Hi all,
i am struggeling with getting my code to work.
What i want is to build a thermostat. Depending on the state of desired temperature and real temperature the state should go to heat or cool. If the state is e.g. heat or cool a relay for the valve should triggerd and depending on the temperature difference a fan should turn on (relay 1-3).
Whatever i do the fan always is in high mode ( relay 3). anyone can give me some pointers so i can understand what i am doing wrong and how i can correct it?
please bare in mind i’m not an expert. ’
Thanks in advance.
FritsOv
type or paste code here
# DHT22- AM2302 sensor
- platform: dht
pin: $dht_data
update_interval: 30s
temperature:
accuracy_decimals: 1
filters:
- offset: $offset
humidity:
switch:
# relay 1 fanlevel low
- platform: gpio
pin: $fan_low_relay_pin
interlock: &interlock_group [relay_1, relay_2, relay_3]
interlock_wait_time: $interlock_time
internal: true
# relay 2 fanlevel mid
- platform: gpio
pin: $fan_mid_relay_pin
interlock: *interlock_group
internal: true
# relay 3 fanlevel high
- platform: gpio
pin: $fan_high_relay_pin
internal: true
# relay 4 valve
- platform: gpio
pin: $valve_pin
icon: "mdi:valve"
internal: true
# heatmode
- platform: gpio
pin: $heat_pin
icon: "mdi:heating-coil"
interlock: &interlock_2 [heater, cooler]
internal: true
# coolmode
- platform: gpio
pin: $cool_pin
icon: "mdi:snowflake"
interlock: *interlock_2
internal: true
# setting up fan with output to corresponding fanspeed
fan:
- platform: speed
output: custom_fan
speed_count: 3
output:
type: float
write_action:
- if:
condition:
lambda: return ((state ==0));
then:
#action for off
- logger.log: "turn all relays to off!"
- switch.turn_off: relay_1
- switch.turn_off: relay_2
- switch.turn_off: relay_3
- if:
condition:
# lambda: return (( id(dht_temperature).state > .16) && (id(dht_temperature).state < .34));
lambda: return (( state > .16) && (state < .34));
then:
# action for low
- logger.log: "Fan Turned to low speed!"
- switch.turn_on: relay_1
- if:
condition:
# lambda: return (( id(dht_temperature).state > .35) && (id(dht_temperature).state < .7));
lambda: return ((state > .35) && (state < .7));
then:
# action for medium
- logger.log: "Fan Turned to medium speed!"
- switch.turn_on: relay_2
- switch.turn_on: valve
- if:
condition:
# lambda: return (( id(dht_temperature).state == 1));
lambda: return ((state ==1));
then:
# action for high
- logger.log: "Fan Turned to high speed!"
- switch.turn_on: relay_3
# setting up climate conrol
climate:
- platform: thermostat
visual:
min_temperature: 15
max_temperature: 40
temperature_step: 0.1 °C ### step temperature up and down
sensor: dht_temperature
# defaults and on boot
default_preset: Home
on_boot_restore_from: memory
# on_boot_restore_from: default_preset
# set minimum time for cooling, heating and idle
min_cooling_off_time: $off_time
min_cooling_run_time: $run_time
min_heating_off_time: $off_time
min_heating_run_time: $run_time
min_idle_time: 5s
# set fan minimum time
min_fanning_run_time: $run_time
min_fanning_off_time: $off_time
min_fan_mode_switching_time: $fan_switch_time
# predefined settings wirth min and max temperature
preset:
- name: Home
default_target_temperature_low: 19.0
default_target_temperature_high: 22.0
- name: Away
default_target_temperature_low: 15.0
default_target_temperature_high: 18.0
- name: Sleep
default_target_temperature_low: 18.0
default_target_temperature_high: 19.0
# deadbangs
cool_deadband: 0.2 °C
cool_overrun: 0.3 °C
heat_deadband: 0.3 °C
heat_overrun: 0.5 °C
# actions to take when stat sets to cool, heat
cool_action:
- switch.turn_on: cooler
- fan.turn_on: ventilate
heat_action:
- switch.turn_on: heater
idle_action:
- switch.turn_off: heater
- switch.turn_off: cooler
- switch.turn_off: valve
- fan.turn_off: ventilate
fan_mode_on_action:
fan_only_action:
fan_mode_low_action:
lambda: !lambda |-
auto call = id(ventilate).turn_on();
call.set_speed(1);
call.perform();
fan_mode_medium_action:
lambda: !lambda |-
call.set_speed(2);
call.perform();
fan_mode_high_action:
lambda: !lambda |-
call.set_speed(3);
call.perform();
fan_mode_off_action:
