Hello everyone this is my first post.
Im’ currently having some trouble with the stream of a esp32cam flashed with esphome. It is weird cause everything seems to work correctly on the esphome log and i do get several messages saying “[D][esp32_camera:159]: Got Image: len=207756” bla, bla. But on the Lovelace picture glance card no stream is shown if i choose live mode, only on auto mode.
The most weird is that the stream is shown on my iphone on the home assistant app even when im away using nabu casa to connect to my pi back home, and if I use another computer to connect with nabu casa it does not work. It seems it only works on my iphone app.
This is my yaml file for the esphome node. Thanks in advance for any help!!
`esphome:`
`name: esp32cam`
`platform: ESP32`
`board: esp32cam`
`wifi:`
`ssid: "bla"`
`password: "bla"`
`# Enable fallback hotspot (captive portal) in case wifi connection fails`
`ap:`
`ssid: "Esp32Cam Fallback Hotspot"`
`password: "3qCg24ohepQC"`
`captive_portal:`
`# Enable logging`
`logger:`
`# Enable Home Assistant API`
`api:`
`ota:`
`# ESP32-CAM`
`esp32_camera:`
`external_clock:`
`pin: GPIO0`
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
resolution: 1600x1200
# ... Frame Settings
binary_sensor:
- platform: status
# Flashlight
output:
- platform: gpio
pin: GPIO4
light:
- platform: binary
output: gpio_4
