Hi!
I try to configure Tasmota to send mqtt-status, when I connect GND to GPIO4, GND to GPIO5, and so on, … => “On” or “Off” like a switch.
Then I will use it in Home Assistant to power on/off my lights (shelly, …)
Thanks a lot!
Hi!
Thanks a lot!
maybe you will look at ESPHome? Direct integration into HA?
And GPIO sensors are only a few lines YAML.
Ulrich
As I understand it, you want a switch. Tasmota can sent MQTT for switches. You can select different switchmodes, or can create rules.
As you describe it you will create two switches. Only one GPIO is enough for a switch/button with on/off stautus to sent to HA
How to configure it? I woul like to use my ESP with 4 Buttons und send MQTT: On (by pushing the button) and off again by releasing…
You configure the button as a switch (is always recommented as it gives you more option)
The dufault is SwitchMode 0, that toggles when you press and toggle again when you release
Check the SwitchModes here
https://tasmota.github.io/docs/Buttons-and-Switches/
I configured 4 GPIOs as a switch and get in the console this output:
00:00:52.469 MQT: stat/tasmota_A1DEC5/RESULT = {“POWER”:“ON”}
00:00:52.472 MQT: stat/tasmota_A1DEC5/POWER = ON
00:00:55.782 MQT: stat/tasmota_A1DEC5/RESULT = {“POWER”:“OFF”}
00:00:55.785 MQT: stat/tasmota_A1DEC5/POWER = OFF
so I dont’t know wich GPIO that is
