yes, you are right sorry for not thinking about this before. Here is the config file…
esphome:
platform: ESP32
board: esp32dev
# Enable logging
logger:
level: VERY_VERBOSE
# Enable Home Assistant API
# api:
mqtt:
broker: 192.168.1.30
port: 1883
username: mqttuser
password: *********
ota:
password: "*************"
wifi:
ssid: !secret wifi_ssid
power_save_mode: NONE
fast_connect: true
reboot_timeout: 45min
# Optional manual IP
manual_ip:
static_ip: 192.168.1.36
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Hoesp32V4 Fallback Hotspot"
captive_portal:
switch:
- platform: gpio
pin: 32
inverted: no
restore_mode: ALWAYS_OFF
- platform: gpio
pin: 33
inverted: no
- platform: gpio
pin: 25
inverted: no
- platform: gpio
pin: 26
inverted: no
- platform: gpio
pin: 27
inverted: yes
restore_mode: ALWAYS_ON
- platform: gpio
pin: 14
inverted: yes
- platform: gpio
pin: 12
inverted: no
- platform: gpio
pin: 13
inverted: no
here are the logs, first switched on “holc1” which is the ceiling light then I switch on “1u” which is a fan at low speed, then I toggle to “2u” which is medium speed. This is when everything goes off, Looks like the MCU has reset. Same result when I toggle the fan speed switches manually instead of the automation.
[19:37:22][D][switch:013]: 'holc1' Turning ON.
[19:37:22][D][switch:037]: 'holc1': Sending state ON
[19:37:22][VV][scheduler:026]: set_timeout(name='send', timeout=0)
[19:37:22][VV][scheduler:185]: Running timeout 'send' with interval=0 last_execution=27204 (now=27217)
[19:37:22][V][mqtt:404]: Publish(topic='hoesp32v4/switch/holc1/state' payload='ON' retain=1)
[19:37:24][D][switch:017]: 'fu' Turning OFF.
[19:37:24][D][switch:017]: '3u' Turning OFF.
[19:37:25][D][switch:017]: '2u' Turning OFF.
[19:37:25][D][switch:013]: '1u' Turning ON.
[19:37:25][D][switch:037]: '1u': Sending state ON
[19:37:25][VV][scheduler:026]: set_timeout(name='send', timeout=0)
[19:37:25][VV][scheduler:185]: Running timeout 'send' with interval=0 last_execution=29852 (now=29867)
[19:37:25][V][mqtt:404]: Publish(topic='hoesp32v4/switch/1u/state' payload='ON' retain=1)
[19:37:30][VV][scheduler:185]: Running interval '' with interval=60000 last_execution=4294941655 (now=34362)
[19:37:36][D][switch:017]: 'fu' Turning OFF.
[19:37:37][D][switch:017]: '3u' Turning OFF.
[19:37:37][D][switch:017]: '1u' Turning OFF.
[19:37:41][I][mqtt:214]: MQTT Connected!
[19:37:41][V][mqtt:309]: subscribe(topic='hoesp32v4/switch/1u/command')
[19:37:41][V][mqtt.component:062]: '1u': Sending discovery...
[19:37:41][V][mqtt:404]: Publish(topic='homeassistant/switch/hoesp32v4/1u/config' payload='{"name":"1u","stat_t":"hoesp32v4/switch/1u/state","cmd_t":"hoesp32v4/switch/1u/command","avty_t":"hoesp32v4/status","uniq_id":"ESPswitch1u","dev":{"ids":"943cc611cd94","name":"hoesp32v4","sw":"esphome v2021.12.1 Dec 30 2021, 19:28:56","mdl":"esp32dev","mf":"espressif"}}' retain=1)
[19:37:41][V][mqtt:404]: Publish(topic='hoesp32v4/switch/1u/state' payload='OFF' retain=1)
[19:37:41][V][mqtt:309]: subscribe(topic='hoesp32v4/switch/2u/command')
[19:37:41][V][mqtt.component:062]: '2u': Sending discovery...
