When I flash my D1 mini clone with ESPHome, it seem to work, my board becomes visible in HA and I can connect to its webserver, but the board shuts down after a minute or so. When I reset it comes up again and after a minute shuts down again.
While when I use the Arduino IDE, the same board, it works and stays on.
Please post the YAML config youâre using, and
have you tried running it with a very minimal config just to see if something in that config is troubling it?
Do you really need the AP fallback? The next time it crashes look at 192.168.4.1 to see if it is in fallback mode.
Personally, I never use the fallback mode. If it isnât communicating, I want to know why. I would delete these lines (but thatâs just me. Maybe someone else can convince me to put them back into my code).
ap:
ssid: "Ac-2Nd-Bedroom Fallback Hotspot"
password: "l06ZWfYUZIjI"
captive_portal:
Handy if you move, or change SSIDâs/passwords in a hurry (i.e. before you have a chance to reprogram/reflash all your devices).
But thatâs a fairly extreme situation, so no, I canât think of a compelling reason for the fallback AP.
In a retail product it would make sense (so the owner could retake control and access to the device) but in your home, not so much.
Plus, if your AP does go offline for a while, you donât want your neighbors suddenly finding themselves seeing SSIDs like âbedroom heat lamp fallbackâ and so forth.
Device appears offline in ESPHome GUI, canât access the logs and I canât access the webserver on the ESP home any more
when I try to read log hostname cannot be resolved
INFO Starting log output from ac-2nd-bedroom.local using esphome API
WARNING Can't connect to ESPHome API for ac-2nd-bedroom.local: Error resolving IP address: [Errno -5] No address associated with hostname
When I keep the logs running local it seems to keep rebooting - getting online again
I tried again with verbose logging:
INFO ac-2nd-bedroom.local: Ping timed out!
INFO Disconnected from ESPHome API for ac-2nd-bedroom.local
WARNING Disconnected from API
INFO Successfully connected to ac-2nd-bedroom.local
[22:13:50][C][mdns:084]: mDNS:
[22:13:50][C][mdns:085]: Hostname: ac-2nd-bedroom
[22:13:50][V][mdns:086]: Services:
[22:13:50][V][mdns:088]: - _esphomelib, _tcp, 6053
[22:13:50][V][mdns:090]: TXT: version = 2022.6.2
[22:13:50][V][mdns:090]: TXT: mac = 58bf25db751b
[22:13:50][V][mdns:090]: TXT: platform = ESP8266
[22:13:50][V][mdns:090]: TXT: board = esp01_1m
[22:13:50][C][ota:085]: Over-The-Air Updates:
[22:13:50][C][ota:086]: Address: ac-2nd-bedroom.local:8266
[22:13:50][C][ota:089]: Using Password.
[u][u][22:13:50][W][ota:094]: Last Boot was an unhandled reset, will proceed to safe mode in 4 restarts[/u][/u]
[22:13:50][C][api:138]: API Server:
[22:13:50][C][api:139]: Address: ac-2nd-bedroom.local:6053
[22:13:50][C][api:141]: Using noise encryption: YES
[22:13:50][C][wifi_info:009]: WifiInfo IPAddress 'ac-2nd-bedroom IP'
[22:13:50][V][wifi_info:009]: Unique ID: '58bf25db751b-wifiinfo-ip'
[22:13:50][C][wifi_info:011]: WifiInfo SSID 'ac-2nd-bedroom SSID'
[22:13:50][V][wifi_info:011]: Unique ID: '58bf25db751b-wifiinfo-ssid'
[22:13:50][C][wifi_info:012]: WifiInfo BSSID 'ac-2nd-bedroom BSSID'
[22:13:50][V][wifi_info:012]: Unique ID: '58bf25db751b-wifiinfo-bssid'
[22:13:50][C][wifi_signal.sensor:009]: WiFi Signal 'ac-2nd-bedroom WiFi Signal'
[22:13:50][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[22:13:50][C][wifi_signal.sensor:009]: State Class: 'measurement'
[22:13:50][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[22:13:50][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[22:13:50][V][wifi_signal.sensor:009]: Unique ID: '58bf25db751b-wifisignal'
[22:13:51][D][api:102]: Accepted 192.168.0.36
[22:13:51][V][component:199]: Component api took a long time for an operation (0.35 s).
[22:13:51][V][component:200]: Components should block for at most 20-30ms.
[22:13:51][V][api.connection:843]: Hello from client: 'ESPHome Logs 2022.6.2 (192.168.0.36)'
[22:13:51][D][api.connection:861]: ESPHome Logs 2022.6.2 (192.168.0.36): Connected successfully
[22:13:51][D][time:041]: Synchronized time: 2022-07-26 22:13:51
[22:14:15][V][json:031]: Attempting to allocate 512 bytes for JSON serialization
[22:14:15][V][json:051]: Size after shrink 64 bytes
[22:14:15][V][json:051]: Size after shrink 156 bytes
[22:14:15][V][json:051]: Size after shrink 152 bytes
[22:14:15][V][json:051]: Size after shrink 200 bytes
[22:14:15][V][json:051]: Size after shrink 144 bytes
[22:14:15][V][json:051]: Size after shrink 444 bytes
[22:14:18][V][sensor:074]: 'ac-2nd-bedroom Uptime': Received new state 44.720001
[22:14:18][D][sensor:124]: 'ac-2nd-bedroom Uptime': Sending state 44.72000 s with 0 decimals of accuracy
and
WARNING Can't connect to ESPHome API for ac-2nd-bedroom.local: Error connecting to ('192.168.0.32', 6053): [Errno 111] Connect call failed ('192.168.0.32', 6053)
INFO Trying to reconnect to ac-2nd-bedroom.local in the background
and then it stoped
â
thanks for the feedback - tbh - just copy-pasted from the source
looks like some component youâre including has a bad memory leak.
Try omitting the third-party components. See if it runs stable. Then add them back incrementally.
Iâm guessing/hypothesizing one of them is leaking memory/heap quite badly.
Your JSON rendering lib is dying without space in which to work.
INFO ac-2nd-bedroom.local: Error while reading incoming messages: Error while reading data: [Errno 104] Connection reset by peer
INFO ac-2nd-bedroom.local: Ping Failed: Error while reading data: [Errno 104] Connection reset by peer
turned off the webserver - in the ESP Home dashboard it still alternates between online and offline, but in the logs no errors any more.
Donât know why it is showing offline.
Will add back the components again tomorrow to see if it was indeed the webserver
the only thing that I saw in the logs is what I shared, it looks like a boot sequence - repeated a couple of times. Also this log entry suggest the reboot: Last Boot was an unhandled reset, will proceed to safe mode in X restarts
Were X counted down⌠- also saw the led flashing as an indication of rebooting.
But other than that I didnât see crashes or any other info in the logs
