Strange, as I haven’t changed anything, and it was working fine before. I can’t recall what caused the issue, but I can only assume an ESPHome update, especially since the exact same problem appeared for a friend whose interface I configured.
Here’s the full boot log, though it doesn’t seem like anything specific is needed to trigger this. The zone status is reported like this immediately after boot.
INFO Starting log output from 192.168.33.111 using esphome API
INFO Successfully connected to dscalarm @ 192.168.33.111 in 2.038s
INFO Successful handshake with dscalarm @ 192.168.33.111 in 0.109s
[21:38:19][I][app:100]: ESPHome version 2025.2.2 compiled on Mar 3 2025, 17:21:31
[21:38:19][C][logger:177]: Logger:
[21:38:19][C][logger:178]: Max Level: DEBUG
[21:38:19][C][logger:179]: Initial Level: DEBUG
[21:38:19][C][logger:181]: Log Baud Rate: 115200
[21:38:19][C][logger:182]: Hardware UART: UART0
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z1-Előszoba'
[21:38:19][C][template_alarm.binary_sensor:032]: Device Class: 'motion'
[21:38:19][I][Panel :979]: [2025-03-11 21:38] E6: E6 00 18 01 00 00 00 00 00 FF 00 00 00 00 00 00 (74)
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z2-Garázs'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z3-Konyha'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z4-Üvegtörés'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z5-Nappali'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z6-Gaming Room'
[21:38:19][I][Panel :979]: [2025-03-11 21:38] 0A: 0A 00 80 9E 00 00 00 00 00 28 00 00 00 00 00 00 (74)
[21:38:19][I][Module:979]: [2025-03-11 21:38] 0A: FF 01 0A FF FF FF FF FF FF FF 01 00 00 00 00 00 (74)
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z8-Szabotázs'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z9-Emelet'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z17-Bejárati ajtó'
[21:38:19][C][template_alarm.binary_sensor:032]: Device Class: 'door'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z18-Terasz ajtó nagy'
[21:38:19][I][Panel :979]: [2025-03-11 21:38] 0A: 0A 00 80 A1 00 00 00 00 00 2B 00 00 00 00 00 00 (74)
[21:38:19][I][Module:979]: [2025-03-11 21:38] 0A: FF 01 05 FF FF FF FF FF FF FF 01 00 00 00 00 00 (74)
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z19-Terasz ajtó kis'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z20-Konyha ablak'
[21:38:19][C][template_alarm.binary_sensor:032]: Device Class: 'window'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z21-Garázskapu'
[21:38:19][C][template_alarm.binary_sensor:032]: Device Class: 'garage_door'
[21:38:19][I][Panel :979]: [2025-03-11 21:38] 5D: 5D 00 10 00 00 00 00 6D 00 00 00 00 00 00 00 00 (58)
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z22-Gaming Window'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z23-Lenti fürdőszoba ablak'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'z24-Kamra ablak'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'dscalarm Partition 1 Ready'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'dscalarm Partition 1 Armed'
[21:38:19][I][Panel :979]: [2025-03-11 21:38] E6: E6 00 18 01 10 00 00 00 00 0F 00 00 00 00 00 00 (74)
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'dscalarm Trouble Status'
[21:38:19][C][template_alarm.binary_sensor:032]: Device Class: 'problem'
[21:38:19][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'dscalarm Battery Status'
[21:38:19][I][Panel :979]: [2025-03-11 21:38] 64: 64 00 04 68 00 00 00 00 00 00 00 00 00 00 00 00 (26)
[21:38:19][D][text_sensor:064]: 'dscalarm beeps': Sending state '2'
