I’m using an E-Paper ESP8266 Driver Board with an waveshare 1.54inch display: https://www.waveshare.com/wiki/E-Paper_ESP8266_Driver_Board
My ESP8266 does, what I want from it - except it won’t deep sleep as it should:
- it starts
- it loads all MQTT-information
- it goes to sleep
- after 5mins it wants to wake up, but does not
- instead the red LED lights up and stays there.
I can only “RESET” it or flash it with a new firmware via USB as it won’t reconnect with my Wifi then.
The YAML looks like this:
esphome:
friendly_name: TeamsEpaper
on_boot:
priority: -100
then:
- wait_until:
# waiting for valid mqtt data
mqtt.connected:
# Give some time
- component.update: current_time
# Wait for display update cycle
- delay: 5s
- component.update: teamsEpaperDisplay
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
password: "yyy"
wifi:
fast_connect: true
ssid: !secret wifi_ssid
ap:
ssid: "Teamsepaper Fallback Hotspot"
password: "zzz"
captive_portal:
# deep sleep
deep_sleep:
run_duration: 30s
sleep_duration: 5min
# Enable MQTT
mqtt:
broker: 192.168.78.18
username: user
password: xxx
client_id: teamsepaper
topic_prefix: servers/Teams
birth_message:
topic: servers/Teams/epaper
payload: online
will_message:
payload: online
# OTA MODUS
on_message:
- topic: servers/Teams/ota
payload: 'ON'
then:
- deep_sleep.prevent: deepSleep5min
- topic: servers/Teams/deepsleep
payload: 'ON'
then:
- deep_sleep.enter: deepSleep5min
# Example configuration entry
spi:
clk_pin: D5
mosi_pin: D7
font:
- file: "segoeui.ttf"
glyphs:
['&', '@', '!', ',', '.', '?', '"', '%', '(', ')', '+', '-', '_', ':', '°', '0',
'1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E',
'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S',
'T', 'U', 'V', 'W', 'X', 'Y', 'Z', ' ', 'a', 'b', 'c', 'd', 'e', 'f',
'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't',
'u', 'v', 'w', 'x', 'y', 'z','å', 'Ä', 'ä', 'Ö', 'ö', 'Ü', 'ü', '/']
glyphs:
- file: "materialdesignicons-webfont.ttf"
glyphs:
# Aktivity
- "\U000F0004" # frei
- "\U000F0849" # im Gespräch
# Status
- "\U000F0133" # verfügbar
- "\U000F0159" # beschäftigt
- "\U000F062A" # nicht stören
- "\U000F1443" # bin gleich zurück
- "\U000F1A13" # abwesend
- "\U000F015A" # offline
- "\U000F03F6" # am Telefon
- "\U000F0CDE" # out of office
# Webcam
- "\U000F05A0" # Webcam an
- "\U000F1737" # Webcam aus
text_sensor:
#MQTT TEAMS ACTIVITY
- platform: mqtt_subscribe
topic: servers/Teams/stateActivity
#MQTT TEAMS STATUS
topic: servers/Teams/stateStatus
#MQTT TEAMS WEBCAM
topic: servers/Teams/stateWebcam
topic: servers/Teams/activityText
#MQTT TEAMS STATUS
topic: servers/Teams/statusText
#MQTT TEAMS WEBCAM
topic: servers/Teams/webcamText
#MQTT LAST UPDATE
topic: servers/Teams/lastUpdate
time:
- platform: sntp
timezone: Europe/Berlin
servers : 192.168.78.1
display:
- platform: waveshare_epaper
cs_pin: D8
dc_pin: D2
busy_pin: D1
reset_pin: D4
model: 1.54inV2
update_interval: never
