I have purchased
D1 wemos mini ESP8266
D1 mini buzzer shield (Wemos D1 mini Buzzer Shield V1.0.0 ESP8266 Arduino - Kunkune )
I have tried to follow many forum articles as well as the RTTTL help pages but nothing is happening. I am at the pont of wondering if the hardware is faulty.
Would anyone mind throwing together a piece of code that I can put into ESPHOME and test it with a switch?
Or could someone tell me if there is a way to test that the hardware actually works?
Many thanks.
Spiro
March 30, 2024, 9:29pm
2
output:
- platform: ledc
pin: PICK your PIN
inverted: True
zero_means_zero: True
rtttl:
output: rtttl_out
binary_sensor:
- platform: gpio
pin:
number: Pick your pin for this
mode: INPUT_PULLUP
inverted: True
filters:
- invert:
- delayed_on: 100ms
- delayed_off: 100ms
on_press:
then:
- rtttl.play: 'TubularB:d=4,o=6,b=200:8b,8e,8a,8e,8b,8e,8g,8a,8e,8c7,8e,8d7,8e,8b,8c7,8e,8b,8e,8a,8e,8b,8e,8g,8a,8e,8c7'
Try this.
Thanks for the input @Spiro
Got this:
Failed config
output.ledc: [source /config/esphome/esphome-web-6f71c4.yaml:37]
Component output.ledc requires component esp32.
platform: ledc
pin: GPIO14
inverted: True
Spiro
March 30, 2024, 9:44pm
4
Sorry that was for Esp32.
output:
- platform: esp8266_pwm
pin: your pin
inverted: True
Possibly will need to use inverted to true otherwise it heats up and chirps all the time. Not sure about zero means zero bit.
Sorry I must be making a newbie error- first time using buzzer.
INFO ESPHome 2024.3.1
INFO Reading configuration /config/esphome/esphome-web-6f71c4.yaml...
Failed config
output.esp8266_pwm: [source /config/esphome/esphome-web-6f71c4.yaml:37]
Pin 14 is used in multiple places.
pin:
number: 14
mode:
output: True
input: False
open_drain: False
pullup: False
pulldown: False
analog: False
inverted: False
inverted: True
frequency: 1000.0
binary_sensor.gpio: [source /config/esphome/esphome-web-6f71c4.yaml:48]
platform: gpio
pin:
number: 14
mode:
input: True
pullup: True
output: False
open_drain: False
pulldown: False
analog: False
inverted: True
filters:
- invert: {}
- delayed_on: 100ms
on_press:
- then:
- rtttl.play:
rtttl: |-
disabled_by_default: False
Spiro
March 30, 2024, 9:52pm
6
You have used the data pin for buzzer and your external button. I assume you wanted to burn buzzer on with an external switch/button
Sorry my error: I meant activate the buzzer from a button in HA.
I want to set it up so that if the car does not charge at 2330hrs then it will buzz. (Automation script)
Spiro
March 30, 2024, 10:11pm
8
api:
services:
- service: play_rtttl
variables:
song_str: string
then:
- rtttl.play:
rtttl: !lambda 'return song_str;'
- output.turn_off: rtttl_out
pin:
number: D1
inverted: True
frequency: 1000.0
This above code in ESPhome yaml will expose the esp8266 as a service. Below is the action sequence to put in your automation to play the sound. I’ll leave the trigger up to yourself.
sequence:
- service: esphome.whateveryoucalledyourespdeviceinesphome_play_rtttl
song_str: >-
Spiro
March 30, 2024, 10:17pm
9
I never had much luck with pin picking and using D1. I tended to use GPIO number. pin: 5 instead for D1 if that’s the pin you picked.
You can test if buzzer working from developer tools. In this backroom is the name of my esphome device.
stevemann
(Stephen Mann (YAML-challenged))
March 30, 2024, 10:20pm
10
Read this then post your yaml file.
Thanks, but if you read the original post, I did not have a yaml as nothing was working and I got myself in a mess
substitutions:
friendly_name: buzz
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
project:
version: '1.0'
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
#api:
# Allow Over-The-Air updates
ota:
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
output:
pin: GPIO14
inverted: True
frequency: 1000.0
api:
services:
variables:
song_str: string
then:
- rtttl.play:
error when installing to hardware:
Failed config
api: [source /config/esphome/esphome-web-6f71c4.yaml:44]
services:
variables:
song_str: string
then:
Unable to find action with the name 'rtttl.play'.
rtttl.play:
rtttl: !lambda |-
return song_str;
Spiro
March 30, 2024, 10:31pm
13
rtttl:
output: rtttl_out
Did we leave these lines out?
found this:
rtttl:
output: rtttl_out
on_finished_playback:
- logger.log: 'Song ended!'
Should that be added?
When you mention GPIO number.
The syntax would be GPIO14 in my case, rather than just pin: 14 ???
Spiro
March 30, 2024, 10:35pm
16
` on_finished_playback:
- logger.log: 'Song ended!'`
This just adds a line to the log in esphome. Won’t affect the buzzer working. Bit below is needed.
rtttl:
output: rtttl_out
just pin: 5. Don’t have to put GPIO in front. D1 is GPIO 5
Getting nowhere- no buzzing at all
Tried, GPIO14,12,13,15 as per Buzzer Shield — WEMOS documentation
and GPIO5 as a last gasp try.
Spiro
March 30, 2024, 10:53pm
19
Looking at the board on the site D1, GPIO5 is the pin needed. It is possible the Buzzer isn’t a passive buzzer but an active one so won’t work.
Looks active to me from the mlt-s540 document. @stevemann you have an electrical background, does this look like an active buzzer?
stevemann
March 30, 2024, 10:56pm
20
Have you tried contacting the shield seller to ask if they have sample code?
