Hi, Guillermo.
It works fine now with DEV branch !
Thank you
Hi, Guillermo.
Thank you
I’ve got two of these boards and can’t seem to get them to flash ESPHome properly at all - is there a trick I’ve missed?
Mine both just start boot looping after what appears to be a successful flash. ESPHome’s Git repo has an issue #598 that was apparently resolved with the latest flashing tool but it hasn’t worked for me.
Sorry if I’ve missed something obvious; it’s my first ESP32 and it seems these are totally different beasts to their older siblings!
EDIT: Fixed. Silly YAML.
Does that mean switching the ESPHome HA addon to the Dev one?
EDIT: Yep, answered my own question
Ready to smash this thing to pieces
I had the SMS element working flawlessly on this but now it doesn’t seem to work at all - I’m getting a weird problem where it’s pulling messages from long ago rather than the message it’s actually receiving. Some of them very old indeed. Very similar to this issue, but I can’t seem to fix. I’ve also had it send repeated messages until it burned its way through £10 worth of credit when it was only supposed to text once!
I thought if I incorporated the right AT command (tried the below combinations) I could include an automation to clear old messages but I can’t seem to get the syntax right and just get ‘Not Ack’ back.
It’s definitely not power related - it’s running off an 18650.
Has anyone else had issues like this?
The driver if far from perfect and not so well tested in different conditions. Mine works ok. I receive one or two gvmnt sms daily.
You can try loading the sim on a phone and make sure there are no stored messages on it. That can be confusing the driver.
Did anyone here tried implementing battery reading percentage?
Thank you all
I has worked for me:
switch:
uart:
baud_rate: 9600
tx_pin: 27
rx_pin: 26
It’s unbelievable how fast I managed to make this work thanks to your comments
Thank you
and signal strength?
Would you have found a way to know:
I found that, it should be adapted to ESPHOME
Thank you
Hello. Please tell me. Need to:
Thank you
esphome:
friendly_name: TTGO T-Call
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "******"
services:
- service: send_sms
variables:
recipient: string
message: string
then:
- sim800l.send_sms:
recipient: !lambda 'return recipient;'
message: !lambda 'return message;'
- service: dial
variables:
recipient: string
then:
- sim800l.dial:
- service: connect
then:
- sim800l.connect
- service: disconnect
then:
- sim800l.disconnect
- service: send_ussd
variables:
ussdCode: string
then:
- sim800l.send_ussd:
ussd: !lambda 'return ussdCode;'
text_sensor:
uart:
baud_rate: 9600
tx_pin: 27
rx_pin: 26
sim800l:
on_sms_received:
- lambda: |-
id(sms_sender).publish_state(sender);
id(sms_message).publish_state(message);
on_incoming_call:
- logger.log:
format: "Incoming call from '%s'"
args: ["caller_id.c_str()"]
- lambda: |-
id(caller_id_text_sensor).publish_state(caller_id);
- homeassistant.event:
event: esphome.incoming_call_event
payload: !lambda 'return id(caller_id_text_sensor).state;'
on_call_connected:
- logger.log:
format: Call connected
on_call_disconnected:
- logger.log:
format: Call disconnected
on_ussd_received:
- lambda: |-
id(ussd_message).publish_state(ussd);
switch:
- platform: gpio
pin: 4
restore_mode: ALWAYS_OFF
internal: true
- platform: gpio
pin: 5
restore_mode: ALWAYS_ON
internal: true
- platform: gpio
pin: 23
internal: true
