I flashed the esp32cam using the MB board but I get the following logs. The installation says its successfull but I get the following logs, which says otherwise
I (26) boot: compile time 20:02:47
I (26) boot: chip revision: 1
I (29) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (36) boot.esp32: SPI Speed : 40MHz
I (41) boot.esp32: SPI Mode : DIO
I (45) boot.esp32: SPI Flash Size : 4MB
I (50) boot: Enabling RNG early entropy source...
I (55) boot: Partition Table:
I (59) boot: ## Label Usage Type ST Offset Length
I (66) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (73) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (81) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (88) boot: 3 ota_0 OTA app 00 10 00010000 001db000
I (96) boot: 4 ota_1 OTA app 00 11 001f0000 001db000
I (103) boot: End of partition table
I (108) boot_comm: chip revision: 1, min. application chip revision: 0
I (115) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=40014h (262164) map
I (224) esp_image: segment 1: paddr=0005003c vaddr=3ffb0000 size=040e8h ( 16616) load
I (231) esp_image: segment 2: paddr=0005412c vaddr=40080000 size=0beech ( 48876) load
I (252) esp_image: segment 3: paddr=00060020 vaddr=400d0020 size=1100f4h (1114356) map
I (679) esp_image: segment 4: paddr=0017011c vaddr=4008beec size=0e354h ( 58196) load
I (717) boot: Loaded app from partition at offset 0x10000
I (717) boot: Disabling RNG early entropy source...
I (729) cpu_start: Multicore app
I (729) quad_psram: This chip is ESP32-D0WD
E (729) quad_psram: PSRAM ID read error: 0xffffffff, PSRAM chip not found or not supported
E (735) cpu_start: Failed to init external RAM, needed for external .bss segment
abort() was called at PC 0x40083020 on core 0
Backtrace: 0x40083ac1:0x3ffe3ba0 0x4008e555:0x3ffe3bc0 0x400949e5:0x3ffe3be0 0x40083020:0x3ffe3c50 0x4007956d:0x3ffe3c80 |<-CORRUPTED
ELF file SHA256: 71b36fda6e4066fa
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:7664
load:0x40078000,len:15360
load:0x40080400,len:3744
entry 0x4008067c
I (27) boot: ESP-IDF 4.3.2 2nd stage bootloader
I (27) boot: compile time 20:02:47
I (27) boot: chip revision: 1
I (30) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (37) boot.esp32: SPI Speed : 40MHz
I (42) boot.esp32: SPI Mode : DIO
I (46) boot.esp32: SPI Flash Size : 4MB
I (51) boot: Enabling RNG early entropy source...
I (56) boot: Partition Table:
I (60) boot: ## Label Usage Type ST Offset Length
I (67) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (74) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (82) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (89) boot: 3 ota_0 OTA app 00 10 00010000 001db000
I (97) boot: 4 ota_1 OTA app 00 11 001f0000 001db000
I (104) boot: End of partition table
I (109) boot_comm: chip revision: 1, min. application chip revision: 0
I (116) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=40014h (262164) map
I (225) esp_image: segment 1: paddr=0005003c vaddr=3ffb0000 size=040e8h ( 16616) load
I (232) esp_image: segment 2: paddr=0005412c vaddr=40080000 size=0beech ( 48876) load
I (253) esp_image: segment 3: paddr=00060020 vaddr=400d0020 size=1100f4h (1114356) map
I (680) esp_image: segment 4: paddr=0017011c vaddr=4008beec size=0e354h ( 58196) load
I (718) boot: Loaded app from partition at offset 0x10000
I (718) boot: Disabling RNG early entropy source...
I (730) cpu_start: Multicore app
I (730) quad_psram: This chip is ESP32-D0WD
E (730) quad_psram: PSRAM ID read error: 0xffffffff, PSRAM chip not found or not supported
