ESP8266 boot error
i would like to ask you.
I have yaml file in ESPHome and all works ok, but if i add one more sensor into my yaml, after flash, esp will not boot and turn on to safe mode…
Here is error code from ESP8266
19:39:16.481 → 3fffffc0: feefeffe feefeffe 3fffdab0 40100481
19:39:16.481 → <<<stack<<<
19:39:16.481 →
19:39:16.481 → --------------- CUT HERE FOR EXCEPTION DECODER ---------------
19:39:16.513 →
19:39:16.513 → ets Jan 8 2013,rst cause:2, boot mode:(3,7)
19:39:16.513 →
19:39:16.513 → load 0x4010f000, len 3424, room 16
19:39:16.513 → tail 0
19:39:16.513 → chksum 0x2e
19:39:16.513 → load 0x3fff20b8, len 40, room 8
19:39:16.513 → chksum 0x2b
19:39:16.513 → csum 0x2b
19:39:16.513 → v0008c180
19:39:16.513 → ~ld
19:39:16.599 → ����n�r��n|� �l�rlb� �|r�l�n� �n� l`��r�l�l� �e[0;32m[I][logger:034]: Log initializede[0m
I dont know what is wrong. But if i removed this sensor from yaml - line 88 - 91 ESP boot ok and everything works ok. If i delete sensor odjezd1 and put here only odjezd 2 all works ok. Problem is only when there is two or more sensors…
I checked if ESP has RAM and flash size - but it looks ok too.
Can you help me? thank you
I have no idea if this will help you, but it’s worth a try:
First build a minimal configuration and flash that first. Then your normal configuration.
It helped me a long time ago.
The explanation back then was that flashing takes up far more memory than the actual code is big.