[19:37:42][V][mqtt:404]: Publish(topic='homeassistant/switch/hoesp32v4/2u/config' payload='{"name":"2u","stat_t":"hoesp32v4/switch/2u/state","cmd_t":"hoesp32v4/switch/2u/command","avty_t":"hoesp32v4/status","uniq_id":"ESPswitch2u","dev":{"ids":"943cc611cd94","name":"hoesp32v4","sw":"esphome v2021.12.1 Dec 30 2021, 19:28:56","mdl":"esp32dev","mf":"espressif"}}' retain=1)
[19:37:42][V][mqtt:404]: Publish(topic='hoesp32v4/switch/2u/state' payload='OFF' retain=1)
[19:37:42][V][mqtt:309]: subscribe(topic='hoesp32v4/switch/3u/command')
[19:37:42][V][mqtt.component:062]: '3u': Sending discovery...
[19:37:42][V][mqtt:404]: Publish(topic='homeassistant/switch/hoesp32v4/3u/config' payload='{"name":"3u","stat_t":"hoesp32v4/switch/3u/state","cmd_t":"hoesp32v4/switch/3u/command","avty_t":"hoesp32v4/status","uniq_id":"ESPswitch3u","dev":{"ids":"943cc611cd94","name":"hoesp32v4","sw":"esphome v2021.12.1 Dec 30 2021, 19:28:56","mdl":"esp32dev","mf":"espressif"}}' retain=1)
[19:37:42][V][mqtt:404]: Publish(topic='hoesp32v4/switch/3u/state' payload='OFF' retain=1)
[19:37:42][V][mqtt:309]: subscribe(topic='hoesp32v4/switch/fu/command')
[19:37:42][V][mqtt.component:062]: 'fu': Sending discovery...
[19:37:42][V][mqtt:404]: Publish(topic='homeassistant/switch/hoesp32v4/fu/config' payload='{"name":"fu","stat_t":"hoesp32v4/switch/fu/state","cmd_t":"hoesp32v4/switch/fu/command","avty_t":"hoesp32v4/status","uniq_id":"ESPswitchfu","dev":{"ids":"943cc611cd94","name":"hoesp32v4","sw":"esphome v2021.12.1 Dec 30 2021, 19:28:56","mdl":"esp32dev","mf":"espressif"}}' retain=1)
[19:37:42][V][mqtt:404]: Publish(topic='hoesp32v4/switch/fu/state' payload='OFF' retain=1)
[19:37:42][V][mqtt:309]: subscribe(topic='hoesp32v4/switch/hosoc/command')
[19:37:42][V][mqtt.component:062]: 'hosoc': Sending discovery...
[19:37:42][V][mqtt:404]: Publish(topic='homeassistant/switch/hoesp32v4/hosoc/config' payload='{"name":"hosoc","stat_t":"hoesp32v4/switch/hosoc/state","cmd_t":"hoesp32v4/switch/hosoc/command","avty_t":"hoesp32v4/status","uniq_id":"ESPswitchhosoc","dev":{"ids":"943cc611cd94","name":"hoesp32v4","sw":"esphome v2021.12.1 Dec 30 2021, 19:28:56","mdl":"esp32dev","mf":"espressif"}}' retain=1)
[19:37:42][V][mqtt:404]: Publish(topic='hoesp32v4/switch/hosoc/state' payload='ON' retain=1)
[19:37:42][V][mqtt:309]: subscribe(topic='hoesp32v4/switch/hoac/command')
[19:37:42][V][mqtt.component:062]: 'hoac': Sending discovery...
[19:37:42][V][mqtt:404]: Publish(topic='homeassistant/switch/hoesp32v4/hoac/config' payload='{"name":"hoac","stat_t":"hoesp32v4/switch/hoac/state","cmd_t":"hoesp32v4/switch/hoac/command","avty_t":"hoesp32v4/status","uniq_id":"ESPswitchhoac","dev":{"ids":"943cc611cd94","name":"hoesp32v4","sw":"esphome v2021.12.1 Dec 30 2021, 19:28:56","mdl":"esp32dev","mf":"espressif"}}' retain=1)
[19:37:42][V][mqtt:404]: Publish(topic='hoesp32v4/switch/hoac/state' payload='ON' retain=1)
[19:37:42][V][mqtt:309]: subscribe(topic='hoesp32v4/switch/holight/command')
[19:37:42][V][mqtt.component:062]: 'holight': Sending discovery...
