Hello folks.
I’m trying to setup the MQTT connection on ESP32 in C++, but without a luck. Not receiving any messages on the HASS side.
Device is connected to wifi and same network as the HASS
This comes from this cool project: https://savjee.be/blog/home-energy-monitor-v2/#integrating-with-home-assistant
Could you please advise if there’s any issue with the below?
Thanks in advance.
#ifndef TASK_HOME_ASSISTANT
#define TASK_HOME_ASSISTANT
#if HA_ENABLED == true
#include <Arduino.h>
#include <WiFiClientSecure.h>
#include <MQTTClient.h>
#include "../config/config.dist.h"
WiFiClientSecure HA_net;
MQTTClient HA_mqtt(1024);
extern unsigned short measurements[];
const char* PROGMEM HA_discovery_msg = "{"
"\"name\":\"" DEVICE_NAME "\","
"\"device_class\":\"power\","
"\"unit_of_measurement\":\"W\","
"\"icon\":\"mdi:transmission-tower\","
"\"state_topic\":\"homeassistant/sensor/" DEVICE_NAME "/state\","
"\"value_template\":\"{{ value_json.power}}\","
"\"device\": {"
"\"sw_version\":\"1.0\","
"\"model\":\"V1\","
"\"manufacturer\":\"HackTest\","
"\"identifiers\":[\"" DEVICE_NAME "\"]"
* Established a connection to Home Assistant MQTT broker.
* This task should run continously. It will check if an
* MQTT connection is active and if so, will sleep for 1
* minute. If not, a new connection will be established.
void keepHAConnectionAlive(void * parameter){
for(;;){
// When we are connected, loop the MQTT client and sleep for 0,5s
if(HA_mqtt.connected()){
HA_mqtt.loop();
vTaskDelay(250 / portTICK_PERIOD_MS);
continue;
if(!WiFi.isConnected()){
vTaskDelay(1000 / portTICK_PERIOD_MS);
continue;
serial_println(F("[MQTT] Connecting to HA..."));
HA_mqtt.begin(HA_ADDRESS, HA_PORT, HA_net);
long startAttemptTime = millis();
while (!HA_mqtt.connect(DEVICE_NAME, HA_USER, HA_PASSWORD) &&
millis() - startAttemptTime < MQTT_CONNECT_TIMEOUT)
vTaskDelay(MQTT_CONNECT_DELAY / portTICK_PERIOD_MS);
if(!HA_mqtt.connected()){
serial_println(F("[MQTT] HA connection failed. Waiting 30s.."));
vTaskDelay(30000 / portTICK_PERIOD_MS);
serial_println(F("[MQTT] HA Connected!"));
* TASK: Every 15 minutes we send Home Assistant a discovery message
* so that the energy monitor shows up in the device registry.
void HADiscovery(void * parameter){
for(;;){
serial_println("[MQTT] HA: no MQTT connection.");
vTaskDelay(30 * 1000 / portTICK_PERIOD_MS);
continue;
serial_println("[MQTT] HA sending auto discovery");
HA_mqtt.publish("homeassistant/sensor/" DEVICE_NAME "/config", HA_discovery_msg);
vTaskDelay(15 * 60 * 1000 / portTICK_PERIOD_MS);
void sendEnergyToHA(void * parameter){
serial_println("[MQTT] Can't send to HA without MQTT. Abort.");
vTaskDelete(NULL);
char msg[30];
strcpy(msg, "{\"power\":");
strcat(msg, String(measurements[LOCAL_MEASUREMENTS-1]).c_str());
strcat(msg, "}");
serial_print("[MQTT] HA publish: ");
serial_println(msg);
HA_mqtt.publish("homeassistant/sensor/" DEVICE_NAME "/state", msg);
// Task is done!
vTaskDelete(NULL);
#endif
#endif
