Esp8266 deep sleep interval
Hi, today i have made esp8266 based temp sensor. I have enabled deep sleep and it works buti cannot change deep sleep interval. Regardless of what interval I set it wakes up fter 5 min. Is there solution to it? Did any of you guys encouter similar problem? Im o the latest esphome. Sensor I am using is some bmp280 I think. I would be grateful for help.
Without knowing your code for that sensor in ESPHome, we cannot help.
Also “latest version” is not a version :smiley: 2022.3.1 should be the version right now.
Sorry for my ignorance. Here is the code:
esphome:
  friendly_name: Sensor Outside
  on_boot:
    priority: -100
    then:
      - delay: 2min
      - deep_sleep.enter: deep_sleep_1
esp8266:
  board: nodemcuv2
logger:
api:
ota:
wifi:
  ssid: XXWiFi
  password: passwdXXX
  manual_ip:
    static_ip: 192.168.1.XXX
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  fast_connect: True
i2c:
  sda: GPIO05
  scl: GPIO04
  scan: False
  - platform: bmp280
    temperature:
      name: "Outside Temperature"
      oversampling: 16x
    pressure:
      name: "Outside Pressure"
    address: 0x76
    update_interval: 5s
  - platform: adc
    pin: A0
    name: "Outside Sensor Battery"
    device_class: battery
    update_interval: 5s
    unit_of_measurement: "%"
    accuracy_decimals: 0
    filters:
      - multiply: 9
      - calibrate_linear:
          - 3 -> 0
          - 9 -> 100
deep_sleep:
  run_duration: 30s
  sleep_duration: 600s
esphome version is : 2023.5.5
Thank You :slight_smile:
  1. Why?
  2. Your code is set to 10 minutes.
I have no idea if this would work, but maybe use a numeric helper entity in Home Assistant and then a value template in the ESPHome code. That’s the limit of my knowledge.
Hi. Thans for the input. I can set any value I want but regardless it will wake up and produce data in ha history graph every 5 mins
OK, I thought you were trying to dynamically change the sleep time.
Are you sure the ESP is going to sleep? Just watch the device in ESPHome panel and watch if it actually goes to sleep.
jeeponline
I did make sure that it was online when i have flashed it wirelessly with new values. Esp does go to sleep and shows up after 5 min :man_shrugging:t2:
You are saying that it goes online for 30 seconds then offline?
online
Yes, thats correct
I’ll run your code later tonight to see what it does here. Which ESP board, specifically, are you using?
Nodemcu v2 i belive it is 12F. Thank you
I can’t duplicate your sleep problem. My NodeMCU sleeps for ten minutes reliably.
You do have GPIO16 connected to RST, don’t you?
Yes. I will try a different microcontoler then. Thank You
I do power it by 9v battery but it should not make any difference. Should it?
Through Vin, it should be OK. But, when the ESP is powering the WiFi transceiver it can draw 200mA, sucking the battery pretty fast. Is the sensor powered all the time? You wouldn’t know if the reboot is from the GPIO16-RST or the battery low because reboot is what waking from deep-sleep does.
Try powering it from a USB supply to rule that out.
I am not ready to suggest a different processor board, but if you have a few handy, then it can’t hurt.
I use 9v rechargeble 800mah. It was fresh and I tried 2 of them
I have reused microcontoler from previous wled project. Can it ba a problem?
No. I reuse my ESP boards all the time. I would still want to use a USB power brick without the battery attached to rule out a power issue.
