I’m trying to control pwn fan with this setup :
My problem is my fan never stop completely, maybe i missed a setting ?
Thanks.
Thanks.
No yaml? No logs? Impossible to help.
output:
- platform: ledc
pin: GPIO12
frequency: 25000 Hz
fan:
- platform: speed
output: ventilateur_cheminee_controle
name: "Ventilateur Cheminée Contrôle"
entity_category: "config"
Are you sure it is a pwm (4-pin) fan and not 3-pin?
Yes it is, but i didn’t try with another fan to be sure it’s not him the problem…
I tried with other 4-pin fans and it’s not working, i can control the speed but the fan never stop.
Is there a particular reason for the chosen frequency? There are some recommended frequencies in the documentation. Also, my understanding is that there should not be a space character between numeric value and the unit.
I have no idea if this has anything do to with your issue, but might be worth trying a different (or the default) frequency.
Ok thank you i will try this.
Otherwise, can i make a switch for the fan with an other pin on the esp ? It may solve my problem ?
A pin to do an on/off and a pin for the pwm ?
Thanks, i’m not an expert in ESP at all…
I guess you could somehow control power to the fan using a MOSFET, but this would make the fan component more complicated, because it assumes it already has access to turn the fan on/off.
Try tinkering with zero_means_zero and min_power ?
I’m just guessing.
There seem to be a few similar issues around the internet so maybe check them too.
I found two Noctua fans with differents wires’s color and it’s working !
But now i have a new problem : when i flash with ESP Home, new configuration are not applied… no error when flashing, it’s wierd…
Ok i found out that i need to remove every pins connexion before flashing the esp, little bit tedious but ok.
Not usually, but maybe to do with your wiring.
Can you explain that a bit further?
I don’t know why but when both my ESP as no wiring but power i can flash them wirelessly and when it is connected to the rest, i get that :
INFO Reading configuration /config/esphome/ventilateur-baie.yaml...
WARNING GPIO12 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing ventilateur-baie (board: esp32dev; framework: arduino; platform: platformio/espressif32 @ 5.2.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Update @ 2.0.0
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/api_connection.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/api_server.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/list_entities.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/proto.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/api/user_services.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/binary_sensor/automation.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/binary_sensor/binary_sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/binary_sensor/filter.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/button/button.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/esp32/core.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/esp32/gpio.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/esp32/preferences.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/fan/fan.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/fan/fan_state.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/ledc/ledc_output.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/logger/logger.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/md5/md5.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/mdns/mdns_component.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/network/util.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/output/automation.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/output/float_output.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/pulse_counter/pulse_counter_sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/restart/button/restart_button.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/sensor/automation.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/sensor/filter.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/sensor/sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/socket/socket.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/speed/fan/speed_fan.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/status/status_binary_sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/template/sensor/template_sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/text_sensor/filter.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/text_sensor/text_sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/uptime/uptime_sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/version/version_text_sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/components/wifi_signal/wifi_signal_sensor.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/application.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/color.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/component.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/component_iterator.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/controller.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/entity_base.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/helpers.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/log.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/scheduler.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/esphome/core/util.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/src/main.cpp.o
Building /data/ventilateur-baie/.pioenvs/ventilateur-baie/bootloader.bin
Creating esp32 image...
Successfully created esp32 image.
Generating partitions /data/ventilateur-baie/.pioenvs/ventilateur-baie/partitions.bin
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFi.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFiAP.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFiClient.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFiGeneric.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFiMulti.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFiSTA.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFiScan.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFiServer.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/WiFi/WiFiUdp.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib915/ESPmDNS/ESPmDNS.cpp.o
Archiving /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib64d/libWiFi.a
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/libbc6/Update/HttpsOTAUpdate.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/libbc6/Update/Updater.cpp.o
Archiving /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib915/libESPmDNS.a
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_core/ed25519/core_ed25519.c.o
Archiving /data/ventilateur-baie/.pioenvs/ventilateur-baie/libbc6/libUpdate.a
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_hash/crypto_hash.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_stream/crypto_stream.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/crypto_verify/sodium/verify.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/sodium/codecs.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/sodium/core.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/sodium/runtime.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium/sodium/utils.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/ref/dh-curve25519.c.o
Archiving /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib9f0/libsodium.a
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/ref/hash-blake2b.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/ref/hash-blake2s.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/ref/hash-sha256.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/sodium/dh-curve25519.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/sodium/hash-blake2b.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/backend/sodium/hash-sha256.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/blake2/blake2b.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/blake2/blake2s.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/chacha/chacha.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/donna/curve25519-donna.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/donna/poly1305-donna.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/sha2/sha256.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/sha2/sha512.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/crypto/x25519/x25519.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/cipherstate.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/dhstate.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/errors.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/handshakestate.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/hashstate.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/internal.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/names.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/patterns.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/rand_os.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/rand_sodium.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/randstate.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/signstate.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/symmetricstate.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/noise-c/protocol/util.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/Esp.cpp.o
Archiving /data/ventilateur-baie/.pioenvs/ventilateur-baie/lib041/libnoise-c.a
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/FirmwareMSC.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/HWCDC.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/HardwareSerial.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/IPAddress.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/IPv6Address.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/MD5Builder.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/Print.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/Stream.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/StreamString.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/Tone.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/USB.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/USBCDC.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/USBMSC.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/WMath.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/WString.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/base64.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/cbuf.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-adc.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-bt.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-cpu.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-dac.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-gpio.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-i2c.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-ledc.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-matrix.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-misc.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-psram.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-rmt.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-spi.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-time.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-timer.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-touch.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/esp32-hal-uart.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/firmware_msc_fat.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/libb64/cdecode.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/libb64/cencode.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/main.cpp.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/stdlib_noniso.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/wiring_pulse.c.o
Compiling /data/ventilateur-baie/.pioenvs/ventilateur-baie/FrameworkArduino/wiring_shift.c.o
Archiving /data/ventilateur-baie/.pioenvs/ventilateur-baie/libFrameworkArduino.a
Linking /data/ventilateur-baie/.pioenvs/ventilateur-baie/firmware.elf
RAM: [= ] 12.3% (used 40208 bytes from 327680 bytes)
Flash: [===== ] 48.7% (used 893229 bytes from 1835008 bytes)
Building /data/ventilateur-baie/.pioenvs/ventilateur-baie/firmware.bin
esp32_create_combined_bin(["/data/ventilateur-baie/.pioenvs/ventilateur-baie/firmware.bin"], ["/data/ventilateur-baie/.pioenvs/ventilateur-baie/firmware.elf"])
Wrote 0xeb7c0 bytes to file /data/ventilateur-baie/.pioenvs/ventilateur-baie/firmware-factory.bin, ready to flash to offset 0x0
========================= [SUCCESS] Took 42.55 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of ventilateur-baie.local
INFO -> 192.168.2.111
INFO Uploading /data/ventilateur-baie/.pioenvs/ventilateur-baie/firmware.bin (899008 bytes)
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
ERROR Error Update end: Error: Finishing update failed. See the MQTT/USB logs for more information.
Hello Jérémy, could you tell what Noctua’s model you found please?
I get the same issue with the Noctua NF-P12 redux-1300 PWM I just bought and btw the max RPM I can get from homeassistant is 620 RPM, so I don’t know if it’s the right value or just and issue with the RPM counter!
Thanks for your feedback!