reset_duration: 2ms
lambda: |
it.printf(60,0, id(textDisplay), "%s", id(teamsStatusText).state.c_str());
it.printf(60,60, id(textDisplay), "%s", id(teamsActivityText).state.c_str());
it.printf(60,120, id(textDisplay), "%s", id(teamsWebcamText).state.c_str());
if (id(teamsStatusText).state == "Verfügbar") {it.print(0,0, id(iconsDisplay), "\U000F0133");}
if (id(teamsStatusText).state == "Beschäftigt") {it.print(0,0, id(iconsDisplay), "\U000F0159");}
if (id(teamsStatusText).state == "Nicht stören") {it.print(0,0, id(iconsDisplay), "\U000F062A");}
if (id(teamsStatusText).state == "Bin gleich zurück") {it.print(0,0, id(iconsDisplay), "\U000F1443");}
if (id(teamsStatusText).state == "Abwesend") {it.print(0,0, id(iconsDisplay), "\U000F1A13");}
if (id(teamsStatusText).state == "Offline") {it.print(0,0, id(iconsDisplay), "\U000F015A");}
if (id(teamsStatusText).state == "Am Telefon") {it.print(0,0, id(iconsDisplay), "\U000F03F6");}
if (id(teamsStatusText).state == "out of office") {it.print(0,0, id(iconsDisplay), "\U000F0CDE");}
if (id(teamsActivityText).state == "Nicht im Gespräch") {it.print(0,60, id(iconsDisplay), "\U000F0004");}
if (id(teamsActivityText).state == "Im Gespräch") {it.print(0,60, id(iconsDisplay), "\U000F0849");}
if (id(teamsWebcamText).state == "An") {it.print(0,120, id(iconsDisplay), "\U000F05A0");}
if (id(teamsWebcamText).state == "Aus") {it.print(0,120, id(iconsDisplay), "\U000F1737");}
it.printf(60,170, id(textDisplayKlein), "Update: %s", id(dateTime).state.c_str());
the log looks like this:
rll��|�l�|�l�b|����r�bl�b��nn�lnn���bp��lrlrl�r�n�b�nbp�rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��l��bn�|���b��nn�l��l`�nn�lnr���nrr�`p�n�r������bn�|�b��nn��l`�nn�lnr���nrl`r��nrl`��p�l`��n�l[I][logger:258]: Log initialized
[C][ota:469]: There have been 0 suspected unsuccessful boot attempts.
[I][app:029]: Running through setup()...
[C][spi:023]: Setting up SPI bus...
[C][wifi:037]: Setting up WiFi...
[C][wifi:038]: Local MAC: C8:C9:xxx
[I][wifi:257]: WiFi Connecting to 'PL.12'...
[I][wifi:518]: WiFi Connected!
[C][wifi:362]: Local MAC: C8:C9:xxx
[C][wifi:363]: SSID: [redacted]
[C][wifi:364]: IP Address: 192.168.78.240
[C][wifi:365]: BSSID: [redacted]
[C][wifi:367]: Hostname: 'teamsepaper'
[C][wifi:369]: Signal strength: -48 dB ▂▄▆█
[C][wifi:373]: Channel: 1
[C][wifi:374]: Subnet: 255.255.255.0
[C][wifi:375]: Gateway: 192.168.78.1
[C][wifi:376]: DNS1: 192.168.78.11
[C][wifi:377]: DNS2: 0.0.0.0
[D][wifi:527]: Disabling AP...
[C][ota:093]: Over-The-Air Updates:
[C][ota:094]: Address: teamsepaper.local:8266
[C][ota:097]: Using Password.
[C][api:025]: Setting up Home Assistant API server...
[C][mqtt:029]: Setting up MQTT...
[I][mqtt:176]: Connecting to MQTT...
[I][mqtt:216]: MQTT Connected!
[C][sntp:028]: Setting up SNTP...
[C][deep_sleep:037]: Setting up Deep Sleep...
[I][deep_sleep:042]: Scheduling Deep Sleep to start in 30000 ms
[I][app:062]: setup() finished successfully!
