LuigiS00
(Luigi)
April 15, 2022, 8:41pm
1
Esp8266 as a wifi button
i’m new with home assistant and I’d like to create an automation that toggle my switch when I push the button on my Esp8266.
I just flashed the esp8266 firmware with EspHome.
My problem is that I can’t create an automation that trigger the light switch when I click the button on my esp8266.
Here is the code:
---CODE INSIDE MY ESP8266:---
binary_sensor:
- platform: gpio
pin: 4
device_class: lock
---AUTOMATION CODE THAT DOESN'T WORK:---
alias: Turn On
description: ''
mode: single
- platform: state
entity_id: binary_sensor.pulsanted2
to: 'on'
condition: []
- service: switch.toggle
entity_id: switch.1000a595a6
nickrout
(Nick Rout)
April 15, 2022, 8:46pm
2
What does the esphome log say when you press the button?
What does state of the binary sensor say when you press the button?
LuigiS00
(Luigi)
April 15, 2022, 9:38pm
3
It’s a little bit strange, because i don’t see anything in the log and the binary_sensor show the status “locked or unlocked” but random.
nickrout
(Nick Rout)
April 15, 2022, 9:42pm
4
Sounds like it is floating, what exactly is your wiring?
LuigiS00
(Luigi)
April 15, 2022, 9:48pm
5
The wiring is port D2 with GND. I saw that the port D2 on my nodemcuv3 is the GPIO 4.
In my esphome code says that my board is esp01_1m.
nickrout
(Nick Rout)
April 15, 2022, 10:13pm
6
That is correct. So your button shorts D2 to ground? I think you need pullup GPIO Binary Sensor — ESPHome
LuigiS00
(Luigi)
April 15, 2022, 10:37pm
7
So like this:
binary_sensor:
- platform: gpio
pin:
number: 4
inverted: false
mode:
input: true
pullup: true
name:
"PulsanteD2"
I tried with this code, but when I release the button, the state goes to off
nickrout
(Nick Rout)
April 15, 2022, 10:41pm
8
No, your indentation is wrong. See the example I pointed you to.
LuigiS00
(Luigi)
April 15, 2022, 10:52pm
9
Thank you so much for the example, but I don’t know if I understood what to do.
So I set “pullup” to false and now when I click the button, the state goes from on to off and stop it…
LuigiS00
(Luigi)
April 15, 2022, 11:23pm
10
I created the automation that when I click the button the light goes on.
Now the problem is how to stuck the state of the button on “ON” when I push the button and “OFF” when I push again the button
nickrout
(Nick Rout)
April 15, 2022, 11:33pm
11
The toggle automation in your first post should do that.
LuigiS00
(Luigi)
April 15, 2022, 11:39pm
12
I don’t know why but the automation doens’t work with switch.toggle.
So I created 2 automation, 1 to turn on the light and 2nd to turn off the light.
But when I press the button, the state of the binary_sensor goes to On and again to off
nickrout
(Nick Rout)
April 16, 2022, 5:10am
13
You are really confusing me. Please post your current config for both the esphome and the HA automation.
LuigiS00
(Luigi)
April 16, 2022, 10:04am
14
I’m sorry about that I have a bad english grammar.
Anyway I just saw that it was a eWelink bug, so the switch.toggle didn’t work fine.
So I found that there is a script that basically Turn on the switch when the switch is off and vice-versa.
So I created the automation that when I push the button then execute the script.
