I have the board ESP32-S3-WROOM-1-N16R8 and PN532 Blue board (same in PN532 NFC/RFID — ESPHome)
The switch on PN532 is configured same as the image for SPI mode
Wiring diagram:
esp32-s3-wroom-1-N16R8 PN532 BLUE Version
GPIO13/SCK ------------------------------ SCK
GPIO11/MISI ------------------------------ MI
GPIO12/MISO ----------------------------- MO/SDA/TX
GPIO10/SS --------------------------------- NSC/SCL/RX
GND ------------------------------------------ GND
5V --------------------------------------------- 5V
Here is ESPHOME config
esphome:
friendly_name: ESP32-S3-WROOM-1-N16R8
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
# Enable logging
logger:
web_server:
port: 80
# Enable Home Assistant API
api:
encryption:
key: "/oAGdSpUJSkfYsHsZ9JJmAVHFv1Lxj3I0clPn6gEZx4="
ota:
password: "1f28aca325cee5a069b9ba3459912fb4"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp32-S3 Fallback Hotspot"
password: "BR6eQssNJSDF"
captive_portal:
spi:
clk_pin: GPIO10
miso_pin: GPIO12
mosi_pin: GPIO11
pn532_spi:
cs_pin: GPIO13
update_interval: 1s
binary_sensor:
- platform: pn532
uid: 74-10-37-94
name: "PN532 NFC Tag"
- platform: pn532
uid: 53-ED-E6-AC-00-00-00
- platform: pn532
uid: 53-ED-E6-AC
name: "New prefix tag"
I’m using ESPHome 2023.10.1
Here is the log:
INFO ESPHome 2023.10.1
INFO Reading configuration /config/esphome/esp32-s3.yaml...
INFO Starting log output from esp32-s3.local using esphome API
INFO Successfully connected to esp32-s3.local
[13:48:12][I][app:102]: ESPHome version 2023.10.1 compiled on Oct 21 2023, 13:31:52
[13:48:12][C][wifi:546]: WiFi:
[13:48:12][C][wifi:382]: Local MAC: FILTERED
[13:48:12][C][wifi:383]: SSID: [redacted]
[13:48:12][C][wifi:384]: IP Address: FILTERED
[13:48:13][C][wifi:386]: BSSID: [redacted]
[13:48:13][C][wifi:387]: Hostname: 'esp32-s3'
[13:48:13][C][wifi:389]: Signal strength: -47 dB ▂▄▆█
[13:48:13][C][wifi:393]: Channel: 1
[13:48:13][C][wifi:394]: Subnet: 255.255.255.0
[13:48:13][C][wifi:395]: Gateway: FILTERED
[13:48:13][C][wifi:396]: DNS1: FILTERED
[13:48:13][C][wifi:397]: DNS2: 0.0.0.0
[13:48:13][C][logger:361]: Logger:
[13:48:13][C][logger:362]: Level: DEBUG
[13:48:13][C][logger:363]: Log Baud Rate: 115200
[13:48:13][C][logger:365]: Hardware UART: UART0
[13:48:13][C][spi:067]: SPI bus:
[13:48:13][C][spi:068]: CLK Pin: GPIO10
[13:48:13][C][spi:069]: SDI Pin: GPIO12
[13:48:13][C][spi:070]: SDO Pin: GPIO11
[13:48:13][C][spi:072]: Using HW SPI: SPI
[13:48:13][C][pn532:375]: PN532:
[13:48:13][C][pn532:387]: Update Interval: 1.0s
[13:48:13][C][pn532:390]: Tag 'PN532 NFC Tag'
[13:48:13][C][pn532:390]: Tag 'New Tag'
[13:48:13][C][pn532:390]: Tag 'New prefix tag'
[13:48:13][C][pn532_spi:156]: CS Pin: GPIO13
[13:48:13][C][captive_portal:088]: Captive Portal:
[13:48:13][C][web_server:161]: Web Server:
[13:48:13][C][web_server:162]: Address: esp32-s3.local:80
[13:48:13][C][mdns:115]: mDNS:
[13:48:13][C][mdns:116]: Hostname: esp32-s3
[13:48:13][C][ota:097]: Over-The-Air Updates:
[13:48:13][C][ota:098]: Address: esp32-s3.local:3232
[13:48:13][C][ota:101]: Using Password.
[13:48:13][C][api:138]: API Server:
[13:48:13][C][api:139]: Address: esp32-s3.local:6053
[13:48:13][C][api:141]: Using noise encryption: YES
However, when I approach the NFC tag, no message in the log for new tag. The tag is working on phone, I can read the uid by using NFC tool app.
Could you please help to check if
- the wiring diagram is OK?
- ESPHOME config is OK?
Thanks for your help.
