Currently I have 10 12v halogen spots on my porch, these spots are controlled with a zwave-dimmer. I want to replace the halogen spots with LED spots and preferably control them with a Wifi + MQTT dimmer.
Does anyone know of such a dimmer ? I can’t find anything ESP8266 based.
I want to use 1 controller for 5 spots. The spots are MR16/12V/3w spots. I don’t know the exact output of the power supplies (there are 2 for 10 halogen spots).
Then you need a power supply that can provide the power for the 5 spots. The actual power supply already supply power for 5 spot, it could be ok.
Check on the power supply, it should be written how much current, in amper (A) or milliamper (mA) it can supply.
You will need a little more power than what is consumed by the 5 spot, to power the esp.
The 5 spots use 3W*5=15W, which equal to 1.25A. With the esp, a 12V 1.5A is enough to power the spot + the driver (ESP).
To be on the safe side, and if you often run the 5 spots at full power for long period of time, you should take a 12V 2A power supply.
It’s better to take one that can supply a little more, so it won’t become warm and extend the life length of the power supply.
