I know there’s several threads for similar issues but they’re a bit older and they don’t alway seem to be caused by the same thing. I’m still fairly new to HA so please bear with me.
I deployed 2 ESP32’s and an ESP8266, all Adafruit Feather boards. The ESP32’s seem rock stable but the ESP8266 seems to drop the connection every 30-45 minutes or so, sometimes shorter, sometimes longer. Usually it comes back up with in 10 seconds but there has been occasions where it took 20 minutes. Doesn’t matter how close or far I have it from the AP and I’ve tried it with multiple power supplies.
Here is my YAML file for that device.
esphome:
platform: ESP8266
board: huzzah
wifi:
ssid: "[Redacted]"
password: "[Redacted]"
ap:
ssid: "Bdrm_ac Fallback Hotspot"
password: "pRgDgic4awmR"
captive_portal:
# Enable Home Assistant API
api:
ota:
- platform: wifi_signal
name: "Bedroom AC Wifi signal"
update_interval: 60s
- platform: uptime
name: "Bedroom AC uptime"
# Example configuration entry
# Disable logging over UART (required)
logger:
baud_rate: 0
# UART settings for Midea dongle (required)
uart:
tx_pin: 3
rx_pin: 1
baud_rate: 9600
# Optional (if you want modify settings)
midea_dongle:
strength_icon: false
# Main settings
climate:
- platform: midea_ac
visual:
min_temperature: 18 °C
max_temperature: 25 °C
temperature_step: 0.1 °C
beeper: false
swing_both: true
outdoor_temperature:
power_usage:
Here’s what I’m seeing in the logfile
2021-05-14 22:34:52 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for bedroom_midea_ac (192.168.1.193): Error connecting to ('192.168.1.193', 6053): [Errno 113] Connect call failed ('192.168.1.193', 6053)
2021-05-14 22:50:12 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for bedroom_midea_ac (192.168.1.193): Error connecting to ('192.168.1.193', 6053): [Errno 113] Connect call failed ('192.168.1.193', 6053)
2021-05-15 00:43:53 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for bedroom_midea_ac (192.168.1.193): Error connecting to ('192.168.1.193', 6053): [Errno 113] Connect call failed ('192.168.1.193', 6053)
2021-05-15 04:42:03 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for bedroom_midea_ac (192.168.1.193): Timeout while connecting to ('192.168.1.193', 6053)
And this is what the ESP8266 itself spits out when I look at the live logs (when it’s actually working)
[18:47:46][I][app:105]: ESPHome version 1.17.1 compiled on May 16 2021, 12:21:06
[18:47:46][C][wifi:443]: WiFi:
[18:47:46][C][wifi:303]: SSID: [redacted]
[18:47:46][C][wifi:304]: IP Address: 192.168.1.193
[18:47:46][C][wifi:306]: BSSID: [redacted]
[18:47:46][C][wifi:307]: Hostname: 'bedroom_midea_ac'
[18:47:46][C][wifi:311]: Signal strength: -71 dB ▂▄▆█
[18:47:46][C][wifi:315]: Channel: 10
[18:47:46][C][wifi:316]: Subnet: 255.255.255.0
[18:47:46][C][wifi:317]: Gateway: 192.168.1.1
[18:47:46][C][wifi:318]: DNS1: 192.168.1.1
[18:47:46][C][wifi:319]: DNS2: (IP unset)
[18:47:46][C][uart_esp8266:075]: UART Bus:
[18:47:46][C][uart_esp8266:077]: TX Pin: GPIO3
[18:47:46][C][uart_esp8266:080]: RX Pin: GPIO1
[18:47:46][C][uart_esp8266:081]: RX Buffer Size: 256
[18:47:46][C][uart_esp8266:083]: Baud Rate: 9600 baud
[18:47:46][C][uart_esp8266:084]: Data Bits: 8
[18:47:46][C][uart_esp8266:085]: Parity: NONE
[18:47:46][C][uart_esp8266:086]: Stop bits: 1
[18:47:46][C][uart_esp8266:090]: Using software serial
[18:47:46][C][uptime.sensor:030]: Uptime Sensor 'Bedroom AC uptime'
[18:47:46][C][uptime.sensor:030]: Unit of Measurement: 's'
[18:47:46][C][uptime.sensor:030]: Accuracy Decimals: 0
[18:47:46][C][uptime.sensor:030]: Icon: 'mdi:timer-outline'
[18:47:46][C][logger:185]: Logger:
[18:47:46][C][logger:186]: Level: DEBUG
[18:47:46][C][logger:187]: Log Baud Rate: 0
[18:47:46][C][logger:188]: Hardware UART: UART0
[18:47:46][C][captive_portal:169]: Captive Portal:
[18:47:46][C][ota:029]: Over-The-Air Updates:
[18:47:46][C][ota:030]: Address: bedroom_midea_ac.local:8266
[18:47:46][C][api:095]: API Server:
[18:47:46][C][api:096]: Address: bedroom_midea_ac.local:6053
[18:47:46][C][wifi_signal.sensor:009]: WiFi Signal 'Bedroom AC Wifi signal'
[18:47:46][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[18:47:46][C][wifi_signal.sensor:009]: Unit of Measurement: 'dB'
[18:47:46][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
Before I just go ahead and return this ESP8266 and swap it out for another ESP32 is there anything I should try first?