[19:37:42][V][mqtt:404]: Publish(topic='homeassistant/switch/hoesp32v4/holight/config' payload='{"name":"holight","stat_t":"hoesp32v4/switch/holight/state","cmd_t":"hoesp32v4/switch/holight/command","avty_t":"hoesp32v4/status","uniq_id":"ESPswitchholight","dev":{"ids":"943cc611cd94","name":"hoesp32v4","sw":"esphome v2021.12.1 Dec 30 2021, 19:28:56","mdl":"esp32dev","mf":"espressif"}}' retain=1)
[19:37:42][V][mqtt:404]: Publish(topic='hoesp32v4/switch/holight/state' payload='OFF' retain=1)
[19:37:42][V][mqtt:309]: subscribe(topic='hoesp32v4/switch/holc1/command')
[19:37:42][V][mqtt.component:062]: 'holc1': Sending discovery...
[19:37:42][V][mqtt:404]: Publish(topic='homeassistant/switch/hoesp32v4/holc1/config' payload='{"name":"holc1","stat_t":"hoesp32v4/switch/holc1/state","cmd_t":"hoesp32v4/switch/holc1/command","avty_t":"hoesp32v4/status","uniq_id":"ESPswitchholc1","dev":{"ids":"943cc611cd94","name":"hoesp32v4","sw":"esphome v2021.12.1 Dec 30 2021, 19:28:56","mdl":"esp32dev","mf":"espressif"}}' retain=1)
[19:37:42][V][mqtt:404]: Publish(topic='hoesp32v4/switch/holc1/state' payload='OFF' retain=1)
[19:37:42][I][app:062]: setup() finished successfully!
[19:37:42][V][mqtt:404]: Publish(topic='hoesp32v4/status' payload='online' retain=1)
[19:37:42][I][app:102]: ESPHome version 2021.12.1 compiled on Dec 30 2021, 19:28:56
[19:37:42][C][wifi:488]: WiFi:
[19:37:42][C][wifi:350]: Local MAC: 94:3C:C6:11:CD:94
[19:37:42][C][wifi:351]: SSID: 'ANILHOME2'
[19:37:42][C][wifi:352]: IP Address: 192.168.1.36
[19:37:42][C][wifi:354]: BSSID: E8:48:B8:13:0E:EB
[19:37:42][C][wifi:355]: Hostname: 'hoesp32v4'
[19:37:42][C][wifi:361]: Channel: 4
[19:37:42][C][wifi:362]: Subnet: 255.255.255.0
[19:37:42][C][wifi:363]: Gateway: 192.168.1.1
[19:37:42][C][wifi:364]: DNS1: 0.0.0.0
[19:37:42][C][wifi:365]: DNS2: 0.0.0.0
[19:37:42][C][logger:233]: Logger:
[19:37:42][C][logger:234]: Level: VERY_VERBOSE
[19:37:42][C][logger:235]: Log Baud Rate: 115200
[19:37:42][C][logger:236]: Hardware UART: UART0
[19:37:42][C][switch.gpio:048]: GPIO Switch '1u'
[19:37:42][C][switch.gpio:049]: Pin: GPIO32
[19:37:42][C][switch.gpio:071]: Restore Mode: Always OFF
[19:37:42][C][switch.gpio:048]: GPIO Switch '2u'
[19:37:42][C][switch.gpio:049]: Pin: GPIO33
[19:37:42][C][switch.gpio:048]: GPIO Switch '3u'
[19:37:42][C][switch.gpio:049]: Pin: GPIO25
[19:37:42][C][switch.gpio:048]: GPIO Switch 'fu'
[19:37:42][C][switch.gpio:049]: Pin: GPIO26
[19:37:42][C][switch.gpio:048]: GPIO Switch 'hosoc'
[19:37:42][C][switch.gpio:048]: Inverted: YES
[19:37:42][C][switch.gpio:049]: Pin: GPIO27
[19:37:42][C][switch.gpio:071]: Restore Mode: Always ON
[19:37:42][C][switch.gpio:048]: GPIO Switch 'hoac'
[19:37:42][C][switch.gpio:049]: Pin: GPIO14
[19:37:42][C][switch.gpio:048]: GPIO Switch 'holight'
[19:37:42][C][switch.gpio:049]: Pin: GPIO12
[19:37:42][C][switch.gpio:048]: GPIO Switch 'holc1'
[19:37:42][C][switch.gpio:049]: Pin: GPIO13
[19:37:42][C][captive_portal:144]: Captive Portal:
[19:37:42][C][ota:082]: Over-The-Air Updates:
[19:37:42][C][ota:083]: Address: 192.168.1.36:3232
[19:37:42][C][ota:086]: Using Password.
