I have followed all the steps on this page. However, I can’t get my ESP to work as a proxy. It is found in the ESP dashboard, it is online there, I also find it with the ESP integration. But I can’t find any BT-devices.
INFO ESPHome 2024.7.3
INFO Reading configuration /config/esphome/woonkamer.yaml...
esphome:
friendly_name: Woonkamer
build_path: build/woonkamer
area: ''
platformio_options: {}
includes: []
libraries: []
name_add_mac_suffix: false
min_version: 2024.7.3
esp32:
board: esp32dev
framework:
version: 2.0.5
source: ~3.20005.0
platform_version: platformio/[email protected]
type: arduino
flash_size: 4MB
variant: ESP32
logger:
baud_rate: 115200
tx_buffer_size: 512
deassert_rts_dtr: false
hardware_uart: UART0
level: DEBUG
logs: {}
api:
encryption:
key: <key>
port: <port>
password: ''
reboot_timeout: 15min
ota:
- platform: esphome
password: <password>
version: 2
port: 3232
wifi:
ap:
ssid: <SSID>
ap_timeout: 1min
domain: .local
power_save_mode: LIGHT
fast_connect: false
passive_scan: false
enable_on_boot: true
networks:
- ssid: <SSID>
password: '<password>'
priority: 0.0
use_address: woonkamer.local
captive_portal: {}
INFO Configuration is valid!
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "<key>"
ota:
- platform: esphome
password: "<password>"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Woonkamer Fallback Hotspot"
captive_portal:
