Is the output supposed to be only text?
I reviewed the wiring and got this result.
I’m using an external 3.3 volt power supply.
Will use the DSC battery as a power supply and test again.
[11:42:55][I][Paneldata: :978]: C1: C1 00 2B 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Moduledata::978]: C1: 1F 01 1F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 08: 08 00 19 9F 8F 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 3F: 3F 01 52 2F FF 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 91: 91 01 27 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 0D: 0D 01 48 80 1B 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Moduledata::978]: 0D: 1F 00 FF FF 07 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: C7: C7 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Moduledata::978]: C7: FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 32: 32 01 49 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 7F: 7F 01 FE 47 3F 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 82: 82 01 58 80 CB 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Moduledata::978]: 82: 3F 01 7F FF 3F 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 05: 05 00 97 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][D][info:1785]: status 01, last status DF,line2status 55,selection 01,partition=1,skip=0
[11:42:55][D][text_sensor:067]: 'dscalarm line1': Sending state 'System is Ready'
[11:42:55][D][text_sensor:067]: 'dscalarm line2': Sending state 'Zone 07 <>'
[11:42:55][D][info:1785]: status 00, last status 8E,line2status 55,selection 01,partition=2,skip=0
[11:42:55][D][text_sensor:067]: 'dscalarm line1 partition 2': Sending state 'Secure System'
[11:42:55][D][text_sensor:067]: 'dscalarm line2 partition 2': Sending state 'Before Arming <>'
[11:42:55][D][info:1785]: status 00, last status 02,line2status 55,selection 01,partition=3,skip=0
[11:42:55][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=4,skip=0
[11:42:55][D][text_sensor:067]: 'dscalarm Partition 1 Status ': Sending state 'disarmed'
[11:42:55][I][Moduledata::978]: CF: 0F 00 1C 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 01: 01 01 25 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: CF: CF 01 07 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: CF: CF 01 03 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 52: 52 00 4F FE 47 0F 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 05: 05 00 B7 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][D][info:1785]: status 01, last status 01,line2status 55,selection 01,partition=1,skip=0
[11:42:55][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=2,skip=0
[11:42:55][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=3,skip=0
[11:42:55][I][Paneldata: :978]: 01: 01 01 27 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: C7: C7 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 52: 52 00 47 1F 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 98: 98 01 C7 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: E0: E0 01 2B 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 10: 10 00 33 7F 0F 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 7F: 7F 01 A9 17 7F 00 00 00 00 00 00 00 00 00 00 00
[11:42:55][I][Paneldata: :978]: 91: 91 01 13 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 3A: 3A 01 49 BF 0F 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: E4: E4 00 E7 07 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: CF: CF 01 03 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Moduledata::978]: CF: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 52: 52 00 4F 3F 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 91: 91 01 8F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 8F: 8F 00 A4 41 07 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Moduledata::978]: 8F: 07 01 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 1C: 1C 00 0F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 1F: 1F 00 A4 43 FB 1C 0F 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 1E: 1E 01 48 83 03 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Moduledata::978]: 1E: 0F 01 FF 7F 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 01: 01 01 2F C7 01 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Moduledata::978]: 01: FF 01 1F FF 02 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: C7: C7 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Moduledata::978]: C7: 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 52: 52 00 40 77 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Moduledata::978]: 52: 7F 01 FF 0E 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 2E: 2E 00 0F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Moduledata::978]: 2E: 6F 01 1F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 7F: 7F 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 52: 52 00 27 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: FF: FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: CF: CF 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 52: 52 00 47 FC 8E 1F 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 32: 32 01 49 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 7F: 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: C8: C8 01 67 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][I][Paneldata: :978]: 05: 05 00 93 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:56][D][info:1785]: status 01, last status 01,line2status 55,selection 01,partition=1,skip=0
[11:42:56][D][text_sensor:067]: 'dscalarm line1': Sending state 'System is Ready'
[11:42:57][D][text_sensor:067]: 'dscalarm line2': Sending state 'Zone 07 <>'
[11:42:57][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=2,skip=0
[11:42:57][D][text_sensor:067]: 'dscalarm line1 partition 2': Sending state 'Secure System'
[11:42:57][D][text_sensor:067]: 'dscalarm line2 partition 2': Sending state 'Before Arming <>'
[11:42:57][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=3,skip=0
[11:42:57][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=4,skip=0
[11:42:57][I][Paneldata: :978]: 7F: 7F 01 FC 8E 7F 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 25: 25 00 93 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 7F: 7F 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: E4: E4 00 E7 07 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 05: 05 00 93 BF CC 8E 07 00 00 00 00 00 00 00 00 00
[11:42:57][D][info:1785]: status BF, last status 01,line2status 55,selection 01,partition=1,skip=0
[11:42:57][D][info:1785]: status 8E, last status 00,line2status 55,selection 01,partition=2,skip=0
[11:42:57][I][Paneldata: :978]: C7: C7 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Moduledata::978]: C7: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 52: 52 00 43 FC C7 0F 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 82: 82 01 58 80 CB 03 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Moduledata::978]: 82: 3F 01 7F FF 3F 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: C7: C7 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 3D: 3D 00 A4 5F FF 91 33 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 05: 05 00 97 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][D][info:1785]: status 00, last status BF,line2status 55,selection 01,partition=1,skip=0
[11:42:57][D][text_sensor:067]: 'dscalarm line1': Sending state 'Secure System'
[11:42:57][D][info:1785]: status 00, last status 8E,line2status 55,selection 01,partition=2,skip=0
[11:42:57][D][text_sensor:067]: 'dscalarm Partition 1 Msg ': Sending state '00: Unknown'
[11:42:57][D][text_sensor:067]: 'dscalarm Partition 1 Status ': Sending state 'unavailable'
[11:42:57][D][binary_sensor:036]: 'dscalarm Partition 1 Ready': Sending state OFF
[11:42:57][I][Paneldata: :978]: C0: C0 00 C9 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 01: 01 01 2F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 05: 05 00 93 BF EC 8E 7F 00 00 00 00 00 00 00 00 00
[11:42:57][D][info:1785]: status BF, last status 00,line2status 55,selection 01,partition=1,skip=0
[11:42:57][I][Paneldata: :978]: CF: CF 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Moduledata::978]: CF: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 52: 52 00 43 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 91: 91 01 8F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:57][I][Paneldata: :978]: 52: 52 00 43 FB 1C 7C 7A 91 07 01 00 00 00 00 00 00
[11:42:57][I][Moduledata::978]: 52: FF 01 7F 07 FF F9 1F FF 3F 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: B1: B1 01 8F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 01: 01 01 2F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: C7: C7 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Moduledata::978]: C7: FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 7F: 7F 01 52 27 FF 91 33 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: D4: D4 01 17 7F 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 91: 91 01 13 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Moduledata::978]: 91: FF 01 1E 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 3F: 3F 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 52: 52 00 4F FF 23 13 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 52: 52 00 4F 7F 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 91: 91 01 9F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 05: 05 00 B9 03 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][D][info:1785]: status 03, last status BF,line2status 55,selection 01,partition=1,skip=0
[11:42:58][D][text_sensor:067]: 'dscalarm line1': Sending state 'Secure System'
[11:42:58][D][text_sensor:067]: 'dscalarm line2': Sending state 'Zone 07 <>'
[11:42:58][D][info:1785]: status 00, last status 8E,line2status 55,selection 01,partition=2,skip=0
[11:42:58][D][text_sensor:067]: 'dscalarm line1 partition 2': Sending state 'Secure System'
[11:42:58][D][text_sensor:067]: 'dscalarm line2 partition 2': Sending state 'Before Arming <>'
[11:42:58][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=3,skip=0
[11:42:58][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=4,skip=0
[11:42:58][D][text_sensor:067]: 'dscalarm Partition 1 Msg ': Sending state '03: Zones open'
[11:42:58][I][Moduledata::978]: E0: 0F 01 0F 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 01: 01 01 2F C7 03 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: E0: E0 01 02 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 22: 22 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: E0: E0 01 57 07 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Moduledata::978]: E0: 0F 01 1F 03 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: C7: C7 01 07 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Moduledata::978]: 1F: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 1F: 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 52: 52 00 43 F9 1C 0F 00 00 00 00 00 00 00 00 00 00
[11:42:58][I][Paneldata: :978]: 7F: 7F 01 A9 17 7F 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][D][text_sensor:067]: 'dscalarm partition 2 beeps': Sending state '0'
[11:42:59][I][Moduledata::978]: 05: 7F 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][I][Paneldata: :978]: 62: 62 00 06 6F 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][I][Paneldata: :978]: C7: C7 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][I][Paneldata: :978]: 1E: 1E 01 48 83 F6 38 0F 00 00 00 00 00 00 00 00 00
[11:42:59][I][Moduledata::978]: 1E: 0F 01 FF 3F 0F FF 0F 00 00 00 00 00 00 00 00 00
[11:42:59][I][Paneldata: :978]: 05: 05 00 B7 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][D][info:1785]: status 01, last status 03,line2status 55,selection 01,partition=1,skip=0
[11:42:59][D][text_sensor:067]: 'dscalarm line1': Sending state 'System is Ready'
[11:42:59][D][text_sensor:067]: 'dscalarm line2': Sending state 'Zone 07 <>'
[11:42:59][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=2,skip=0
[11:42:59][D][text_sensor:067]: 'dscalarm line1 partition 2': Sending state 'Secure System'
[11:42:59][D][text_sensor:067]: 'dscalarm line2 partition 2': Sending state 'Before Arming <>'
[11:42:59][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=3,skip=0
[11:42:59][D][info:1785]: status 00, last status 00,line2status 55,selection 01,partition=4,skip=0
[11:42:59][D][text_sensor:067]: 'dscalarm Partition 1 Msg ': Sending state '01: Ready'
[11:42:59][D][text_sensor:067]: 'dscalarm Partition 1 Status ': Sending state 'disarmed'
[11:42:59][D][binary_sensor:036]: 'dscalarm Partition 1 Ready': Sending state ON
[11:42:59][I][Paneldata: :978]: 01: 01 01 2F C7 01 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][I][Paneldata: :978]: 7F: 7F 01 52 27 FF 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][I][Paneldata: :978]: 91: 91 01 8F 01 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][I][Paneldata: :978]: 05: 05 00 93 0B 00 00 00 00 00 00 00 00 00 00 00 00
[11:42:59][D][info:1785]: status 0B, last status 01,line2status 55,selection 01,partition=1,skip=0
[11:42:59][D][text_sensor:067]: 'dscalarm line1': Sending state 'Quick exit '
[11:42:59][D][text_sensor:067]: 'dscalarm line2': Sending state 'in progress '
[11:42:59][D][text_sensor:067]: 'dscalarm Partition 1 Msg ': Sending state '0B: Quick exit'
[11:42:59][D][text_sensor:067]: 'dscalarm Partition 1 Status ': Sending state 'unavailable'
[11:42:59][D][binary_sensor:036]: 'dscalarm Partition 1 Ready': Sending state OFF
[11:42:59][I][Paneldata: :978]: FB: FB 00 47 0F 00 00 00 00 00 00 00 00 00 00 00 00