[21:38:19][I][dscalarm:2072]: status 01, last status 01,selection 01,partition=1,skip=0,force=0
[21:38:20][D][text_sensor:064]: 'dscalarm line1': Sending state 'System is Ready'
[21:38:20][D][text_sensor:064]: 'dscalarm line2': Sending state 'Ready to Arm <>'
[21:38:20][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'dscalarm AC Status'
[21:38:20][C][template_alarm.binary_sensor:032]: Device Class: 'plug'
[21:38:20][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'dscalarm Fire partition 1 Status'
[21:38:20][C][template_alarm.binary_sensor:032]: Device Class: 'smoke'
[21:38:20][I][Panel :979]: [2025-03-11 21:38] 0A: 0A 00 80 C8 00 00 00 00 00 52 00 00 00 00 00 00 (74)
[21:38:20][I][Module:979]: [2025-03-11 21:38] 0A: FF 01 2D FF FF FF FF FF FF FF 01 00 00 00 00 00 (74)
[21:38:20][C][template_alarm.binary_sensor:032]: Template Alarm Binary Sensor 'Partition 1 Alarm Status'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'dscalarm System Status'
[21:38:20][C][template_alarm.text_sensor:021]: Icon: 'mdi:shield'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'zone status'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'Partition 1 Status'
[21:38:20][I][Panel :979]: [2025-03-11 21:38] 0A: 0A 00 80 A1 00 00 00 00 00 2B 00 00 00 00 00 00 (74)
[21:38:20][I][Module:979]: [2025-03-11 21:38] 0A: FF 01 1C FF FF FF FF FF FF FF 01 00 00 00 00 00 (74)
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'Partition 1 Msg'
[21:38:20][C][template_alarm.text_sensor:021]: Icon: 'mdi:alert-box'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'zone that triggered last alarm'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'Arming/Disarming user'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'dscalarm line1'
[21:38:20][I][Panel :979]: [2025-03-11 21:38] 5D: 5D 00 10 00 00 00 00 6D 00 00 00 00 00 00 00 00 (58)
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'dscalarm line2'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'dscalarm event'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'dscalarm beeps'
[21:38:20][C][template_alarm.text_sensor:021]: Template Alarm Sensor 'Trouble Msg'
[21:38:20][C][template.switch:068]: Template Switch 'dscalarm Connection'
[21:38:20][C][template.switch:070]: Icon: 'mdi:shield-link-variant'
[21:38:20][C][template.switch:091]: Restore Mode: always OFF
[21:38:20][C][template.switch:057]: Optimistic: NO
[21:38:20][I][Panel :979]: [2025-03-11 21:38] E6: E6 00 18 01 10 00 00 00 00 0F 00 00 00 00 00 00 (74)
[21:38:20][I][Panel :979]: [2025-03-11 21:38] 64: 64 00 02 66 00 00 00 00 00 00 00 00 00 00 00 00 (26)
[21:38:20][D][text_sensor:064]: 'dscalarm beeps': Sending state '1'
[21:38:20][I][dscalarm:2072]: status 01, last status 01,selection 01,partition=1,skip=0,force=0
[21:38:20][C][homeassistant.time:010]: Home Assistant Time:
[21:38:20][C][homeassistant.time:011]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[21:38:20][C][restart:068]: Restart Switch 'restart_switch'
[21:38:20][C][restart:070]: Icon: 'mdi:restart'
[21:38:20][C][restart:091]: Restore Mode: always OFF
[21:38:20][C][safe_mode.switch:068]: Safe Mode Switch 'Safe Mode'
[21:38:20][C][safe_mode.switch:070]: Icon: 'mdi:restart-alert'
[21:38:20][C][safe_mode.switch:091]: Restore Mode: always OFF
[21:38:20][C][restart.button:017]: Restart Button 'Reboot'
[21:38:20][C][restart.button:017]: Icon: 'mdi:restart'
[21:38:20][C][ethernet:326]: Ethernet:
[21:38:20][C][ethernet:515]: IP Address: 192.168.33.111
[21:38:20][C][ethernet:516]: Hostname: 'dscalarm'
[21:38:20][C][ethernet:517]: Subnet: 255.255.255.0
[21:38:20][C][ethernet:518]: Gateway: 192.168.33.254
[21:38:20][C][ethernet:523]: DNS1: 8.8.8.8
[21:38:20][C][ethernet:524]: DNS2: 0.0.0.0
[21:38:20][C][ethernet:536]: MAC Address: A8:03:2A:21:E3:D4
[21:38:20][C][ethernet:537]: Is Full Duplex: YES
[21:38:20][C][ethernet:538]: Link Speed: 100
[21:38:20][C][ethernet:345]: Power Pin: 16
[21:38:20][C][ethernet:347]: MDC Pin: 23
[21:38:20][C][ethernet:348]: MDIO Pin: 18
[21:38:20][C][ethernet:349]: PHY addr: 1
[21:38:20][C][ethernet:351]: Type: LAN8720
[21:38:20][I][Panel :979]: [2025-03-11 21:38] 0A: 0A 00 80 BA 00 00 00 00 00 44 00 00 00 00 00 00 (74)
[21:38:20][C][mdns:116]: mDNS:
[21:38:20][C][mdns:117]: Hostname: dscalarm
[21:38:20][C][esphome.ota:073]: Over-The-Air updates:
[21:38:20][C][esphome.ota:074]: Address: dscalarm.localdomain:3232
[21:38:20][C][esphome.ota:075]: Version: 2
[21:38:20][C][esphome.ota:078]: Password configured
[21:38:20][C][safe_mode:018]: Safe Mode:
[21:38:20][C][safe_mode:020]: Boot considered successful after 60 seconds
[21:38:20][C][safe_mode:021]: Invoke after 10 boot attempts
[21:38:20][C][safe_mode:023]: Remain in safe mode for 300 seconds
[21:38:20][C][api:140]: API Server:
[21:38:20][C][api:141]: Address: dscalarm.localdomain:6053
[21:38:20][C][api:143]: Using noise encryption: YES
[21:38:20][I][Panel :979]: [2025-03-11 21:38] 5D: 5D 00 00 00 00 00 00 5D 00 00 00 00 00 00 00 00 (58)
[21:38:20][I][Panel :979]: [2025-03-11 21:38] E6: E6 00 18 01 00 00 00 00 00 FF 00 00 00 00 00 00 (74)
[21:38:20][I][Panel :979]: [2025-03-11 21:38] 11: 11 00 AA AA AA AA AA AA AA 02 00 00 00 00 00 00 (67)
[21:38:20][I][Module:979]: [2025-03-11 21:38] 11: FF 01 3F FC FF FF FF FF FF 03 00 00 00 00 00 00 (67)
[21:38:21][D][api:103]: Accepted 192.168.9.200
[21:38:21][W][component:237]: Component api took a long time for an operation (53 ms).
[21:38:21][W][component:238]: Components should block for at most 30 ms.
[21:38:21][D][api.connection:1446]: Home Assistant 2025.3.1 (192.168.9.200): Connected successfully
[21:38:21][D][time:051]: Synchronized time: 2025-03-11 21:38:21
[21:38:22][D][text_sensor:064]: 'dscalarm beeps': Sending state '0'
[21:38:24][I][Panel :979]: [2025-03-11 21:38] 11: 11 00 AA AA AA AA AA AA AA 02 00 00 00 00 00 00 (67)
[21:38:24][I][Module:979]: [2025-03-11 21:38] 11: FF 01 3F FC FF FF FF FF FF 03 00 00 00 00 00 00 (67)
[21:38:29][I][Panel :979]: [2025-03-11 21:38] 2D: 2D 00 81 01 81 C7 00 F7 00 00 00 00 00 00 00 00 (58)
[21:38:29][I][Panel :979]: [2025-03-11 21:38] 11: 11 00 AA AA AA AA AA AA AA 02 00 00 00 00 00 00 (67)
[21:38:29][I][Module:979]: [2025-03-11 21:38] 11: FF 01 3F FC FF FF FF FF FF 03 00 00 00 00 00 00 (67)
[21:38:32][I][Panel :979]: [2025-03-11 21:38] 11: 11 00 AA AA AA AA AA AA AA 02 00 00 00 00 00 00 (67)
[21:38:32][I][dscalarm:2072]: status 01, last status 01,selection 01,partition=1,skip=0,force=1
[21:38:32][D][text_sensor:064]: 'Partition 1 Status': Sending state 'ready'
[21:38:32][D][text_sensor:064]: 'zone status': Sending state 'TA:1,TA:2,TA:3,TA:4,TA:5,TA:6,TA:8,TA:9,TA:17,TA:18,TA:19,TA:20,TA:21,TA:22,TA:23,TA:24'
[21:38:33][I][Module:979]: [2025-03-11 21:38] 11: FF 01 3F FC FF FF FF FF FF 03 00 00 00 00 00 00 (67)
[21:38:36][I][Panel :979]: [2025-03-11 21:38] 11: 11 00 AA AA AA AA AA AA AA 02 00 00 00 00 00 00 (67)
[21:38:36][I][Module:979]: [2025-03-11 21:38] 11: FF 01 3F FC FF FF FF FF FF 03 00 00 00 00 00 00 (67)
[21:38:40][I][Panel :979]: [2025-03-11 21:38] 11: 11 00 AA AA AA AA AA AA AA 02 00 00 00 00 00 00 (67)
[21:38:40][I][Module:979]: [2025-03-11 21:38] 11: FF 01 3F FC FF FF FF FF FF 03 00 00 00 00 00 00 (67)
