thanks Dilbert, my pins are definitely right 18 21 22, checked now, also they are default to that on the new branch code in both dscalarm.yaml and dscalarm.h
I think it must be wiring, just not sure how.
I connected the transistor with emitter to ground/black, base to 18 and collector to green (resistors included)
Will play around some more and see if come right, thanks for the input
Update: So after playing around I accidentally solved the problem, total noob mistake, i had my esp 32 on the protoboard but I didnt solder it on yet incase i needed to pop it off and reprogram if i couldnt access ota, anyway it moved a bit while working on the board and made ‘better’ contact, boom all the readings rushed into the logs. I assumed the stand off pins made proper contact without soldering.
Still getting a couple moduledata and panel data messages, are these normal? my assumption is once i solder the esp32 it shouldnt do that anymore, unless my wiring is still kak
Thanks very much for this project!
[20:14:23][D][info:1758]: status 03, last status 03,line2status 70,selection 01,partition=2,skip=0
[20:14:23][D][text_sensor:067]: 'dscalarm line1 partition 2': Sending state 'Secure System'
[20:14:23][D][text_sensor:067]: 'dscalarm line2 partition 2': Sending state 'Zone 11 <>'
[20:14:23][D][binary_sensor:036]: 'dscalarm Basement windows(z8)': Sending state OFF
[20:14:23][D][text_sensor:067]: 'dscalarm zone status ': Sending state 'OP:12'
[20:14:26][I][Paneldata: :956]: 11: 11 00 AA AA AA AA AA AA AA 02 00 00 00 00 00 00
[20:14:26][I][Moduledata::956]: 11: FF 01 FF FC 0F FF FF FF FF 03 00 00 00 00 00 00
[20:14:27][I][Paneldata: :956]: 27: 27 00 82 05 80 03 80 B1 00 00 00 00 00 00 00 00
[20:14:27][D][info:1758]: status 05, last status 05,line2status 70,selection 01,partition=1,skip=0
[20:14:27][D][text_sensor:067]: 'dscalarm line1': Sending state 'Armed: '
[20:14:27][D][text_sensor:067]: 'dscalarm line2': Sending state 'Away '
[20:14:27][D][info:1758]: status 03, last status 03,line2status 70,selection 01,partition=2,skip=0
[20:14:27][D][text_sensor:067]: 'dscalarm line1 partition 2': Sending state 'Secure System'
[20:14:27][D][text_sensor:067]: 'dscalarm line2 partition 2': Sending state 'Zone 11 <>'
[20:14:27][D][binary_sensor:036]: 'dscalarm Basement windows(z8)': Sending state ON
[20:14:27][D][text_sensor:067]: 'dscalarm zone status ': Sending state 'OP:8,OP:12'
[20:14:27][D][text_sensor:067]: 'dscalarm Trouble Msg ': Sending state ''
[20:14:29][I][Paneldata: :956]: 27: 27 00 82 05 80 03 00 31 00 00 00 00 00 00 00 00
[20:14:29][D][info:1758]: status 05, last status 05,line2status 70,selection 01,partition=1,skip=0
[20:14:29][D][text_sensor:067]: 'dscalarm line1': Sending state 'Armed: '
[20:14:29][D][text_sensor:067]: 'dscalarm line2': Sending state 'Away '
[20:14:29][D][info:1758]: status 03, last status 03,line2status 70,selection 01,partition=2,skip=0
[20:14:29][D][text_sensor:067]: 'dscalarm line1 partition 2': Sending state 'Secure System'
[20:14:29][D][text_sensor:067]: 'dscalarm line2 partition 2': Sending state 'Zone 11 <>'
[20:14:29][D][binary_sensor:036]: 'dscalarm Basement windows(z8)': Sending state OFF
[20:14:29][D][text_sensor:067]: 'dscalarm zone status ': Sending state 'OP:12'
[20:14:30][D][text_sensor:067]: 'dscalarm zone status ': Sending state 'OP:12'
[20:14:31][D][text_sensor:067]: 'dscalarm Partition 1 Msg ': Sending state '05: Armed away'
[20:14:35][D][text_sensor:067]: 'dscalarm line1': Sending state 'Armed: '
[20:14:35][D][text_sensor:067]: 'dscalarm Partition 2 Msg ': Sending state '03: Zones open'
[20:14:39][D][text_sensor:067]: 'dscalarm beeps': Sending state '0'
[20:14:40][I][Paneldata: :956]: 27: 27 00 82 05 80 03 00 31 00 00 00 00 00 00 00 00
[20:14:40][D][info:1758]: status 05, last status 05,line2status 70,selection 01,partition=1,skip=0
[20:14:40][D][text_sensor:067]: 'dscalarm line1': Sending state 'Armed: '
