been running this config on 2 boards just added a 3rd
esphome:
friendly_name: Voice Assistant TARDIS
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "*******************************************"
ota:
password: "*************************************"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.131
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Voice-Assistant-Tardis"
password: "C8EfVtX6IiVQ"
captive_portal:
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: GPIO26 #WS
i2s_bclk_pin: GPIO25 #SCK
microphone:
- platform: i2s_audio
adc_type: external
pdm: false
channel: right
bits_per_sample: 32bit
i2s_audio_id: i2s_in
i2s_din_pin: GPIO33 #SD Pin from the INMP441 Microphone
media_player:
dac_type: external
i2s_dout_pin: GPIO27 # DIN Pin of the MAX98357A Audio Amplifier
mode: mono
voice_assistant:
microphone: mic_i2s
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 4.0
use_wake_word: false
media_player: media_player_speaker
on_wake_word_detected:
- light.turn_on:
on_listening:
- light.turn_on:
effect: "Slow Pulse"
red: 0%
green: 0%
blue: 100%
brightness: 100%
on_stt_end:
- light.turn_on:
effect: "None"
red: 0%
green: 100%
blue: 0%
brightness: 100%
on_error:
- light.turn_on:
effect: "None"
red: 100%
green: 0%
blue: 0%
- if:
condition:
switch.is_on: use_wake_word
then:
- switch.turn_off: use_wake_word
- delay: 1sec
- switch.turn_on: use_wake_word
on_client_connected:
- if:
condition:
then:
- voice_assistant.start_continuous:
on_client_disconnected:
- if:
condition:
then:
- voice_assistant.stop:
on_end:
- light.turn_off:
binary_sensor:
- platform: status
name: API Connection
filters:
- delayed_on: 1s
on_press:
- if:
condition:
then:
on_release:
- if:
condition:
then:
switch:
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
entity_category: config
on_turn_on:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- lambda: id(va).set_use_wake_word(false);
light:
- platform: neopixelbus
type: grb
pin: GPIO32 # DIN pin of the LED Strip
num_leds: 6 # change the Number of LEDS according to your LED Strip.
variant: ws2812x
default_transition_length: 0.5s
effects:
- pulse:
transition_length: 500ms
update_interval: 500ms
min_brightness: 50%
max_brightness: 100%
- pulse:
transition_length: 100ms
update_interval: 100ms
min_brightness: 50%
now getting this error
[15:43:43][W][component:214]: Component api took a long time for an operation (0.05 s).
[15:43:43][W][component:215]: Components should block for at most 20-30ms.
[15:43:43][D][api.connection:1089]: Home Assistant 2023.12.3 (192.168.1.162): Connected successfully
[15:43:43][E][voice_assistant:375]: Multiple API Clients attempting to connect to Voice Assistant
[15:43:43][E][voice_assistant:376]: Current client: Home Assistant 2023.12.3 (192.168.1.162)
[15:43:43][E][voice_assistant:377]: New client: Home Assistant 2023.12.3 (192.168.1.162)
[15:44:12][W][api.connection:102]: Home Assistant 2023.12.3 (192.168.1.162): Connection reset
[15:44:12][D][voice_assistant:422]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[15:44:12][D][voice_assistant:428]: Desired state set to IDLE
[15:44:12][D][voice_assistant:422]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[15:44:12][D][voice_assistant:422]: State changed from STOPPING_MICROPHONE to IDLE
after this the devices stop working unless I turn on/off the things
