Hello, I kindly need a functional YAML configuration for ESP32 with INMP441, which I want to use only as an I2S microphone for monitoring noise levels in a room. I don’t need a YAML for a complete voice assistant. Thank you.
esphome:
friendly_name: esp32_02
esp32:
board: esp32dev
framework:
type: arduino
external_components:
- source: github://stas-sl/esphome-sound-level-meter
# Enable logging
logger:
level: DEBUG
logs:
i2s: DEBUG
microphone: DEBUG
sound_level_meter: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
fast_connect: true
ap:
ssid: "Esp32-02 Fallback Hotspot"
password: "eVv4rVmMxxfi"
captive_portal:
# INMP441 I²S-MEMS-Mikrofon (Arduino-Framework)
# SD → GPIO21
# WS → GPIO15
# SCK → GPIO14
# VDD → 3V3
# GND → GND
i2s:
bck_pin: GPIO18 # Serial Clock (SCK)
ws_pin: GPIO22 # Word Select (WS)
din_pin: GPIO21 # Serial Data (SD)
sample_rate: 48000 # 48 kHz
bits_per_sample: 32 # 32 Bit (MIC liefert 24 Bit + 8 Bit Padding)
bits_shift: 8 # Rechts‐Shift um 8 Bit für 24→32 Bit Alignment
use_apll: true # Optional: präziserer Takt
# Sound Level Meter (External Component)
sound_level_meter:
update_interval: 1s
buffer_size: 1024
warmup_interval: 500ms
mic_sensitivity: -26dB
mic_sensitivity_ref: 94dB
offset: 0dB
groups:
- sensors:
- type: eq
# Schalter zum Ein/Abschalten des Sound-Meters
switch:
name: "Decibel Meter ON/OFF"
lambda: |-
return id(sound_level_meter1).is_on();
turn_on_action:
- sound_level_meter.turn_on: sound_level_meter1
turn_off_action:
- sound_level_meter.turn_off: sound_level_meter1
restore_mode: RESTORE_DEFAULT_ON
- platform: restart
name: "Decibel Meter Reset"
# System-Sensoren
- platform: wifi_signal
update_interval: 60s
binary_sensor:
- platform: status
This works as DB Meter.
You made my day … was able with your code to implement 2 soundmeters !!!
many many thanks !
Fred.
