank you very much for your answers, I have tried to apply them (not sure I did properly but I think yes).
So I have re-done the ā€œprepare for first useā€ on my esp32 using esphome web so that I could see my esp32 on my modem. Once I saw it there, I have reserved the IP address it was using (192.168.1.20 here).
Once this done, I have also updated the yaml file as below, to add the domain (not sure if tmjpugh you were talking of use_address or domain, but I’m not sure how to use the use_address and so what I should put in this field):
Note that I have updated the hostname to a simpler one without any dash or underscore, just in case.
esphome:
  friendly_name: vmc
esp32:
wifi:
  manual_ip:
    static_ip: 192.168.1.20  # Replace with an unused IP in your network
    gateway: 192.168.1.1      # Replace with your router's IP
    subnet: 255.255.255.0     # Typically this is correct for most home networks
  domain: .vmc.local
captive_portal:
logger:
api:
  encryption:
    key: "Wh0n3sUY8JYAgTLvxqG+CuQgTc88FAcE2/tL3gQ8Xrk="
switch:
  - platform: gpio
    pin: GPIO6
Unfortunaly, it still doesn’t work.
Once I have uploaded the factory file using esphome, the esp32 is not able to connect to my modem/router:
Do you have any idea of something I could have badly implemented here ?
Again, many thanks for your help ! Even though I still don’t succeed, I have the feeling I’m going in the right direction… hopefully :sweat_smile:
Delete the line with ā€œdomainā€ and try again
Exact same result
esphome:
  friendly_name: vmc
esp32:
wifi:
  manual_ip:
captive_portal:
logger:
api:
  encryption:
switch:
  - platform: gpio
    pin: GPIO6
wifi:
  manual_ip:
  domain: .vmc.local
  use_address: 192.168.1.20
Just tried that one too, with and without the domain, and it does not work… Always the same problem of ESP32 not connecting to wifi:
[21:27:33][D][wifi:697]: Retrying with hidden networks…
[21:27:33][I][wifi:313]: WiFi Connecting to ā€˜Livebox-9200’…
[21:27:34][W][wifi_esp32:545][arduino_events]: Event: Disconnected ssid=ā€˜Livebox-9200’ bssid=AC:CF:7B:FF:92:00[redacted] reason=ā€˜Auth Expired’ [21:27:34][W][wifi:653]: Error while connecting to network.
[21:27:34][D][wifi:697]: Retrying with hidden networks…
Do you think buying another router than the one provided by my internet provider might be an easy way to fix this issue ?
Seems to be an issue with the board you use
Adding this might help
wifi:
  output_power: 8.5
IT WORKS !
The output_power: 8.5 fixed it ! :smiley:
Many thanks for your help !
Any recommandation in term of board I should use for next time that does not have this kind of problem ?
Glad to be of help.
No real suggestions, I’m using esp32-pico d4 for most of my projects, two years ago those were quite cheap, so bought a few and still using them, no issues with those.
Anyway, your problem is solved.
Wroom32 is always best choice if there are no special requirements.
Ps. mark your post solved.