[19:37:42][W][ota:092]: Last Boot was an unhandled reset, will proceed to safe mode in 6 restarts
[19:37:42][C][mqtt:063]: MQTT:
[19:37:42][C][mqtt:065]: Server Address: 192.168.1.30:1883 (192.168.1.30)
[19:37:42][C][mqtt:066]: Username: 'mqttuser'
[19:37:42][C][mqtt:067]: Client ID: 'hoesp32v4-943cc611cd94'
[19:37:42][C][mqtt:069]: Discovery prefix: 'homeassistant'
[19:37:42][C][mqtt:070]: Discovery retain: YES
[19:37:42][C][mqtt:072]: Topic Prefix: 'hoesp32v4'
[19:37:42][C][mqtt:074]: Log Topic: 'hoesp32v4/debug'
[19:37:42][C][mqtt:077]: Availability: 'hoesp32v4/status'
[19:37:42][C][mdns:084]: mDNS:
[19:37:42][C][mdns:085]: Hostname: hoesp32v4
[19:37:42][V][mdns:086]: Services:
[19:37:42][V][mdns:088]: - _http, _tcp, 80
[19:37:42][V][mdns:090]: TXT: version = 2021.12.1
[19:37:42][C][mqtt.switch:041]: MQTT Switch '1u':
[19:37:42][C][mqtt.switch:042]: State Topic: 'hoesp32v4/switch/1u/state'
[19:37:42][C][mqtt.switch:042]: Command Topic: 'hoesp32v4/switch/1u/command'
[19:37:42][C][mqtt.switch:041]: MQTT Switch '2u':
[19:37:42][C][mqtt.switch:042]: State Topic: 'hoesp32v4/switch/2u/state'
[19:37:42][C][mqtt.switch:042]: Command Topic: 'hoesp32v4/switch/2u/command'
[19:37:42][C][mqtt.switch:041]: MQTT Switch '3u':
[19:37:42][C][mqtt.switch:042]: State Topic: 'hoesp32v4/switch/3u/state'
[19:37:42][C][mqtt.switch:042]: Command Topic: 'hoesp32v4/switch/3u/command'
[19:37:42][C][mqtt.switch:041]: MQTT Switch 'fu':
[19:37:42][C][mqtt.switch:042]: State Topic: 'hoesp32v4/switch/fu/state'
[19:37:42][C][mqtt.switch:042]: Command Topic: 'hoesp32v4/switch/fu/command'
[19:37:42][C][mqtt.switch:041]: MQTT Switch 'hosoc':
[19:37:42][C][mqtt.switch:042]: State Topic: 'hoesp32v4/switch/hosoc/state'
[19:37:42][C][mqtt.switch:042]: Command Topic: 'hoesp32v4/switch/hosoc/command'
[19:37:42][C][mqtt.switch:041]: MQTT Switch 'hoac':
[19:37:42][C][mqtt.switch:042]: State Topic: 'hoesp32v4/switch/hoac/state'
