Hello, ESPHome keeps failing to compile.
It’s always this error:
xtensa-esp32-elf-g++: internal compiler error: Killed (program cc1plus)
This started happening when I updated Home Assistant to 2022.11.3, and ESPHOME to version 2022.11.1. I did have a working ESP32 working but that is also having the same error. So I’ve come to conclude it is something with the software.
Any help would be helpful. Thanks
Things I’ve tried:
-rebooting Home assistant
-trying different ESP32s
-restarting ESPHOME
-reinstalling ESPHOME
===INFORMATION===
Home Assistant 2022.11.3
Supervisor 2022.10.2
Operating System 9.3
Frontend 20221108.0 - latest
ESPHOME 2022.11.1
===CODE===
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-0Edb00"
password: "90ZIt4EGiof3"
captive_portal:
===LOGS===
INFO Reading configuration /config/esphome/esphome-web-0edb00.yaml...
INFO Generating C++ source...
INFO Core config or version changed, cleaning build files...
INFO Deleting /data/esphome-web-0edb00/.pioenvs
INFO Deleting /data/esphome-web-0edb00/.piolibdeps
INFO Compiling app...
Processing esphome-web-0edb00 (board: esp32dev; framework: arduino; platform: platformio/espressif32 @ 3.5.0)
Library Manager: Installing esphome/AsyncTCP-esphome @ 1.2.2
INFO Installing esphome/AsyncTCP-esphome @ 1.2.2
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- AsyncTCP-esphome @ 1.2.2
|-- WiFi @ 1.0
|-- FS @ 1.0
|-- Update @ 1.0
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 1.1.0
|-- ESPmDNS @ 1.0
Compiling /data/esphome-web-0edb00/.pioenvs/esphome-web-0edb00/src/esphome/components/api/api_connection.cpp.o
Compiling /data/esphome-web-0edb00/.pioenvs/esphome-web-0edb00/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/esphome-web-0edb00/.pioenvs/esphome-web-0edb00/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/esphome-web-0edb00/.pioenvs/esphome-web-0edb00/src/esphome/components/api/api_pb2_service.cpp.o
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
*** [/data/esphome-web-0edb00/.pioenvs/esphome-web-0edb00/src/esphome/components/api/api_pb2.cpp.o] Error 4
========================= [FAILED] Took 34.92 seconds =========================
