Hi fellows. Since 2 weeks i’m using home assistant, and i already have a couple of sensors and cameras, included the PV and EVCC Charger. I am nearly addicted
I’ve successful built a doorphone (DIY Doorphone with voice response topic)
It uses a DfPlayer via UART interface, and the ESP32 cam.
I’ve had the “brillant idea” to include in the project two buttons, and also a LD2410 sensor (necessairly via UART, due reliability).
I’m stuck with DfPlayer integration (all works well without LD2410). when i add it, does not work
Maybe i’m asking too much to the ESP32 Cam? looking at the log, there is no data flood from LD2410 sensor (when DfPlayer is disabled)…
here the config (a bit streamlined) :
#ESP32Cam + DfPlayer + LD2410
substitutions:
statuslightpin: GPIO33
flashlightpin: GPIO4
buttonpin: GPIO12
buttonpin2: GPIO15
# dfplayer
df_tx_pin: GPIO14
df_rx_pin: GPIO13
#ld2410
ld_tx_pin: GPIO2
ld_rx_pin: GPIO16
esphome:
friendly_name: $devicename
platform: ESP32
board: esp32cam #esp32dev
on_boot:
priority: -10
then:
- light.turn_on: $statuslight
external_components:
- source: github://esphome/esphome@dev
components: [ ld2410 ]
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
ota:
# Camera config
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
resolution: 1600x1200 #2560x1920 #1600x1200
idle_framerate: 0.01 fps # 0.1 fps
vertical_flip: true
horizontal_mirror: false
uart:
- id: uart01
rx_pin: $ld_rx_pin
tx_pin: $ld_tx_pin
baud_rate: 256000
parity: NONE
stop_bits: 1
- id: uart02
tx_pin: $df_tx_pin
rx_pin: $df_rx_pin
baud_rate: 9600
parity: NONE
stop_bits: 1
#dfplayer:
# uart_id: uart02
# on_finished_playback:
# then:
# logger.log: 'Playback finished'
ld2410:
uart_id: uart01
timeout: 10s
max_move_distance : 6m
max_still_distance: 6m
g0_move_threshold: 50
g0_still_threshold: 20
g1_move_threshold: 50
g1_still_threshold: 20
g2_move_threshold: 40
g2_still_threshold: 20
g3_move_threshold: 30
g3_still_threshold: 20
g4_move_threshold: 30
g4_still_threshold: 20
g5_move_threshold: 20
g5_still_threshold: 20
g6_move_threshold: 20
g6_still_threshold: 20
g7_move_threshold: 40
g7_still_threshold: 30
g8_move_threshold: 40
g8_still_threshold: 30
binary_sensor:
- platform: status
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
- platform: gpio
pin:
number: $buttonpin
mode: INPUT_PULLUP
inverted: True
on_press:
then:
#- dfplayer.play:
# file: 5
- light.turn_off: $flashlight
- delay: 0.10s
- light.turn_on: $flashlight
- delay: 0.10s
- delay: 0.10s
- platform: gpio
pin:
number: $buttonpin2
mode: INPUT_PULLUP
inverted: True
on_press:
then:
#- dfplayer.play:
# file: 6
- delay: 0.10s
- delay: 0.10s
- delay: 0.10s
- platform: wifi_signal
name: $hostname WiFi Signal
update_interval: 600s
- platform: internal_temperature
name: $hostname Internal Temperature
switch:
- platform: restart
output:
#flashlight
- platform: gpio
pin:
number: $flashlightpin
#inverted: True
#statuslight
- platform: gpio
pin:
number: $statuslightpin
inverted: True
light:
#flashlight
- platform: binary
output: gpio_4
#=========================== AUTORESTART 2 AM =================================
time:
- platform: homeassistant
on_time:
- seconds: 0
minutes: 0
hours: 2
days_of_week: MON-SUN
then:
- switch.toggle: restart_switch
and this is the log when DfPlayer is active:
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
[I][logger:262]: Log initialized
[C][ota:469]: There have been 5 suspected unsuccessful boot attempts.
[D][esp32.preferences:114]: Saving 1 preferences to flash...
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[C][uart.arduino_esp32:077]: Setting up UART...
[D][binary_sensor:034]: 'doorbell_button_gg': Sending initial state OFF
[D][binary_sensor:034]: 'doorbell_button_da': Sending initial state OFF
[C][light:035]: Setting up light 'doorbell flash'...
[D][light:036]: 'doorbell flash' Setting:
[D][light:041]: Color mode:
[C][light:035]: Setting up light 'doorbell status light'...
[D][light:036]: 'doorbell status light' Setting:
[D][esp-idf:000]: E (582) camera: Camera probe failed with error 0x105(ESP_ERR_NOT_FOUND)
[E][esp32_camera:024]: esp_camera_init failed: ESP_ERR_NOT_FOUND
[E][component:113]: Component esp32_camera was marked as failed.
[C][ld2410:033]: Setting up LD2410...
[C][ld2410:049]: Firmware Version : 0.0.0000
[C][ld2410:050]: LD2410 setup complete.
[D][binary_sensor:034]: 'doorbell status': Sending initial state OFF
[C][wifi:038]: Setting up WiFi...
[C][wifi:048]: Starting WiFi...
[C][wifi:049]: Local MAC: E8:DB:84:12:7C:C8
[D][wifi:425]: Starting scan...
[D][sensor:094]: 'doorbell Internal Temperature': Sending state 23.33333 °C with 1 decimals of accuracy
[E][uart:015]: Reading from UART timed out at byte 4289593344!
E (13151) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (13151) task_wdt: - loopTask (CPU 1)
E (13151) task_wdt: Tasks currently running:
E (13151) task_wdt: CPU 0: IDLE
E (13151) task_wdt: CPU 1: loopTask
E (13151) task_wdt: Aborting.
abort() was called at PC 0x400f5234 on core 0
Backtrace:0x40083a49:0x3ffbe9cc |<-CORRUPTED
ELF file SHA256: 0000000000000000
Rebooting...
