Hi everyone, hope everyone’s doing well.
I am a beginner in hassio. Pardon me for silly mistakes.
My setup:
I am integrating seeed-studio xiao esp32c3 with door sensor in esphome.
The esp32c3 should wake up whenever there is change in state, else go to sleep.
That is, if door opens, wakeup, report to hassio, sleep. Same goes for door close.
Current Project status:
I have written the configuration file for esphome yaml file. The integration of door sensor with esp32c3 is working fine(without deep sleep).
I seek help in:
I am trying to integrate deep sleep in the above system. The pin to wakeup is same as door pin.
When defining that in deep sleep mode, I am getting an error saying that pin used multiple times.
Below is my yaml file.
esphome:
friendly_name: Door_Sensor
esp32:
board: seeed_xiao_esp32c3
variant: esp32c3
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "EncryptionKey"
ota:
password: "OtaKey"
wifi:
ssid: Potato
password: Password
ap:
ssid: "Door-Sensor Fallback Hotspot"
password: "dnKbTZUUHNwj"
captive_portal:
# Define your door sensor pin and setup
binary_sensor:
- platform: gpio
pin:
number: GPIO2
mode: INPUT_PULLUP
device_class: door
deep_sleep:
run_duration: 30s
wakeup_pin: GPIO2
wakeup_pin_mode: IGNORE
Any suggestions or input will be really helpful.
Thanks.
zoogara
(Daryl)
January 8, 2024, 6:12am
2
You need to add allow_other_uses: true
to your binary sensor.
This was just recently added:
Thanks for the input Daryl, I will try this let you know the status.
Hi, I tried adding the parameter to the yaml file, and I could successfully flash it.
But now, my door sensor is showing unavailable on dashboard (even if I am changing the state of door sensor). Where am I going wrong here?
My yaml file:
esphome:
esp32:
variant: esp32c3
framework:
type: arduino
# Enable logging
logger:
api:
encryption:
key: "api key"
ota:
password: "ota password"
wifi:
ssid: Potato
password: Password
ap:
captive_portal:
binary_sensor:
- platform: gpio
pin:
number: GPIO2
mode: INPUT_PULLUP
device_class: door
# Configure deep sleep
deep_sleep:
run_duration: 5s # Adjust as needed
wakeup_pin:
number: GPIO2 # Replace with the actual GPIO pin where your door sensor is connected
Here is the dashboard screenshot attached:
zoogara
(Daryl)
January 8, 2024, 8:57pm
5
Ah - can’t help you there. I have the same issue with one of my deep sleep sensors - still trying to solve it.
Appreciate your insights Daryl, maybe I will create a new topic and see if someone has done it already.
I wonder if we can use a on_boot to prevent deep sleep for maybe 30 seconds to allow the first read
