ESP8266 | ESP-01S relay did not save states after power failure
Device Type: 5V ESP8266 ESP-01 2 Channel WiFi Relay Module 2 Channel Relay Module.
Board: ESP8266 + ESP-01S.
Problem: Relay did not save it states after reboot.
ESP-01S flashed and controlled by ESPHome Addon from IP address or HA entities.
Tried different configs here, but as a lack of practice, I can’t figure it out by myself. Relay cant retrieve it last state and switch to it after power loss. Last config I tried saves last state for HA entity, but not for relay. Tried configs with restore_from_flash and power_on_state, so far I’m stuck. Can someone please point me in the right direction?
My config from ESPHome device yaml for simple relay control:
esphome:
  friendly_name: Water Controller
esp8266:
  board: esp01_1m
logger:
  baud_rate: 0 #need this to free up UART pins
api:
  encryption:
    key: "..."
ota:
  password: "..."
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Water-Controller Hotspot"
    password: "..."
captive_portal:
web_server:
  port: 80
time:
  - platform: homeassistant
text_sensor:
  - platform: version
    name: Relay ESPHome Version
  - platform: wifi_info
    ip_address:
    bssid:
  - platform: uptime
  - platform: wifi_signal
    name: Relay WiFi Signal
    update_interval: 60s
uart:
  baud_rate: 115200
  tx_pin: GPIO1
  rx_pin: GPIO3
switch:
    turn_on_action:
      - uart.write: [0xA0, 0x01, 0x01, 0xA2]
    turn_off_action:
      - uart.write: [0xA0, 0x01, 0x00, 0xA1]
    optimistic: true
    turn_on_action:
      - uart.write: [0xA0, 0x02, 0x01, 0xA3]
    turn_off_action:
      - uart.write: [0xA0, 0x02, 0x00, 0xA2]
    optimistic: true
What do I need to add here?
Thank you!
lookup restore_mode, at least that’s what I’m using for my athom plugs
restore_mode: RESTORE_DEFAULT_OFF
Thank you. Small progress here:
After adding
restore_from_flash: true
preferences: flash_write_interval: 1sec
and
to every relay I got this strange behavior:
relay1 did not retrieve (or save) it state after turn off, but relay2 works as intended.
My code now is:
esphome:
esp8266:
  board: esp01_1m
preferences:
logger:
  baud_rate: 0
api:
  encryption:
    key: "..."
ota:
  password: "..."
wifi:
  ap:
    password: "..."
captive_portal:
web_server:
  port: 80
time:
text_sensor:
  - platform: version
    ip_address:
    bssid:
  - platform: uptime
uart:
  baud_rate: 115200
  tx_pin: GPIO1
  rx_pin: GPIO3
switch:
    turn_on_action:
    turn_off_action:
    optimistic: true
    turn_on_action:
    turn_off_action:
    optimistic: true
Why relay1 behave so? Did I mess something?
I don’t see any issues: I use same entries:
substitutions:
  relay_restore_mode: RESTORE_DEFAULT_OFF
esp8266:
  board: esp8285
preferences:
  flash_write_interval: 1min
switch:
  - platform: gpio
    pin: GPIO12
    restore_mode: ${relay_restore_mode}
I would try to restart the relay, or put it without power for x minutes to get the flash cleared. Or re-upload code after keeping it off power for a few minutes
Just found another esp-01s module and tested it on UART adapter, and it works! Flipped new one with the old - still relay1 issues. The problem with relay itself.
So the question now - is there something I can do with it to make it work properly? It has 2 jumpers and s1/s2 buttons on it.
This is the one:
Screenshot 2023-10-21 120955
Relay was with its own logic aboard. Was needed to add some delay to esp8266 after relay was fully booted.
Adding this code did the trick:
esphome:
  on_boot:
    priority: 1000
    then:
      - lambda: |-
          delay(7000);
have a look at my new post on this
