Hello everybody,
i want to use an esp8266 to control a 5V fan (from a 3d printer, link to product on amazon.it) and read the temperature from an NTC thermistor.
For the software part I don’t think I will have any problem, but electronics is not my best skill… So could you guys check if my drawing is correct?
I didn’t find any info about but are the 3.3V and the 5V pins in or out?
Karosm
(Karosm)
2
Wiring looks correct, but your relay module needs more investigation.
Do you have a link?
sure, this is the link https://www.amazon.it/gp/product/B07BVXT1ZK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
evetually can i just power the esp (by the usb port) and use a gpio to power on the fan? bypassing the relay?
Karosm
(Karosm)
4
You can’t use gpio to power something!
ok I thought that once the gpio is closed it provide the 5v signal or something similar… sorry newbie silly question…
Karosm
(Karosm)
6
And your relay module is not compatible with Esp8266, it’s good only for 5V MCU, like arduino.
Karosm
(Karosm)
7
It provides 3.3V signal. But just signal, not power for a fan. Max current draw from Gpio pin is ~12mA.
thank you,
even if I will get the 5v to power the relay directly from the power supply and use the gpio for trigger it?
I also have some esp32 full size board like these (https://www.amazon.it/gp/product/B074RGW2VQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1) are these compatible with the relay?
Karosm
(Karosm)
9
Noup.
Esp in 3.3V MCU.
You can use 3.3V relay module, 5V relay module with separate driver circuit, 3.3V mosfet module or just simple NPN transistor with two resistors.
https://www.amazon.it/kwmobile-Modulo-relè-canali-Arduino/dp/B01H2D2RI0/
Sorry I am lost a bit…
So I can’t use the relay like this?
sorry but what is the difference between the relay you linked and the ones I have?
Karosm
(Karosm)
11
It has separate 5V power pins and optocoupled (3.3V) input pins.
mosfet:
Transistor circuit:
Thanks again for your time
so with mosfet can I wire like so?
EDIT: in picure in and out are inverted… I noticed just now, anyway OUT +/- to the fan, DC+/- to the power source
