ESP32 wont boot with 3,3v from battery 18650
Hi all
I have a simple moisture sensor code, it works good since weeks on two esp8266 nodemcu and the following powering circuit (3,3v from battery/solar power and LDO as described in this link Power ESP32/ESP8266 with Solar Panels and Battery | Random Nerd Tutorials)
Now I’ve tried this same code in 2 different ESP32 WROOM board using the same powering circuit:
but with this boards and this powering circuit the device wont connect to the WIFI and it appears OFFLINE, while if I supply the device with 5V from usb port it works as expected.
How do you power your ESP32 project from battery?
Is there something I’m missing or doing wrong with ESP32 boards?
P.S. with Arduino code and same board/powering circuit the wifi connection works well …
Thanks very much anyone could help
esphome:
  platform: ESP32
  board: mhetesp32minikit
  #board: esp32doit-devkit-v1
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "4ac70b8af3f1d483e0b1b53726cfdbd0"
wifi:
  ssid: !secret wifi_username
  #output_power: 10
# Deep Sleep Feature. Needs adjustments...
#deep_sleep:
#  run_duration: 30s
#  sleep_duration: 60min
  - platform: adc
    pin: GPIO35
    name: esp32 Soil Moisture Value
    update_interval: 3s
    unit_of_measurement: "%"
    accuracy_decimals: 0
    icon: "mdi:flower"
    attenuation: 11db
    filters:
    - median:
        window_size: 7
        send_every: 4
        send_first_at: 1
    - calibrate_linear:
        - 3.04 -> 0.00
        - 1.30 -> 100.00
    - lambda: |
        if (x < 0) return 0;
        else if (x > 100) return 100;
        else return (x);
binary_sensor:
    name: esp32 Soil Moisture Status
    device_class: moisture
    #Change this value to determine desire wetness of soil
    lambda: |-
        if (id(esp32_soil_sensor_value).state > 35) {
          return true;
        } else {
          return false;
  - platform: status
    name: esp32 Soil Moisture Online
My guess is there is not enough current output from the LDO, the max on the MCP1700 is 250ma, and I do not think that is enough to power an ESP32 dual core board, try using a LD1117AV33 instead, it can support 1000ma