[I][app:102]: ESPHome version 2023.3.2 compiled on Apr 3 2023, 15:45:57
[C][wifi:504]: WiFi:
[C][wifi:369]: Signal strength: -50 dB ▂▄▆█
[D][text_sensor:067]: 'teamsActivity': Sending state '0'
[D][text_sensor:067]: 'teamsStatus': Sending state '0'
[D][text_sensor:067]: 'teamsWebcam': Sending state '0'
[D][text_sensor:067]: 'teamsActivityText': Sending state 'Nicht im Gespräch'
[D][text_sensor:067]: 'teamsWebcamText': Sending state 'Aus'
[D][text_sensor:067]: 'teamsStatusText': Sending state 'Verfügbar'
[D][text_sensor:067]: 'Uhrzeit': Sending state '15:44'
[D][sntp:077]: Synchronized time: 2023-04-03 15:54:24
[C][logger:293]: Logger:
[C][logger:294]: Level: DEBUG
[C][logger:295]: Log Baud Rate: 115200
[C][logger:296]: Hardware UART: UART0
[C][spi:101]: SPI bus:
[C][spi:102]: CLK Pin: GPIO14
[C][spi:104]: MOSI Pin: GPIO13
[C][spi:106]: Using HW SPI: YES
[C][waveshare_epaper:221]: Waveshare E-Paper
[C][waveshare_epaper:221]: Rotations: 0 °
[C][waveshare_epaper:221]: Dimensions: 200px x 200px
[C][waveshare_epaper:227]: Model: 1.54inV2
[C][waveshare_epaper:251]: Full Update Every: 30
[C][waveshare_epaper:252]: Reset Pin: GPIO2
[C][waveshare_epaper:253]: DC Pin: GPIO4
[C][waveshare_epaper:254]: Busy Pin: GPIO5
[C][waveshare_epaper:255]: Update Interval: never
[C][captive_portal:088]: Captive Portal:
[C][mdns:108]: mDNS:
[C][mdns:109]: Hostname: teamsepaper
[C][api:138]: API Server:
[C][api:139]: Address: teamsepaper.local:6053
[C][api:141]: Using noise encryption: YES
[C][mqtt:065]: MQTT:
[C][mqtt:066]: Server Address: 192.168.78.18:1883 (192.168.78.18)
[C][mqtt:068]: Username: [redacted]
[C][mqtt:069]: Client ID: [redacted]
[C][mqtt:071]: Discovery prefix: 'homeassistant'
[C][mqtt:072]: Discovery retain: YES
[C][mqtt:074]: Topic Prefix: 'servers/Teams'
[C][mqtt:076]: Log Topic: 'servers/Teams/debug'
[C][mqtt:079]: Availability: 'servers/Teams/epaper'
[C][sntp:053]: SNTP Time:
[C][sntp:054]: Server 1: '192.168.78.1'
[C][sntp:055]: Server 2: ''
[C][sntp:056]: Server 3: ''
[C][sntp:057]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[C][mqtt:609]: MQTT Message Trigger:
[C][mqtt:610]: Topic: 'servers/Teams/ota'
[C][mqtt:611]: QoS: 0
[C][mqtt:610]: Topic: 'servers/Teams/deepsleep'
[C][mqtt_subscribe.text_sensor:021]: MQTT Subscribe Text Sensor 'teamsActivity'
[C][mqtt_subscribe.text_sensor:022]: Topic: servers/Teams/stateActivity
[C][mqtt_subscribe.text_sensor:021]: MQTT Subscribe Text Sensor 'teamsStatus'
[C][mqtt_subscribe.text_sensor:022]: Topic: servers/Teams/stateStatus
[C][mqtt_subscribe.text_sensor:021]: MQTT Subscribe Text Sensor 'teamsWebcam'
[C][mqtt_subscribe.text_sensor:022]: Topic: servers/Teams/stateWebcam
[C][mqtt_subscribe.text_sensor:021]: MQTT Subscribe Text Sensor 'teamsActivityText'
[C][mqtt_subscribe.text_sensor:022]: Topic: servers/Teams/activityText
[C][mqtt_subscribe.text_sensor:021]: MQTT Subscribe Text Sensor 'teamsStatusText'
[C][mqtt_subscribe.text_sensor:022]: Topic: servers/Teams/statusText
[C][mqtt_subscribe.text_sensor:021]: MQTT Subscribe Text Sensor 'teamsWebcamText'
[C][mqtt_subscribe.text_sensor:022]: Topic: servers/Teams/webcamText
[C][mqtt.text_sensor:023]: MQTT Text Sensor 'Uhrzeit':
[C][mqtt.text_sensor:024]: State Topic: 'servers/Teams/sensor/uhrzeit/state'
[C][mqtt_subscribe.text_sensor:021]: MQTT Subscribe Text Sensor 'Uhrzeit'
[C][mqtt_subscribe.text_sensor:022]: Topic: servers/Teams/lastUpdate
[C][deep_sleep:049]: Setting up Deep Sleep...
[C][deep_sleep:052]: Sleep Duration: 300000 ms
[C][deep_sleep:055]: Run Duration: 30000 ms
[I][deep_sleep:116]: Beginning Deep Sleep
[I][deep_sleep:118]: Sleeping for 300000000us
[E][waveshare_epaper:119]: Timeout while displaying image!
[W][wifi_esp8266:482]: Event: Disconnected ssid='PL.12' bssid=[redacted] reason='Association Leave'
