I just tried flashing my new ESP32 and its throwing an exception and halting, and I can’t see what I am doing wrong in the yaml code to cause this, does anyone know what in here I messed up to break this? I’ve tried commenting out segments to find it, like the entire stepper sequence but most of it is pretty much copy paste so I am unsure where the issue is.
Using 'COM3' as serial port.
)Writing at 0x00088000... (100 %)Wrote 897520 bytes (501499 compressed) at 0x00010000 in 44.5 seconds (effective 161.5 kbit/s)...
Hash of data verified.
Leaving...
Hard Resetting...
Done! Flashing is complete!
Showing logs:
[18:10:17]ets Jun 8 2016 00:22:57
[18:10:17]
[18:10:17]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[18:10:17]configsip: 0, SPIWP:0xee
[18:10:17]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[18:10:17]mode:DIO, clock div:2
[18:10:17]load:0x3fff0018,len:4
[18:10:17]load:0x3fff001c,len:952
[18:10:17]load:0x40078000,len:6084
[18:10:17]load:0x40080000,len:7944
[18:10:17]entry 0x40080310
[18:10:17][I][logger:116]: Log initialized
[18:10:17][E][Preferences.cpp:457] getBytes(): nvs_get_blob len fail: 0 NOT_FOUND
[18:10:17][C][ota:364]: There have been 0 suspected unsuccessful boot attempts.
[18:10:17][I][app:028]: Running through setup()...
[18:10:17][C][a4988.stepper:010]: Setting up A4988...
[18:10:17][E][Preferences.cpp:457] getBytes(): nvs_get_blob len fail: 1 NOT_FOUND
[18:10:17]Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited). Exception was unhandled.
Code:
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: !secret AP
password: !secret APPW
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret OTA_PW
ota:
i2c:
sda: GPIO21
scl: GPIO22
scan: False
- platform: adc
pin: A0
unit_of_measurement: "V"
- platform: adc
pin: A3
- platform: bme280
temperature:
name: "MiniTank Temperature"
oversampling: 16x
unit_of_measurement: "°C"
pressure:
name: "MiniTank Pressure"
unit_of_measurement: "P"
humidity:
name: "MiniTank Humidity"
unit_of_measurement: "%"
address: 0x77
update_interval: 60s
- platform: tcs34725
red_channel:
name: "TCS34725 Red Channel"
green_channel:
name: "TCS34725 Green Channel"
blue_channel:
name: "TCS34725 Blue Channel"
clear_channel:
name: "TCS34725 Clear Channel"
illuminance:
name: "TCS34725 Illuminance"
color_temperature:
name: "TCS34725 Color Temperature"
gain: 1x
integration_time: 2.4ms
address: 0x29
- platform: homeassistant
entity_id: sensor.mt_feeder_toggle
on_value_range:
- above: 50.0
then:
- stepper.report_position:
position: 0
- stepper.set_target:
target: 0
target: 1000
# Individual outputs
output:
- platform: ledc
pin: GPIO8
- platform: ledc
pin: GPIO9
- platform: ledc
pin: GPIO10
- platform: ledc
pin: GPIO11
- platform: ledc
pin: GPIO3
- platform: ledc
frequency: 120
pin: GPIO4
- platform: ledc
frequency: 120
pin: GPIO5
light:
- platform: rgbw
red: R
green: G
blue: B
white: W
- platform: monochromatic
output: 'Pump'
output: 'Htr'
output: 'Air'
stepper:
- platform: a4988
step_pin: GPIO0
dir_pin: GPIO1
max_speed: 250 steps/s
# Optional:
sleep_pin: GPIO2
acceleration: inf
deceleration: inf
